LTU932
First Picture Of The PW6000 Powered LAN A318
Sat Feb 17, 2007 11:56 pm
I searched but found nothing on the subject. Here it is, LA's first A318 and the first PW6000 powered A318 that's getting ready for delivery:
Photo © French Frogs AirSlides
About time the PW6000 enters service.
A342
RE: First Picture Of The PW6000 Powered LAN A318
Sun Feb 18, 2007 12:00 am
Quoting LTU932 (Thread starter):
Thanks for the pic, it looks very good !
But what is it doing in TLS, and why has it a French reg ? Never seen that on German-assembled Airbuses before.
Exceptions confirm the rule.
EI321
Sun Feb 18, 2007 12:04 am
What are the dorsal fins on the side of the engines?
Ari
Sun Feb 18, 2007 12:07 am
Anybody know what kind of routing it will be taking to reach south america?!?
aRi
EI321
Sun Feb 18, 2007 12:12 am
Quoting Ari (Reply 3):
If it had folding wings they could have just shuved the whole thing into a beluga!
Anbody know what the situation is with the A318 and LCY certification? Could be a big sales booster.
[Edited 2007-02-17 16:16:36]
LTU932
Sun Feb 18, 2007 12:30 am
Quoting A342 (Reply 1):
Probably some extra flight testing prior to delivery. That's my guess.
Who knows. Regardless of whether it will be delivered through SMA and MAO or through DKR and MAO, the initial routing might be very long and tight in range if it doesn't have any temporary aux tanks, but once in South America, probably Brazil, it shouldn't be very difficult to get the A318 to SCL.
I guess the delivery might be XFW-SMA-MAO-SCL with aux tanks. The same if delivery is from TLS.
Sun Feb 18, 2007 12:48 am
Quoting EI321 (Reply 2):
Vortex generators found on other 320 models as well, cuts down on the engine/pylon interference on the wing.
LH526
Crew
Sun Feb 18, 2007 12:49 am
Grea photo. Saw it in FXW in primer cls.
Anyone know the exact first inaugural flight date for LA? Any proposed routings?
Mario
LH526
Trittst im Morgenrot daher, seh ich dich im Strahlenmeer ...
Sun Feb 18, 2007 12:53 am
Quoting LH526 (Reply 7):
Just noticed that that aircraft has the trailing probe as well, which means its a certification flight, will have to wait for it to get certified first.
LH526
Crew
Sun Feb 18, 2007 12:59 am
Quoting Zeke (Reply 8):
Noticed that too, that's why I asked  Smile
A342
Sun Feb 18, 2007 1:19 am
Quoting LTU932 (Reply 5):
Depending on the MTOW LA has selected, aux tanks might not be needed at all. Additionally, you can chose a route where you don't need them, even with a low MTOW. I suspect that's what they'll do.
LTU932
Sun Feb 18, 2007 1:48 am
Quoting A342 (Reply 10):
I should have been more clear, so I apologise for the misunderstanding. With aux tanks, I meant temporary aux tanks, similar to those used on delivery flights of 717s to Hawaii.
VictorKilo
Sun Feb 18, 2007 2:58 am
SID-FOR is only 1536 nm - well within the range of a A318, yet alone an A318 without passengers. So I don't see why they would need to use aux tanks to get the aircraft from Africa to South America - and you certainly wouldn't need them to get from TLS (where the picture was taken) to SID, or FOR to SCL. Even if you needed a fuel stop in between TLS-SID or FOR-SCL, you certainly woudn't need to spend the money to modify the cabin for aux tanks.
A342
Sun Feb 18, 2007 3:04 am
Quoting LTU932 (Reply 11):
No, I've understood you ! Still, see here why even those are unnecessary:
Quoting VictorKilo (Reply 12):
KL808
Sun Feb 18, 2007 5:08 am
Wow. What a beautiful aircraft indeed.
How many does LA have in order?
Whats the backlog on the A318?
Drew
AMS-LAX-MNL
MCOflyer
Sun Feb 18, 2007 6:21 am
I agree its too beautiful. I'm curious to know the routes LAN will use them on.
MCOflyer
Devilfish
Sun Feb 18, 2007 7:01 am
That is the most beautiful livery on an A318 so far. Great that LAN Chile will soon have it in service. When are the rest due to follow?
What are the facilities at Ilheus like? A three leg TLS-DKR-IOS-SCL ferry routing would be relatively easy, with 2500+/- mile segments - well below the A318's 3,250 nm range limit.
I believe LCY certification is targetted for the first half of this year. The Airbus site says LA would use the A318s for domestic operations.
We may finally know if Pratt & Whitney is successful in this iteration of the PW6000 engine.
[Edited 2007-02-17 23:08:19]
Minuteman
Sun Feb 18, 2007 7:04 am
Are those brake fans on the mains? It seems unusual that a baby bus would need them, especially when it has thrust reversers.
