Arcrftlvr
WN Flight - PHX To PHX?
Wed Feb 21, 2007 10:39 pm
I saw on the boards at Sky Harbor this morning (2/21), that WN flight #8751 is a scheduled 7:00am departure from PHX to PHX? Can anyone shed some light on this flight?
OPNLguy
RE: WN Flight - PHX To PHX?
Wed Feb 21, 2007 10:42 pm
It's a testhop of an aircraft coming out of maintenance....
Arcrftlvr
Wed Feb 21, 2007 10:46 pm
Then, why would it be posted on the boards if it won't be carrying any passengers? Just curious.
OPNLguy
Wed Feb 21, 2007 10:52 pm
ASD-based flight trackers don't show flights based on their being passenger-carrying or not--they just show flights, period.
JayDub
Wed Feb 21, 2007 10:53 pm
Likely because, in one way or another, whatever combined dispatch/scheduling/res software suite WN uses, automatically feeds the Flight Information Displays.
[Edited 2007-02-21 14:54:26]
"Travel is only glamorous in retrospect." - Paul Theroux
OPNLguy
Wed Feb 21, 2007 10:57 pm
Quoting JayDub (Reply 4):
Likely because, in one way or another, whatever dispatch/scheduling/res software WN uses, automatically feeds the Flight Information Displays.
Not exactly...
Whenever we (or any other airline) files an IFR flight plan with ATC, that info is what gets into the ASD system. (This is why you also see the route of flight). The airline's scheduling and/or rez systems are not involved with what one sees on ASD. The on-airport FIDS/monitor dispalys are another matter. I'd bet you that SWA8751 is not showing up on the arrival/departure monitors inside the terminal at PHX....
JayDub
Wed Feb 21, 2007 11:04 pm
OPNL...the OP is referring to the "boards" or FIDs at PHX Sky Harbor.
(I'm aware of the beauty of how the ASD gets its info.)
It happens...I don't know what software WN uses, but those who use information feeds from SABRE products like FTPlot/FTWeb and the such to feed FIDs have been known to show anything that originates out of certain airport.
If there's a test flight with an origination out of the PHX and coming right back to PHX, it will likely show up on on both the departure and arrival boards...just with no gate information. It's an IT function to keep those from showing...it's just not worth the hassle.
What are we betting?
[Edited 2007-02-21 15:08:07]
OPNLguy
Wed Feb 21, 2007 11:28 pm
Quoting JayDub (Reply 6):
A beverage of your choice...
Let me know what it says, I'm curious...
[Edit}
I'll be darned... A 07:09 departure...
http://www.ifly.com/phoenix-sky-harb...ernational-airport/live-departures
[Edited 2007-02-21 15:33:45]
JayDub
Wed Feb 21, 2007 11:34 pm
Shiner Bock it is...Man, I miss home.
Obviously I can't see the FID screen at PHX from my little corner of the world...but if you pump the info into Southwest.com you get this.
Flight Status Information
Arrival Date: Wednesday, February 21, 2007
Flight Number: 8751
Departure Phoenix (PHX) 07:00 AM 10:00 AM Delayed N/A
Arrival Phoenix (PHX) 07:50 AM 10:50 AM Delayed N/A
[Edited 2007-02-21 15:35:47]
JayDub
Thu Feb 22, 2007 12:10 am
Quoting OPNLguy (Reply 7):
http://www.ifly.com/phoenix-sky-harb...tures
Interestingly enough, we maybe have just unintentionally uncovered a fatal flaw in the PHX flight information system. WN lists scheduled departure time as 0700 local, however PHX says it is scheduled for 0709 local.
I appears they get the info from the FAA...which doesn't list gate departure time, but actual wheels up time. Could be bad for any average pax that doesn't understand the difference.
[Edited 2007-02-21 16:12:04]
Arcrftlvr
Thu Feb 22, 2007 1:57 am
Quoting OPNLguy (Reply 5):
Yes, it was posted on the departure monitors at the airport and was "delayed" until 10:00am...I did not look at the arrival monitors.
OPNLguy
Thu Feb 22, 2007 2:58 am
Quoting ArcrftLvr (Reply 10):
Roger that.. Looks like they canceled it as SWA8751 and ran it as SWA8750, in the air now...
http://flightaware.com/live/flight/S...0/history/20070221/1713Z/KPHX/KPHX
litz
Thu Feb 22, 2007 3:18 am
Quoting OPNLguy (Reply 3):
There have been instances of flights listed at Hartsfield, leaving from "Gate DN" ... they were Delta test flights leaving from Delta North (the old MX hangar), that somehow didn't get editted out of the public screens ...
Hartsfield also has the infamous Gate XLD ... ie: cancelled ...
 Smile
- litz
ATCGOD
Thu Feb 22, 2007 3:59 am
Someone tell me if this is a stupid question. But since it's not a revenue flight, why are they using SWA as a callsign and not N*****? Just curious.
OPNLguy
Thu Feb 22, 2007 4:08 am
We release all our Part 91 ops just like they are Part 121 ops... It's mostly a contractual issue...
ATCGOD
Thu Feb 22, 2007 4:17 am
Quoting OPNLguy (Reply 14):
With who? Pilots? I'm not sure why that would be a contractual issue for anyone.
OPNLguy
Thu Feb 22, 2007 4:21 am
Quoting ATCGOD (Reply 15):
The dispatchers are unionized too...
ATCGOD
Thu Feb 22, 2007 4:23 am
Quoting OPNLguy (Reply 16):
Didn't know that.
chris133
Thu Feb 22, 2007 5:58 am
The flight showing on the FIDS board is not a glitch or flaw of any kind. We have the ablity to show any flight on the internal (or employee only) screens or show the flight on both the internal and Public screens. All it takes is one check mark in a box on a computer to change that.
Silver1SWA
Crew
Thu Feb 22, 2007 6:25 am
After the fender bender in SAN back in December, one of the aircraft did a test flight around SAN after being repaired. It showed on our FIDS.
chris133
Thu Feb 22, 2007 6:49 am
Quoting Silver1SWA (Reply 19):
Yeah Ops left the internal only box unchecked on that one. Same thing as PHX
