Gerry
Shades Up, Shades Down
Sun Mar 18, 2007 8:15 pm
It seems that Qantas and Virgin Blue on Australian domestic runs at least, require passengers to put blinds up just before landing. Is this required anywhere else and if so, why is that?
Gerry
Mir
RE: Shades Up, Shades Down
Sun Mar 18, 2007 8:22 pm
Always helpful to be able to see outside the plane in an evacuation situation, so that if there's something nasty out one side (such as a fire), everyone knows that opening those exits would be a bad idea. Also, if it's bright outside and all the shades are down, it makes the transition once people leave the aircraft a lot harder (same reason why they dim the cabin lights for takeoff and landing at night).
That, and the fact that windows are for looking out of.  Smile
-Mir
bastew
Sun Mar 18, 2007 8:26 pm
At BA the only requirement is that window blinds on doors and those near the doors are open for t/o and landing.
S5FA170
Sun Mar 18, 2007 9:55 pm
At Republic, our manual used to say "we recommend all window-shades be open for taxi, take-off and landing."
With out new revision, it now says "Prior to every taxi, take-off or landing, flight attendants must ensure all window shades are fully open."
As mentioned above, it is a safety issue. In the event an evacuation becomes necessary, those of us inside the cabin can assess conditions outside the cabin (smoke, fire, debris, water) and people outside the cabin can assess conditions inside (smoke in the cabin, flames, people, etc.)
I get asked this questions at least once a trip and once it is explained it usually makes sense. Its not a FAR (otherwise all airlines would require them to be open) so every airline is free to enforce their policy on this subject. I think the only FAR pertaining to this would be about exit rows, which my aircraft doesn't have, so I'm not sure exactly.
Prepare doors for departure and cross-check.
IAHFLYR
Sun Mar 18, 2007 10:01 pm
I heard the request this week on CO when the final approach to landing PA was made...."please raise your window shades for landing"...and that was the first I'd heard that PA before but I sure like it.
Quoting Mir (Reply 1):
Thank you!
malaysia
Mon Mar 19, 2007 3:47 am
but I do not like it when they brighten all the cabin lights and leave them on completely for landing and arrival at night. Its so hard to see outside and I practically think its like having shades down. It should be considered dangerous, cause we need to use our night vision and be aware of our surroundings when landing, thus the cabin should always be dimmed on arrival. they brighten them to pick up trash and check seatbelts, but some flights I have been on, just left them on all the way to the gate.
There Are Those Who Believe That There May Yet Be Other Airlines Who Even Now Fight To Survive Beyond The Heavens
iairallie
Mon Mar 19, 2007 3:53 am
Quoting Malaysia (Reply 5):
Most airlines go by the have the interior lights appoximate the outside lighting for landing and take off. However some emergency light strips need to be charged with the lights on full bright in order to work.
My airline requires shades up for taxi, take off and landing so you can see any hazzards outside if an evacuation becomes necessary.
Enough about flying lets talk about me!
travatl
Mon Mar 19, 2007 4:16 am
My carrier has gone back and for the with the shades issue over the years. No policy, then all up, then only up in exit rows, then all up again, the no policy, etc. etc... Currently no requirement for window shades. However, all lights to off/dim for takeoff and landing.
malaysia
Mon Mar 19, 2007 4:25 am
Quoting IAirAllie (Reply 6):
But I cant see any hazzards outside if the cabin is fully lit and its pitch black outside. I would need an emergency blanket to look out window for impending ground impact. (but the fleece blankets were $10? at Independence Air  Smile )
iflykpdx
Mon Mar 19, 2007 4:28 am
Semi-related question, but on the 787 will the way the windows are "blacked out" have an effect during emergency situations? I'm assuming here that once the power is cut to the system the window stays in whatever state it was in before the power was out. If anyone knows how it all works, any info would be appreciated!
Airport Management - UND
nzrich
Mon Mar 19, 2007 6:12 am
Yes we require all shades open for take off and landing at air nz
"Pride of the pacific"
KPWMSpotter
Mon Mar 19, 2007 8:54 am
Quoting IflyKPDX (Reply 9):
From what I understand of the 787 windows, the glass in its normal state is transparent. When an electric current is run through it, it will dim (much like the transitions lenses for glasses, although those dim under UV light). I can't find any texts online to back this up though, as I can't find exactly what the technology the 787 windows will be using is.
One benefit of this technology that I know of is that the FAs will be able to control all of the windows from a central location. Even if the glass was a problem, they could just flip a switch and open all the windows anyways. (maybe even safer than relying on the pax themselves to do it!)
I reject your reality and substitute my own...
iairallie
Mon Mar 19, 2007 12:31 pm
Quoting Malaysia (Reply 8):
Most airlines require that the cabin lights approximate the exterior condition for landing, as I mentioned in the same post you quoted. That means dim for at night brighter during the day. Trust me you will see flames out that window regardless of the interior lighting and time of day. In addition in emergency mode the the only lighting present in the cabin are the emergency path and exit lights, all other cabin lights are out.
Quoting KPWMSpotter (Reply 11):
Ok to reveal just what a geek I am. I've read a few articles about this type of window. The way it works is basically thus. It goes opaque when an electric current is applied. I belive they regain transparency as soon as the current is removed. So in an emergency the current would probably automatically be disrupted. I think that it is likely that the windows will be in clear mode for the phases of flight most likely to result in an emergency.
