Impacto
Do Continental Use Their 777s On Domestic Routes?
Tue Apr 17, 2007 2:50 am
I am aware of the fact that AA, UAL, and DL use their 777s on domestic routes especially to KLAX from their respective hubs. What about Continental? If not, why?
ikramerica
RE: Do Continental Use Their 777s On Domestic Routes?
Tue Apr 17, 2007 3:10 am
Not in recent months. Occasionally it will go on EWR-IAH once a day for repositioning, and once in a while it's actually scheduled for that route for a week or two.
When the type was new, they flew them domestically more, including IAH-LAX. Those were the days.
IAHFLYR
Tue Apr 17, 2007 3:15 am
CO has and will from time to time put a B772 from IAH-EWR around 1045 A.M. and from EWR-IAH around 315 P.M., most of the year those flights are either a B762 or B764.
Reasons they don't run the B772's much in the domestic U.S. routes, I would think is due to the lack of them and they're needed to support the longer international routes.
Keep in mind CO is taking delivery of only their 20th B772 on Tuesday, April 17th, yes tomorrow!
flynavy
Tue Apr 17, 2007 3:19 am
They flew them to MCO back in the late 1990's for route proving/crew training.
Change is: one airline, six continents!
curticool
Tue Apr 17, 2007 4:59 am
It Seems To Short Given The Large Quantity Of 738'S That CO Has
N102DA
cba
Tue Apr 17, 2007 5:14 am
When they do, it is for repositioning or because the aircraft is going to be on the ground for long periods of time waiting for another intl. flight. Same strategy applies for the 764 and 762, which is why you'll see them on IAH-EWR runs.
phoenixflyer
Tue Apr 17, 2007 8:38 am
When looking for flights back home from EWR to PHX i noticed the T7 is being used for a least a few days on the EWR to IAH route in mid August. Usually that route is 738.
tbear815
Tue Apr 17, 2007 9:40 am
Where is CO's principal maintenance base for the T7's?
tsnamm
Tue Apr 17, 2007 9:45 am
CO's T7 is usually only run domestically anymore as part of a one stop IAH/EWR/somewhere in Europe...there's not enough revenue to use T7's for anything but long haul Intl...
drerx7
Tue Apr 17, 2007 9:54 am
Quoting Tbear815 (Reply 7):
Well more 777s run out of EWR. Here at IAH we have em to EZE (certain frequencies), CDG, and LGW. Occasionally the 777 will run a swap to EWR or as a continuation to/from EZE when its on that run (EWR-IAH-EZE-IAH-EWR). I personally have flown them IAH-LAX-IAH and IAH-EWR-IAH. Remember they also flew IAH-HNL as CO1/2 for the longest time (I think the aircraft switched down to 764 @ HNL for the continuation to GUM--not sure if the 777 continued all the way there-don't think so though).
HOUSTON, TEXAS
sammyk
Tue Apr 17, 2007 9:55 am
A few months ago I had a 777 on a EWR-IAH flight. The flight was later headed to Argentina.
LAXspotter
Tue Apr 17, 2007 9:57 am
Quoting Drerx7 (Reply 9):
You missed IAH-NRT, but recently atleast as of this year, i dont recall CO domestic T7 flights.
"Patriotism is the last refuge of the scoundrel" Samuel Johnson
iahcsr
Tue Apr 17, 2007 10:33 am
A and B Checks done at EWR and IAH. C and D are done at HKG.
tercer
Tue Apr 17, 2007 11:01 am
Quoting Impacto (Thread starter):
The longer a 777 is in the air the more money it makes so scheduling it on domestic legs, while being able to move more people, will loose money since the airplane is designed to fly for more than 15 hours.
It's politically sensitive, but it's going to happen.
c0ex
Tue Apr 17, 2007 11:14 am
Looks like it isnt flying to the IAH-EWR leg anytime soon. There is currently 762, 752, and mix of 737's flying that route now.
theRightchoice
STT757
Tue Apr 17, 2007 11:58 am
CO needs to keep their widebodies flying International Long Haul flights, to support domestic capacity CO needs to acquire additional 757-300s.
Starting with the four remaining 757-300s at ATA, and some additional 757-300s flying for European charters or Akira.
centrair
Tue Apr 17, 2007 12:09 pm
So the majority of CO's T7s are rotated through international destinations like NW does with their 747s and A330s?
My name is Centrair but HND is closer. Let's Japanese Aviation!
drerx7
Tue Apr 17, 2007 12:51 pm
Quoting Centrair (Reply 16):
All of them are flying internationally. IF you see a domestic 777 it'll be on the IAH-EWR run.
HOUSTON, TEXAS
ikramerica
Tue Apr 17, 2007 1:19 pm
Quoting Phoenixflyer (Reply 6):
No, it's an every plane but 777 route, usually. They fly 757s and 762s on the route as well as 737s, and sometimes ERJs!!
Quoting C0ex (Reply 14):
That's standard. The 777 can be subbed in (to reposition after maintenance, when a 762 goes tech, or a 777 has gone tech and is sitting idle after being fixed, etc..)
