SWAFA27
Quick Question On This Pic
Thu Mar 15, 2007 12:02 pm
What kind of angle and/or climb rate do you think this 757 is at?
Photo © Jonathan Rankin
[Edited 2007-03-15 05:23:33]
ALL views, opinions expressed are mine ONLY and are NOT representative of those shared by Southwest Airlines Co
san747
RE: Quick Question On This Pic
Thu Mar 15, 2007 12:04 pm
If that shot is level, looks about 25-35 degrees (judging by eyesight alone)... Either way... WOW!
Scotty doesn't know...
kearney
Thu Mar 15, 2007 12:14 pm
Id say 45 degrees, if its level.
AirplaneFan
Thu Mar 15, 2007 12:38 pm
Id say about 40°.
AirplaneFan
I GOT YOUR SIX
SWAFA27
Thu Mar 15, 2007 1:11 pm
Quoting San747 (Reply 1):
Quoting Kearney (Reply 2):
Quoting AirplaneFan (Reply 3):
Id say about 40°
Whats the standard angle for takeoff?
AirplaneFan
Thu Mar 15, 2007 1:30 pm
Quoting SWAFA27 (Reply 4):
I think it is 5°-20° depending on the weight of the airplane, though I may be wrong.
AirplaneFan
I GOT YOUR SIX
san747
Usually around 15 degrees.
GQfluffy
Thu Mar 15, 2007 2:25 pm
Used to be whatever angle didn't spill the coffee on the first class passengers...
This isn't where I parked my car...
LAXspotter
Thu Mar 15, 2007 2:41 pm
Quoting San747 (Reply 6):
Yep, Takeoff in a 737 means that you cannot put nose pitch higher than 10 Degreees or it going to be tailstrike, after positive climb, angle is increased to about 15 degrees.
"Patriotism is the last refuge of the scoundrel" Samuel Johnson
jetjeanes
Thu Mar 15, 2007 3:36 pm
Its and empty military plane.. they probably didnt give a hoot about coffee
i can see for 80 miles
Gr8Circle
Thu Mar 15, 2007 10:45 pm
Quoting GQfluffy (Reply 7):
You're not supposed to be drinking coffee during T/O...irrespective of class.... Big grin
alfa75
Fri Mar 16, 2007 1:27 am
I thought they served cocktails?
The best things in life aren't things!
SOBHI51
Fri Mar 16, 2007 1:38 am
At that angle the plane will stall.
timboflier215
Fri Mar 16, 2007 3:49 am
It's pretty impossible to tell for certain without being able to see the ground to measure the angle/ check that the photographer is holding the camera level. I'm sure it's pretty damned steep though!
MDorBust
Fri Mar 16, 2007 4:44 am
Quoting SOBHI51 (Reply 12):
If you hold the angle long enough, yes.
If you assume that angle to only for a few seconds, no.
There's a video floating around of a military 757-200 doing a mighty impressive zoom climb after a high speed pass.
"I KICKED BURNING TERRORIST SO HARD IN BALLS THAT I TORE A TENDON" - Alex McIlveen
Max777geek
Fri Mar 16, 2007 4:54 am
Quoting SWAFA27 (Thread starter):
What kind of angle
Oh, the famous "tilted camera" angle, indeed. It can be 179 degrees and the plane does not stall.
SWAFA27
Fri Mar 16, 2007 8:12 am
BTW found this great clip of the same kind of 757
Tristarfreak
Fri Mar 16, 2007 8:16 am
the camera might be at an angle but id still say that is toooo much of a angle for that type of plane
elcableguy77
Fri Mar 16, 2007 8:19 am
Quoting Tristarfreak (Reply 17):
Holy cow! What a climb angle!
Former ZW F/A | "Wisconsin 72A, contact departure, see ya."
