luketenley
PIT Ranked 9th Overall In On- Time Departures
Tue Mar 27, 2007 12:26 pm
The data that define airport performance often stem, for better or worse, from the most complicated travel days in a given year, when delays super-size and passengers fume. The fierce winter storm of March 16 -- the one that sneak-attacked an entire state -- was such a day.
Stanley Luczak thought the weather would let him off easy that day. Forecasters had predicted the worst of it to arrive in mid-afternoon, just around the time that Mr. Luczak, operations duty manager at Pittsburgh International Airport, would end his shift.
"My actual figuring was, well, the next guys will be worrying about it," he said. "Everything was supposed to be hunky-dory until [5 p.m.]."
He arrived at the airport around 7 a.m. and studied the weather printout generated by one of three independently contracted airport forecasters. But within the hour, he noticed that worsening conditions -- and dropping temperatures -- didn't jibe with the prediction.
And suddenly, Mr. Luczak, one of seven men with the power to single-handedly shut down the airport, faced a Domino-line of snap decisions that would determine much about his airport's functionality for the day, and the weekend.
Across the state, Charles Isdell, Philadelphia International's director of aviation, was dealing with a similar constellation of nasty conditions.
After the storm dropped between 5 and 17 inches of snow throughout Pennsylvania, 1,000 people were still stranded that night at Philadelphia International Airport. Some there waited in kiosk lines for more than three hours to re-book flights. The airport sometimes maintained only one usable runway.
"It caught us off guard," said Mr. Isdell. "I don't think anybody knew the storm was coming as early as it did. ... It threw off our whole game plan."
At Pittsburgh International, that same storm caused only a fraction of the mayhem. Fewer than 25 fliers were stranded Friday night, spokeswoman JoAnn Jenny said, and many received hotel vouchers.
The reputations of Pennsylvania's two primary airports differ as much as their size and age. Philadelphia International opened during World War II; the new Pittsburgh International opened in 1992. Though the airports, only a decade ago, served roughly the same number of passengers, in 2006, Philadelphia served 31.8 million and Pittsburgh served just less than 10 million.
According to the Federal Bureau of Transportation Statistics, in 2006, 80.6 percent of flights departed Pittsburgh on time, ranking it 9th among 31 major U.S. airports. Philadelphia ranked 27th, with an on-time rate of 72.2 percent. And, among 14 carriers reporting data on flights leaving Pittsburgh, US Airways had the smallest percentage of flight delays, just 12.3. In Philadelphia, that percentage rose to 28.3.
"The airside of Pittsburgh is celebrated for the operational efficiency," said Bill Lauer, a local airline analyst. "Pittsburgh has generally had a very benign, on-time performance level. As compared to, say, Philadelphia. ..."
"For full disclosure," said Mike Boyd, a Colorado-based aviation consultant, "I've lived in Philadelphia, and I fully believe its airport should be leveled."
Of course, in the airline industry, even the most conclusive data come with caveats. Statistics from one airport depend on performance at another; just as efficiency reciprocates, problems can spiderweb. A plane late leaving Boston for its first morning flight, for instance, will likely perpetuate that delay at every airport it flies into for the remainder of the day. Airports aren't designed to make up for lost time.
That's why Pittsburgh, during the weekend storm, wanted to maintain two working runways at all times. Failing to do so would cripple operations. And Mr. Luczak, among others, shouldered responsibility for problem-solving his way out of the quagmire.
"The thing is," said Kent George, executive director of the Allegheny County Airport Authority, "we will not be the restriction. We will not."
Just after 8 a.m. on that snowy Friday, Mr. Luczak, who 13 years ago left the grocery business and found an entry-level job at the airport, recognized the need for unplanned action. He, not his successor in the next shift, would need to make a decision.
With ground temperatures close to freezing, Mr. Luczak feared the formation of ice on the runways -- a potentially fatal danger to planes landing at 165 mph. At 8:21, according to airport logbooks, he asked the crew outside to activate the anti-icing operation: This meant the runways would be covered with $75,000 worth of chemicals. This also meant that if temperatures soon rose to, say, 34 degrees, Mr. Luczak would face responsibility for burning that money without good cause.
Having held his current position since 2000, Mr. Luczak -- with glasses, a buzz-cut and a Drew Carey build -- knew the vagaries of airport management firsthand. For the longest days, he and his staff could make use of the on-site cots and kitchen. Delays could result from weather patterns, poor personnel training, decisions made by individual carriers. Delays borne at other airports could follow certain flights all day.
Delays could lurk anywhere, even underground, where groundhogs could chew through electrical wiring.
"We try to euthanize as many as possible," he said matter-of-factly.
Philadelphia has its own problems, some unpreventable. It's sandwiched between Washington, D.C., and New York City, each with three major airports that crowd the airspace above it, restricting some Philadelphia departures. Beyond that, Philadelphia's own growth has forced a series of construction projects, and even its minor on-time improvements -- its delay ranking rose from 31st (worst) in 2005 to 27th in 2006 -- "is not really something to jump up and down about," Mr. Isdell said.
In 2003 and 2004, US Airways finalized a hub transition that swapped Pittsburgh for Philadelphia. The airline rightfully saw potential in the eastern city because of its market size and room for growth; it became the gateway for European and Caribbean flights, and Pittsburgh shrank into a "secondary hub." Daily, US Airways now offers 431 flights from Philadelphia and 145 from Pittsburgh.
"For better of worse, US Airways, in terminal B and C, they occupy the two oldest parts of our airport," Mr. Isdell said. "They are not the most user-friendly areas. They were built in 1953. They have had some cosmetic upgrades, but they have narrow concourses. The spaces between the airplanes where they taxi are narrower than what you'd build today. And the infrastructure is 50 years old, so we're constantly replacing electrical systems, things like that."
