isitsafenow
Powerouts At DTW End
Tue Mar 06, 2007 6:05 am
The DC-9 power outs at DTW have ended. I was through there 4 times in the past 4 weeks and did not see or
hear one power out.
In the March issue of the NW onboard mag, there is an article that talks about NW fuel
conservation. One sentence stated the "NW has a different pushback procedure that now saves the airline
fuel" It must be no power outs because its awfully quiet around the A building these days.
safe
If two people agree on EVERYTHING, then one isn't necessary.
michman
RE: Powerouts At DTW End
Tue Mar 06, 2007 6:26 am
While I understand the need to save fuel (why didn't they implement this months ago???) , I will definitely miss the power-backs in the DC-9. Love the sound of those JT-8D's spooling up.
N1120A
Tue Mar 06, 2007 6:41 am
Quoting Michman (Reply 1):
You know, while it does save fuel, it ends up costing them more on the labor and non-aircraft related expense end.
md80fanatic
Tue Mar 06, 2007 7:42 am
Everyone wants to be friendly to the environment these days.....even if it costs more money. It's all about the image of green (as in green movement)....kinda makes me sick actually.
Someone tell me a terribly heavy pushback truck with a big v8 (at least) burns just as much fuel as those twin JTs during the same manuever. Once the aircraft is in motion backwards.....it does not take much thrust to keep it that way.
srbmod
Tue Mar 06, 2007 7:52 am
Quoting MD80fanatic (Reply 3):
Increased a/c maintenance costs as well. Powerbacks are rough on engines and by eliminating the practice you save on the costs of maintaining and replacing engines.
Quoting N1120A (Reply 2):
The cost of additional labor and GSE is still less than the cost of a replacement engine. Even FL realized (in addition to the fuel savings) that and quit the practice a few years back.
md80fanatic
Tue Mar 06, 2007 9:13 am
Reverse thrust on landing is also hard on engines, and most of the time entirely unnecessary. Is catching the nearest exit worth the added engine maint. expense? I guess so since it happens all the time.
A better argument would be reducing noise levels in and near the terminals and having less chance of blowing debris being tossed around the tarmac. I think the "fuel saver" mantra is basically to appease those that are currently deemed the most politically-correct.
N1120A
Tue Mar 06, 2007 2:52 pm
A diesel tractor probably doesn't burn that much fuel doing that.
Quoting Srbmod (Reply 4):
FL still does powerbacks regularly.
