gyojoo
Video Of A380 Fan Blade Off Test
Fri Mar 02, 2007 2:05 am
Donno if it was posted before, but here's video of A380 RR Trent 900 Fan Blade Failuare Test.
All I can say is Wow on the sheep power of that thing running at full and when it goes off.
iboam
RE: Video Of A380 Fan Blade Off Test
Fri Mar 02, 2007 4:50 am
All I can say is amazing! Sad that they had to destroy such a beautiful piece of engineering.
wjcandee
Fri Mar 02, 2007 4:54 am
Quoting Gyojoo (Thread starter):
How many sheep does it use?
(And why not horses?)
DAYflyer
Fri Mar 02, 2007 5:31 am
Quoting Iboam (Reply 1):
I agree, but better to test and be safe. Great video, thanks to the thread starter for sharing.
One Nation Under God
autothrust
Fri Mar 02, 2007 5:54 am
Yes, i posted it a half year ago, though i cant find my thread with the sh*t search engine. However the video is amazing one engine = 4 tons of solid gold.  eyepopping
“Faliure is not an option.”
airfoilsguy
Fri Mar 02, 2007 6:37 am
Quoting AutoThrust (Reply 4):
There is no way that each engine cost $84,966,400 US dollars. That would mean a set of 4 costs $339,865,600
Gold $663.80 per ounce
16 ounces per lb equals 1 lb of gold at $10,620.80
4 tons equals 8000lbs
8000lbs times 10,0620.80 equals $84,966,400
It's not a near miss it's a near hit!!
autothrust
Fri Mar 02, 2007 12:30 pm
Quoting Airfoilsguy (Reply 5):
 Wow! Huh, i didnt sum it but of course you are right. In the full video they mentioned it. Maybe that was some years ago(2000?) when Gold prices didnt rise so much or discovery channel just cant sum.
OPNLguy
Fri Mar 02, 2007 12:35 pm
I'll say; not too ba-a-a-a-a-d at all....  Wink
AsstChiefMark
Fri Mar 02, 2007 12:42 pm
Quoting Wjcandee (Reply 2):
I thought they fired chickens are them. Now they're using sheep? Wow.
Mark  Wink
Red tail...Red tail...Red tail...Red tail...Red tail...Red tail...Red tail...Red tail...Damned MSP...Red tail...Red tail
YUL777
Fri Mar 02, 2007 1:00 pm
Can somedy tell me if this test will also certify the engine concerning the brid strike issue of if it's a whole different test?
jasond
Quoting AsstChiefMark (Reply 8):
That's technology for you, what a great world we live in
katwspotter
Fri Mar 02, 2007 1:32 pm
What an awesome video. Really captures the true forces of a jet engine.
A/C I have worked in ATW - SF340 E145 CRJ2/7/9 DC93/4/5 A319/20 MD83 B738 B752/3 B763/4 A333
ardian
Fri Mar 02, 2007 2:45 pm
Wow... all I can say is wow...
The sound when the engine goes to full power is just evil! What a great vid
Fri Mar 02, 2007 5:40 pm
Explain the Coloured & Striped Blades.
regds
MEL
JAAlbert
Fri Mar 02, 2007 6:19 pm
It looked like the building shook when that blade came off. Is that due to the explosive charge or was that actually due to the energy released when the blade came off? I would be very, very concerned if I heard an explosion like that -- and the plane shook -- like that building did while over the middle of the atlantic.
Asturias
Fri Mar 02, 2007 7:34 pm
Quoting HAWK21M (Reply 13):
You watched the video, but didn't listen to the narration..? Amazing. The blades were explained in the video.
saludos
Asturias
Tonight we fly
airfoilsguy
Fri Mar 02, 2007 8:38 pm
Quoting JAAlbert (Reply 14):
It is from the blade coming off. The explosive charge is tiny any would sound like a gunshot.
Quoting Asturias (Reply 15):
Calm down, a lot of people surf the web at work where listening to sound is not wise.
EMA747
Fri Mar 02, 2007 9:50 pm
Hucknall, Nottingham is just down the road from where I live!  Big grin
Quoting Ardian (Reply 12):
It sent shivers down my spine. It's an amazing advert for British engineering that we can build such an awesome piece of equipment. And I'm also very proud that it comes from my area.
Andy S
Failing doesn’t make you a failure. Giving up and refusing to try again does!
GEnxPower
Fri Mar 02, 2007 10:05 pm
Not to take away anything from the energy released from such a fan blade out event, the video does use certain amount of artistic license and dramatization of the event, especially the shaking of the camera at the monitoring station. The engine will get a tremendous shake for sure, but feeling the building shake like that is just director's extra little touch.
In the plane, you will probably feel a jolt but that's the entire point of the FBO, to keep the blade out event under control. Other parts of FAA certification requirement include containment, vibration response, load imbalance from non uniform fan and engine control. (i.e Pilot or control must still have enough authority over the engine power to at least shut it down safely without the engine going out of control)
The explosion and the flames are real though, and so is the shaking, vibrations and swelling of the fan case and fan cowl. Remember, the test cameras used for such a test are special high frame rate cameras, that captures up to 10,000 frames per second. Normal 30 fps camera won't pick up much vibs and deformations at all.
Good video! Thanks for sharing
tepidhalibut
Fri Mar 02, 2007 10:09 pm
Quoting YUL777 (Reply 9):
Nope. The Fan Blade Off and Bird Ingestion tests are completely different.
- FBO - Gotta contain all high energy debris. Obviously, the engine is not expected to continue producing thrust.
- Medium Bird Ingestion - (The usual test you see video of). The engine needs to cope with approx 8 medium sized birds hitting it at take-off speeds, and still be able to produce 75% of rated thrusts. The reasoning is that medioum sized birds are flocking birds, so could affect all of the installed engines. You don't want to lose all thrust.
There is some overlap and wrinkles regarding Large Birds and LFBs, but I'm trying not to get too technical.
Hope This Helps...
YUL777
Fri Mar 02, 2007 10:27 pm
Thanks TepidHalibut for the explanation. I was discussing about this test this morning with a few colleagues and I was told by a former Boeing engineer that they don't use frozen chicken no more to simulate the bird ingestion. They use something like an hard ball, maybe the size of a handball, that is thrown in the engine for this particular test. Can anyone confirm the information and give more detail about this ''ball''.
LHStarAlliance
Fri Mar 02, 2007 10:35 pm
Wow ! Imagine the force of such an blade at 3K r/m !
Boycott The Olympic Games In Beijing !
airfoilsguy
Fri Mar 02, 2007 10:37 pm
Quoting Yul777 (Reply 20):
Last I heard they still use real birds. Not frozen ones because your chance of encountering a frozen bird in flight is almost nil. The same can be said for handballs. When testing engines the conditions have to be realistic. I don't think a handball would be realistic enough.
United787
Fri Mar 02, 2007 11:40 pm
Quoting Airfoilsguy (Reply 22):
 rotfl
Sat Mar 03, 2007 6:53 pm
No Audio.as was at work.Maybe I'll check it out on another computer after work.
regds
MEL