Photo © Rui Alves - Madeira Spotters
EI321
Sun Feb 18, 2007 7:14 am
Quoting DEVILFISH (Reply 16):
It would be great if WX ordered the A318 as they could use the maintainace & training facilities of AF, and offer a proper 5 abreast business class. With the new Avros arriving however this looks like only a long term possibility.
felipemia89
Sun Feb 18, 2007 8:45 am
Beautiful aircraft! Can't wait until its inaugural flight for LAN.
WesternA318
Sun Feb 18, 2007 8:51 am
What a gorgeous looking Aircraft, cant WAIT to tryout LAN!
Check out my blog at fl310travel.blogspot.com!
DAYflyer
Sun Feb 18, 2007 9:26 am
The engines almost look as large as the fuselage.
Great looking livery though.
One Nation Under God
CF188A
Sun Feb 18, 2007 12:49 pm
can someone please tell me ... what the point in the A318 really was? I mean it is not more efficient than the EMB series... if i read these forums correctly.? How much life does this aircraft really have in store?
Dream as if you'll live forever. Live as if you'll die tomorrow~ RIP ... LJFM
LTU932
Sun Feb 18, 2007 12:55 pm
Quoting CF188A (Reply 22):
I believe Airbus wanted to enter the 100 seat market with the A318. In all fairness, we could probably ask the same thing about the Boeing 737-600.
WesternA318
Sun Feb 18, 2007 12:57 pm
There is a small need for it, you will see some airlines either buy the aircraft as a step up from props, or for others, as a 737-500/DC-9 replacement
CanadianNorth
Sun Feb 18, 2007 1:35 pm
A slightly shrunk A319 basically, to offer a 100 seat version of the popular A320 series. It is heavier and larger than the Embraer 190 but hauls roughly the same number of pax. Because of this it is less efficient and can be charged more for landing fees etc, however, it does offer a lot of commonality with the A319/A320/A321. So for airlines who already have those aircraft, the higher costs of the A318 vs the E190 can be made up for by having interchangeable crews and simplified maintenance. Same goes with the 737-600 vs the E190 for airlines with fleets of other 737s.
For airlines that require large fleets of both (example being Air Canada with 100some 319/320/321 and a fleet of E175/190s), it is more economical to go with the 190. On the other hand, if you are like Westjet and have a large fleet of 737s and only require a small number of 100 seaters, the maintenance costs and crew costs have a larger effect and thus it becomes cheaper to just pick up a few -600s.
The market for both the 318 and the 736 is quite limited, but considering they were fairly easy and pretty cheap for Airbus and Boeing to develop (start with a 737-700 or an A319 and basically just shorten it up a few feet) it is entirely possible for money to be made with them.
CanadianNorth
Way to go, nice and slow, never late, 748!
Devilfish
Sun Feb 18, 2007 3:27 pm
Quoting CanadianNorth (Reply 25):
To be more specific, 9 more than the E190 and 1 less pax than the E195, significantly farther with substantially more cargo.
CF188A
Sun Feb 18, 2007 10:27 pm
Quoting DEVILFISH (Reply 26):
which...the Embraer or the 318?
Mexicana757
Mon Feb 19, 2007 2:49 am
Nice looking LAN A318.
Quoting CF188A (Reply 27):
That would be the A318
A342
Mon Feb 19, 2007 5:21 am
The A318 also has a better airfield performance than the E-series, maybe that point was imortant to LA.
Devilfish
Thu Feb 22, 2007 1:26 am
Quoting KL808 (Reply 14):
Twenty (20) according to this Flightglobal report.....
http://www.flightglobal.com/articles...testing-five-years-later-than.html
"The first Pratt & Whitney PW6000-powered Airbus A318 for launch customer LAN Airlines is undergoing testing. The Chilean airline has 20 of the twinjets on order."
I believe the LA order is pretty much it, because the other launch customers had converted to the A319, cancelled or just let their orders lapse when their aircraft/engine combination of choice failed to meet performance requirements. I think some of them might revive their orders while others could place new orders IF they see a DRAMATIC performance improvement in LA's PW6000A engined birds.
A342
Thu Feb 22, 2007 1:34 am
Quoting DEVILFISH (Reply 30):
You should include the A318Elite backlog, then the figure almost doubles.
WINGS
Thu Feb 22, 2007 1:43 am
That is correct DEVILFISH. Lan currently have 20 A318 on firm order. I believe that LAN also hold some options as well.
Here are the correct figures for the A318 backlog.
Air France x 1
LAN x 20
Tarom x 2
Frontier x 4
Private (A318 Elite) x 13
US Airways x 15 (it will be interesting to see what US does with this order).
Total: 55 frames to be delivered.
Wings
Aviation Is A Passion.
Danny
Thu Feb 22, 2007 1:48 am
Quoting WINGS (Reply 32):
IMO will convert to 320/321.
KL808
Thu Feb 22, 2007 2:14 am
Maybe DEVILFISH meant PW powered.
But thanks WINGS for the backlog update. Hopefully those 15 US frames will get delivered as 318's.
Quoting Danny (Reply 33):
 cry
Drew
AMS-LAX-MNL
Areopagus
Thu Feb 22, 2007 3:02 am
How much performance/CASM improvement is claimed for the PW6000 variant?
