flynavy
Why Did AC Serve Norfolk?
Sun Feb 18, 2007 8:50 am
I've always wondered why they flew here (ORF). If I recall, they pulled out around 9/11. Was it to funnel pax to the cruise terminal here, or what? Just wondering.
Change is: one airline, six continents!
lijnden
RE: Why Did AC Serve Norfolk?
Sun Feb 18, 2007 12:25 pm
The AC flights were mostly summer holiday package flights. Virginia Beach is or was very populair with Canadians. It also gives or gave ORF its International status (customs etc.).
I am not sure about the cruise terminal.
Be kind to animals! Next trip: ORF-ORD-NRT-IAD-ORF
toltommy
Sun Feb 18, 2007 12:34 pm
Quoting Lijnden (Reply 1):
Having Int'l service has NOTHING to do with the status. ORF is still an Int'l airport, because it is equipped to process int'll arrivals and departures. For example, CAK is not an international airport. But it had AC service around the same time, because of preclearance facilities at YYZ. CAK-YYZ service didn't last long either. However, the local GA airport in Akron, Akron-Fulton Int'l, is equipped to process Int'l arrivals and departures. There hasn't been any scheduled service to Akron-Fulton in my lifetime.
Quoting Flynavy (Thread starter):
It was because they thought they could make money, plain and simple. There was a ton of extra capacity following the CP/AC merger that had to be flown to new destinations. As I said earlier, AC started YYZ-CAK service around the same time, it lasted less than 6 months.
flynavy
Sun Feb 18, 2007 4:30 pm
These flights were flown with CRJs, correct?
deltairlines
Sun Feb 18, 2007 5:24 pm
Quoting Flynavy (Reply 3):
Yes...I remember seeing an AC CRJ at the gate back in July 2001 in ORF.
N1120A
Sun Feb 18, 2007 5:48 pm
Quoting TOLtommy (Reply 2):
You are incorrect for 2 reasons. First, despite pre-clearance, airlines coming from Canada must always land at an airport with FIS capability and international status, hence why AS had to divert a YVR-SNA flight despite pre-clearance. Second, here is the operations listing on Airnav for CAK. Notice the final line.
Airport use: Open to the public
Sectional chart: DETROIT
Control tower: yes
ARTCC: CLEVELAND CENTER
FSS: CLEVELAND FLIGHT SERVICE STATION [216-267-3700]
NOTAMs facility: CAK (NOTAM-D service available)
Attendance: CONTINUOUS
Wind indicator: lighted
Segmented circle: no
Lights: DUSK-DAWN
Beacon: white-green (lighted land airport)
Landing fee: yes, MULTI ENG ONLY
Fire and rescue: ARFF index B
Airline operations: ONE HOUR PPR FOR UNSKED ACR OPNS WITH MORE THAN 30 PSGR SEATS CALL AMGR 330-499-4059. ARFF SVC NOT AVBL 0000-0600 DLY EXCEPT ONE HR PPR; CALL AMGR.
International operations: customs landing rights airport
austinairport
Wed Feb 21, 2007 1:26 pm
Does anybody know if they have plans to update the old terminal. The Arrivals Terminal is so pretty on a warm sunny day.
Whoever said you can do anything you set your mind to has obviously never tried to slam a revolving door!!!
flynavy
Wed Feb 21, 2007 8:15 pm
Well, there are plans to expand Norfolk's terminal to three concourses. The only other expansion in the works is another runway. They just finsihed a remodeling of the two existing concourses. See www.takeorf.com.