And as noted about, there are occasions where they do schedule the 777 on the route in advance, but it's not at all regular.
nwa757boy
Tue Apr 17, 2007 1:26 pm
Quoting Ikramerica (Reply 18):
I've NEVER seen the ERJ between IAH-EWR. I thought there was a clause somewhere in the CAL ALPA that states only CAL planes and pilots can fly between hubs.
The only time I've been on a 777 was a deadhead from IAH to EWR...
drerx7
Tue Apr 17, 2007 1:34 pm
Quoting NWA757boy (Reply 19):
There is that clause; however, there are some flights that are through flights with stops in intermediate cities (they don't come up for sale but I believe they do if you are redeeming OnePass rewards online) so IAH-XXX-EWR for example with the same plane.
HOUSTON, TEXAS
EWRCabincrew
Tue Apr 17, 2007 4:25 pm
They don't go non-stop, but they do go EWR-IAH through secondary cities like RIC, IND, STL and the like.
You can't cure stupid
centrair
Tue Apr 17, 2007 4:31 pm
Quoting Drerx7 (Reply 17):
I will clarify.
NW rotates all their widebodies at the outerstation and then at the hubs in the US. NO Domestic Widebodies (except MSP-HNL)
IE: A333 flies DTW-AMS-BOS-AMS-MSP
Could say CO fly EWR-Foreign Airport-IAH-Foreign Airport-EWR to rotate their T7s?
EWRCabincrew
Tue Apr 17, 2007 4:44 pm
Quoting Centrair (Reply 22):
Our T7 cities commonly served from EWR and IAH are NRT, LGW and CDG. The T7s are sometimes rotated out there, too. EWR-CDG-IAH or IAH-NRT-EWR and so on.
cba
Tue Apr 17, 2007 5:55 pm
Quoting EWRCabincrew (Reply 21):
 checkmark
If you plug in a ticket for IAH-EWR on CO and scroll to the bottom, sometimes you'll see these options. I've seen IAH-RIC-EWR among others as potential itineraries, however they usually come up as more expensive when compared to the multiple obvious n/s flights.
iahcsr
Tue Apr 17, 2007 11:05 pm
Quoting EWRCabincrew (Reply 23):
Normal/Standard routings are EWR-NRT/LGW-IAH (and reverse of course). Arrival/Departure times don't allow for this though CDG.
STJ
Wed Apr 18, 2007 12:16 am
NW will ocassionally run a repo of a 330 between DTW and MSP but never has pax although I did see a Non-Rev on one of them once.
nwa757boy
Wed Apr 18, 2007 12:29 am
I am aware of the through flights, but I was talking nonstop between IAH-EWR, sorry i wasnt specific.
airplanenut
Wed Apr 18, 2007 1:29 am
If I recall correctly, quite a while back, the Tokyo run was actually BOS-EWR-NRT-EWR-BOS, which let you take a 777 on a <200 mile flight.
Why yes, in fact, I am a rocket scientist...
MEACEDAR
Wed Apr 18, 2007 2:34 am
I flew EWR-IAH on a CO 777. This was about 6-7 months back.
drerx7
Wed Apr 18, 2007 6:57 am
Quoting Airplanenut (Reply 28):
The 777 wasn't used on EWR-BOS but the flight number may have continued on to NRT.
HOUSTON, TEXAS
ikramerica
Wed Apr 18, 2007 7:02 am
Quoting MEACEDAR (Reply 29):
It happens. It's just not regularly scheduled like the 762 is.
N1120A
Wed Apr 18, 2007 7:03 am
Quoting Tercer (Reply 13):
Um, the 772ER's average flight length is significantly shorter than 15 hours and it makes money on plenty of shorter routes.
Norcal773
Back in 2002, I flew CO's 777 IAH-EWR but I believe the flight was continuing on to FRA and a lot of pax never got off the plane at EWR. That was my first T7 flight so I was quite excited.
If you're going through hell, keep going
airportugal310
Wed Apr 18, 2007 11:29 am
Quoting Drerx7 (Reply 30):
I wanna say that this was Continental 1180....but I could be wrong
I sell airplanes and airplane accessories
drerx7
Wed Apr 18, 2007 11:43 am
Quoting AirPortugal310 (Reply 34):
The 777 definitely wasn't used on the BOS-EWR leg.
HOUSTON, TEXAS
usairways85
Wed Apr 18, 2007 11:51 am
I've seen a CO 772 in MCO, in fact it was petermax. However that was 3 years ago. With more international expansion since then i would suspect as many people have that the 772's mainly fly international
tercer
Wed Apr 18, 2007 6:56 pm
Quoting N1120A (Reply 32):
Um, ok so how about you back that statement up with some data showing that airlines utilizing the 777 on domestic flights turn a profit on the on those routes.
Norcal773
Wed Apr 18, 2007 9:21 pm
Quoting Tercer (Reply 37):
He never said anythign about domestic fligths making profit! He said shorter than your 15 hours which doesn't mean domestic. As a matter of fact, not too many routes a 772ER is operated for more than 15 hours as you claimed. Name 5 routes that a 772ER flies for more than 15 hours. Even better, how about you back your first statement up first before asking N1120A to back his up!
