MaverickM11
Who Will Fly An A380 To MUC?
Fri Apr 20, 2007 9:24 am
Saw the pic of the A380 at MUC and wondered what routes to MUC are viable as an A380? LH rarely flies the 744 to MUC and TG probably has bigger fish to fry with their small 380 fleet.
E pur si muove -Galileo
Avianca
RE: Who Will Fly An A380 To MUC?
Fri Apr 20, 2007 9:35 am
I think we will see fore sure EK with the A380 in MUC
MaverickM11
Fri Apr 20, 2007 12:48 pm
Quoting Avianca (Reply 1):
Touché....I think the better question there is where won't EK fly the A380 Silly
FrancoBlanco
Fri Apr 20, 2007 3:53 pm
Quoting MaverickM11 (Reply 2):
To MUC.
It will be a long time until we see A380s regularly at MUC. LH will base all theirs at FRA (as with the 744, the 744 never flew a regular, scheduled flight out of MUC), TG is more than unlikely to upgrade and EK... well, just because EK will receive 45 A380s over the next years, doesn't mean that every single destination will get to see one. EK currently has two daily flights to MUC; the evening flight is always performed with their smallest equipment, the A332. The daytime flight is either a A343 or A332, but has recently been downgraded from a 772 which was used four times weekly.
So until the two existing flights won't be upgraded to a 772, 773, or 77W you should not consider the possibility of an EK A380 at MUC. Furthermore, MUC does not have slot problems - it would be easy to introduce a third daily flight, and Terminal 1 (where EK resides) did not receive special A380 gates AFAIK.
Sebastian
'Pointless!' - NY Times
stylo777
Fri Apr 20, 2007 6:15 pm
Quoting FrancoBlanco (Reply 3):
 checkmark
the one and only possible carrier in my eyes is LH which could perform some BKK, JFK, LAX flights out of MUC if at all..
mbj2000
Fri Apr 20, 2007 7:58 pm
Quoting Stylo777 (Reply 4):
Your words in LH's ears!  Smile Should LH put one on MUC - LAX or even better SFO, I will be one of the first to buy a ticket, finally a good reason to visit a friend in San Jose...  cloudnine
Like most of life's problems, this one can be solved with bending -- Bender Unit 22
Avianca
Fri Apr 20, 2007 10:00 pm
asking me why than EK self anounced that they will use the A380 on major routes like FRA, MUC,LHR etc...
SailorOrion
Fri Apr 20, 2007 10:26 pm
Wrong. LH did have MUC-LAX and MUC-SFO with 747s between 1999 and 2001.
There won't be any A380 flights into MUC for the time being, but some airlines might be sending it here later on. TG is one candidate for example. However, at least in Europe, MUC was the first airport to be certified for A380 operation (possibly owing to the fact that no runway/taxiway reconfigurations were needed).
SailorOrion
emirates777
Sat Apr 21, 2007 7:19 am
One A380 was allocated to operate the morning MUC flight however this has been switched over to Beijing (PVG).
In Germany Emirates will operate the one of the FRA flights with an A380.
Regarding EK @ MUC -- The morning flight switches to a B772/B773 from 1 Feb 2008.
Emirates777