US Airways spokeswoman Valerie Wunder said that "Pittsburgh is not a hub for us, and Philadelphia is. A hub is always going to have lower numbers in terms of performance, most always."
By the time the storm moved across Pennsylvania, the delicate, nationwide airline infrastructure was already set for days of complications.
Snow and ice continued to fall on that Friday afternoon. Heavy-duty trucks, equipped with plows and brooms as wide as double-lane highways, cleared Pittsburgh's two operating runways. The ground temperature never rose above freezing, and Mr. Luczak, having risked $75,000 on a quick judgment call, felt proud.
By Sunday, according to most news estimates, US Airways was trying to help 100,000 fliers stranded systemwide. Those in Pittsburgh's and Philadelphia's control towers directed planes to the sky, ensuring that they'd take off -- per federal regulations -- within six minutes of receiving the de-icing treatment.
But Pittsburgh, in part due to Mr. Luczak's pre-emptive decision to treat the runways with chemicals, faced no problems of its own. The treatment process, Mr. Luczak said, "helped us out all weekend."
"Philosophically," he said, "I knew I did good. Even if it had gone the other way, I knew I made the right decision. ... Nobody said anything to me or anything like that. It was just, you know -- I was proud -- especially because I went against the grain."
Pittsburgh International Airport lover
steeler83
RE: PIT Ranked 9th Overall In On- Time Departures
Tue Mar 27, 2007 1:11 pm
Nice post. It really did not bash PHL like I thought it would. (You know how those PHL loyals hate how some of us talk smack on their airport... It has the people, just not the best facility. The way it seems, the majority of the airports in the northeast handle mroe traffic than what they were designed to handle.
There is this whole gate swap thing taking place so that US can continue to expand Europe service. I don't see international expansion out of PHL ending anytime soon really. Which County benefits from having the airport, Delaware or Philadelphia? PHL kinda straddles the county line. According to the NWS weather site, the airport is in Delaware County, but that could be where the weather sensing equipment is located...
Anyway... oh my... This is a PIT thread, and I just made a post about PHL... Irony?
OKAY... I have used this argument numerous times though, saying how delay prown PHL is, and how PIT has the space. All I can say is, beware of those who may  flamed  you man... But then again, it's really not an A vs B, PHL bash bit to make PIT look better IMO...
Do not bring stranger girt into your room. The stranger girt is dangerous, it will hurt your life.
luketenley
Tue Mar 27, 2007 1:20 pm
Just copied the info from the Post Gazette. If they want to bash me, they really have no reason.
steeler83
Tue Mar 27, 2007 1:30 pm
Quoting Luketenley (Reply 2):
Been there done that man. I want PIT to grow as much as anyone. There are people who are so wrapped up around PHL that if anyone says anything REMOTELY degrading about PHL, they go completely ballistic, as if we've broken one of the Ten Commandments and have been condemned to hell...
I made one statement about PHL just for the sake of comparing a couple of airports, and I practically had me head chewed off...
luketenley
Tue Mar 27, 2007 1:36 pm
Quoting Steeler83 (Reply 3):
This will get me flamed, but its because Philly people suck!! I have not met one nice one yet. And listening to what people at the airport say about how rude and careless they are.
steeler83
Tue Mar 27, 2007 1:46 pm
Quoting Luketenley (Reply 4):
Euhhh... was I given a cue to laugh???
luketenley
Tue Mar 27, 2007 1:50 pm
Quoting Steeler83 (Reply 5):
HAHAHA maybe!
steeler83
Tue Mar 27, 2007 2:01 pm
Quoting Luketenley (Reply 6):
HAHAHA maybe!
I am getting the sense that this is becomming nothing more than a non-private AIM conversation of how we're hoping that PIT traffic will increase. I am having my chuckles over this whole thing though. Hopefully other folks will chime in, and hopefully the PHL lovers will not bash us for bashing PHL. If I really wanted to do that, I could spend my free time away from West Chester, go by some spraypaint at a hardware store, and spraypaint, "PHL sucks" all over the facilities for all I care, but I don't.
I have been though PHL, and honestly, I don't know which was worse... the PHL B C D and E concourses, or how dark, drab, and little the old PIT terminal was. That thing only had 55 gates or so, while the new terminal has 75 gates in use... It used to have 97 when the E (commuter) concourse was fully operational.
Heck, those ceilings were so low, that if they were any lower, I might as well be Bilbo Frodo Baggins, or some other short person
luketenley
Tue Mar 27, 2007 2:06 pm
Quoting Steeler83 (Reply 7):
If the ACAA would've known then that the traffic would've decreased this much, the new terminal would've never been built like it is. A new terminal would be there but nowhere near the size of what it is now. I wish the old building was still there!
And I'm sure when the sun comes up, all the sleeping a.netters will be on here reading all these. We are just the night owls!
USPIT10L
Tue Mar 27, 2007 4:34 pm
As well it should be. PIT is, hands down, one of the best airports in the country, period. On-time, space, shopping, lack of ground delays. Any way you slice it, PIT rules for airline operations! Too bad other airlines haven't gotten the message to add flights or start service here. Look at DEN and DTW and how much they have grown since their new terminals opened. Meanwhile, PIT builds a brand-new super-terminal and what happens almost ten years later, the hub airline up and leaves! Just our luck, isn't it friends?
It's a Great Day for Hockey!
steeler83
Wed Mar 28, 2007 6:20 am
Quoting USPIT10L (Reply 9):
Yeah, well as our pal ScottB in the other thread about US possibly adding flights back, the hub was closed for many reasons. I didn't know that WN's buildup of BWI was a factor that sent a ripple effect into US' operations throughout the Northeast...
