airbusA346
F-WWAI & A330F Questions
Wed Feb 28, 2007 5:44 am
I was just wondering is the weird hump on the nose of F-WWAI, has something to do with this, e.g Testing.
From Wikipedia Airbus A330 page.
To overcome the standard A330's nose-down body angle on the ground, the A330F will make use of a revised nose landing gear layout. The same leg will be used, however it will be attached lower in the fuselage, requiring a distinctive blister fairing on the nose to accommodate the retracted nosegear.
Photo © Terence Li
Also why are the going to do that with the nose gear on the A330F why not just lengthen the nose gear, instead of lowering the nose gear assembly in the aircraft and creating that horrible looking hump.
Tom.
Tom Walker '086' First Officer of a A318/A319 for Air Lambert - Hours Flown: 17 hour 05 minutes (last updated 24/12/05).
A342
RE: F-WWAI & A330F Questions
Wed Feb 28, 2007 5:51 am
Lengthening the nose gear would be very expensive, and it wouldn't look any better. Airlines won't care about the look.
I think that A340 is testing something else, the fairing looks different.
Exceptions confirm the rule.
KL808
Wed Feb 28, 2007 6:14 am
Isn't the hump for extra strenghthening too.
Drew
AMS-LAX-MNL
airbusA346
Wed Feb 28, 2007 7:00 am
Quoting KL808 (Reply 2):
How can it be used for strengthening, when it isn't used on any other Airbus Freighter.  Wink
Tom.
RichardPrice
Wed Feb 28, 2007 8:55 am
Quoting AirbusA346 (Thread starter):
Wouldnt lengthening the nose gear also produce the problem of it not fitting into the housing? And thus also create the requirement of a hump?
The size of the wheel well isnt infinite you know...  Smile
CV580Freak
Wed Feb 28, 2007 9:28 am
I read in FI's Straight & Level that it's nothing to do with the nose gear. It is,in fact, being secretly being developed to house a chin mounted weapon to take out the oppositions freighter/tankers in 'head to head' competitions.
It will also be fitted with a chaff system designed to blow A350 Mk 1 marketing brochures into the engine inlets of the competitors........
One day you are the pigeon, the next the statue ...
CV580Freak
Wed Feb 28, 2007 9:30 am
Seriously though, I think the avionics bay was moved in the original pax A330 to accomodate a crew rest area and it's obviously easier (and cheaper) to tinker with the undercarriage than the avionics.
chuchoteur
Wed Feb 28, 2007 4:53 pm
Ref A330, answered your own question...
cheaper to modify a bit of structure than redesign and certify a new undercarriage unit.
of course, it would have been better from the get go to have an aircraft that sat level on the ground...
Ref A340 pic, it is the prototype testing a LIDAR (Laser radar thingy) in trials ref clear air turbulence (CAT)
