777jaah
ANA Q400 Declared Emergency Landing
Tue Mar 13, 2007 9:35 am
Just on the news, i saw on CNBC World that an ANA plane has problems with its landing gear and its trying to land at Kochi Airport.
No details yet on type or anything at all.
JAAH
Next flights: AV BOG-ADZ-BOG, AV-UA BOG-IAD-ORD-IAD-BOG, BOG-FLL-BOG, LA BOG-MIA-BOG J
NWAatNGO
Tue Mar 13, 2007 9:46 am
Flight took off from Itami Airport in Osaka and was due to land at Kochi before 9am Japan time. They are now over 90 minutes late, but they are planning on landing at 10:50am even though the front gear has not come down. News is showing how they tried to break the gear loose by bouncing the plane off the runway, but to no avail. According to the news there are 56 passengers and 4 crew members. Not sure what type of plane, but it is a commuter plane, turbo prop. Watching the news now will keep everyone up to date.
Here's hoping they can land and stop safely.
NWAatNGO
MDorBust
Tue Mar 13, 2007 9:51 am
Sounds like it might be one of the DHC-8-402s
"I KICKED BURNING TERRORIST SO HARD IN BALLS THAT I TORE A TENDON" - Alex McIlveen
NWAatNGO
Tue Mar 13, 2007 9:56 am
MDorBust,
I think you are right about the plane.
It just landed and there were no problems. They were able to get it stopped on the runway and are currently spraying the fuselage with water, but it looked like a really smooth landing considering the situation.
Good work guys!!!
NWAatNGO
777jaah
Tue Mar 13, 2007 10:04 am
Quoting NWAatNGO (Reply 3):
Good work guys!!!
Thanks for the info, and thanks God everythiing weht OK for everyone onboard.
JAAH
smolt
Tue Mar 13, 2007 10:11 am
From NHK news;
http://up.mugitya.com/img/Lv.1_up4464.jpg
now passengers are getting off.
PanAm_DC10
Community Manager
RE: ANA Q400 Declared Emergency Landing
Tue Mar 13, 2007 7:07 pm
Here are some further links to an article from Flight International
http://www.flightglobal.com/articles...nose-gear-up-landing-at-kochi.html
That has a couple of shots of the landing and states that the cause of the nosewheel failure is not yet known.
The following is a link to a BBC article which has a video of the landing
http://news.bbc.co.uk/2/hi/asia-pacific/6444819.stm
ANA, Japan's second largest carrier, has grounded its entire fleet of Bombardier planes pending an inquiry.
Swift action from ANA until the results of the incident are known.
Regards, PanAm_DC10
Ask the impossible to achieve the best possible
Buyantukhaa
I scratch my head, therefore I am.
hoppe777
Tue Mar 13, 2007 7:20 pm
Wow ! great landing guys and to think that it was so smooth as if nothing happened at all.
They should be proud of themselves......
Hoppe777
Sometime in easter 10 .... yet to book :)
Tue Mar 13, 2007 7:29 pm
No doubt the pilots did a good job, but let's not overdramatize. This was hardly the most dire of emergencies.
LHStarAlliance
Tue Mar 13, 2007 7:47 pm
Will this affect the good safety record of ANA ??
Boycott The Olympic Games In Beijing !
YHMYYZspotter
Tue Mar 13, 2007 8:38 pm
Quoting Starlionblue (Reply 10):
I bet it was if you were a passenger on the plane. I know I would be just a tad nervous. I hardly think people are overdramatizing. I agree great landing!
Tue Mar 13, 2007 9:34 pm
Quoting YHMYYZspotter (Reply 12):
Whether I would have been nervous or not does not have any bearing on the skill of the pilots or the magnitude of the emergency. I sometimes get nervous when an aircraft flies through wake turbulence on approach. This hardly means the aircraft is about to plummet to the ground.
As I said before: Yes, this was an emergency and potentially there could have been loss of life. However, the pilots train for this situation and unless they screw up by the numbers landing with retracted nose gear isn't a huge problem.
And yes, I would probably have been scared. But my being scared doesn't make the situation any more or less dangerous.
Aaron747
Tue Mar 13, 2007 9:43 pm
Quoting LHStarAlliance (Reply 11):
Why would it? This is, for all intents and purposes, an incident and nothing more.
At any rate, the media here is making much of past troubles ANA Connection has had with the DHC-8-400s. Let the idiotic sensationalism begin  Yeah sure
centrair
Tue Mar 13, 2007 9:51 pm
Actually not really.
Last year the Japanese Land and Infrastructure Ministry sent a warning to Bombardier concerning the Q400s. Though NH was doing a great job at maintainance, there were concerns about the plane's forward landing gear. This is not the first time that there have been problems.
On the news tonight they were saying that this is actually something like the 4th time that a pilot has had problems with the forward landing gear. On all the previous times he pulled the emergency release to lower the gear and it worked. But this time it didn't work.
In February 2006, another Bombardier plane operated by ANA experienced landing gear problems. That pilot aborted an initial landing attempt after all three sets of wheels failed to deploy. The landing gear was later deployed manually, and none of the 25 passengers and crew was injured.
Later that month, two ANA-operated Bombardier airliners made emergency landings at Osaka airport shortly after taking off. One had problems with its heating system, while a warning lamp in the other signalled something was wrong with one of its doors. No one was injured.
In 2004, the right wheel of a Bombardier broke off while landing at Kochi airport, also with no injuries.
The Toronto Star
[Edited 2007-03-13 14:58:34]
My name is Centrair but HND is closer. Let's Japanese Aviation!
zschocheimages
Wed Mar 14, 2007 1:05 am
This happened on a Mesaba Q100 I was on about 12 or 13 years ago only it was one of the side gear. The pilot made 7 or 8 landing attempts at Houghton, MI before it finally came down. Next option was to do a wheels up landing at KI Sawyer AFB.
Why fly with 2 engines when you can have 3?
Jerald01
Wed Mar 14, 2007 1:23 am
 duck
It was the most dire of emergencies THAT crew and THOSE passengers were experiencing AT THAT TIME ! Any time the rollers don't come down and lock in place as advertised is a scary situation. We can sit back and "ho-hum" it all we want but you can bet the PPM * was pegged on the high side for the final landing...
* PPM = Pilot Pucker Meter
"There may be old pilots, and there may be bold pilots, but there are darn few green cows"
Wed Mar 14, 2007 4:25 am
Quoting Jerald01 (Reply 17):
I never said ho-hum. I said it was not the most dire of emergencies. I have no doubt the pilots had a nice high pulse. But it was hardly like they were very likely to die or anything. They didn't have two engines on fire over the ocean.
Of course it was the most dire they were experiencing at that time. But that's like saying when someone cuts me off on I-95 (an almost daily occurrence) that it is the most dire emergency at that time. Sure it is, but I still get to work in one piece every day.
[Edited 2007-03-13 21:26:33]
