kearney
Yyz Aircraft Declaring Emergency
Fri Mar 02, 2007 6:15 am
I am listening to the traffic in toronto, i did not catch the flight # or airline, however an aircraft has declared an emergency and is trying to land on 33R. ill keep you posted.
kearney
RE: Yyz Aircraft Declaring Emergency
Fri Mar 02, 2007 6:16 am
It seems to be an iceing issue and they cant maintain altitude.
[Edited 2007-03-01 22:17:42]
kearney
Fri Mar 02, 2007 6:26 am
Aircraft is on the ground. I think it was skyservice, could be wrong.
manu
Fri Mar 02, 2007 6:31 am
Probably should add that YYZ is under a major winter storm right now with icing conditions at the max. Environment Canada issued a severe winter weather warning early this morning. I am surprised the flight tried to take off and the airport is even operating. I would not want to fly today.
sebring
Fri Mar 02, 2007 6:50 am
Hearing takeoffs overhead, so the airport is operating outbound, but several planes have diverted to their secondary airports.
Cruiser
Fri Mar 02, 2007 10:22 am
The airport has been operating all afternoon...looks like just some delays. I was out there this afternoon and you could not even make out planes that were about 100m away. Although...I knew they were there because you could easily hear them! They were certainly busy clearing snow though....
James
Leahy on Per Seat Costs: "Have you seen the B-2 fly-by at almost US$1bn a copy? It has only 2 seats!"
laxagent
Fri Mar 02, 2007 12:06 pm
I was just there on Tuesday everything was smooth. Only thing is the deicing all the way at the end of runway and the going back to the other end for take off. I was on AC 795 bound for LAX
LAX
lailaiyyz
Sat Mar 03, 2007 12:25 am
Looks like it is Aeropro 802, A Beechcraft 100 King Air (twin-turboprop).
Try this link
http://www.liveatc.net/forums/index.php/topic,2828.0.html
to hear the ATC recording for this.
From what I can make sense of the recording, the plane seems to have ice problem even before it takes off.. then after takeoff returns to the airport immediately.
[Edited 2007-03-02 16:32:19]
