aio86
SAA Vs TAP On Flights To Southern Africa
Fri Apr 20, 2007 3:02 pm
I am looking into flights between the US and Southern Africa for this summer. As a Mileage Plus member, I am deciding between flying South Africa Airways on one of the non-stops from IAD. My other option is with TAP Portugal and flying direct from Lisbon. How is the Y service on both airlines with their A340s? I like the prospects of Lisbon because I can break up the trip with a day in Lisbon (I'm looking at an 8:30am arrival from the US and an 11pm departure out again; I like that especially compared to a 4-8 hour layover in LHR, FRA or ZRH) but also the possibilities of upgrading myself with TAP using United miles (which is not possible with SAA). Thoughts? Thanks!
Flying Belgian
RE: SAA Vs TAP On Flights To Southern Africa
Fri Apr 20, 2007 3:22 pm
Do bear in mind that TP LIS-JNB flights are not always non-stop. I'm pretty sure that the JNB-LIS leg stops in Maputo.
FB.
Life is great at 41.000 feet...
lxlgu
Fri Apr 20, 2007 3:34 pm
Hi!
Bear in mind it will be a 346 on SAA with great service and a good entertainment program
I would say go for SA as the nonstop is so much quicker
As FB said TP could be via Maputo one way
Due to JNB altitude the ac cannot reach US nonstop so flight is via Dakar
Cheers!
Tony
swissgabe
Fri Apr 20, 2007 4:35 pm
Quoting Flying Belgian (Reply 1):
TP does have both options, flying LIS-JNB-MPM-LIS and/or LIS-MPM-JNB-LIS. So basically you could fly LIS - JNB - LIS on both ways nonstop.
Quoting Lxlgu (Reply 2):
Quoting Aio86 (Thread starter):
SAA doesn't fly nonstop from IAD to JNB but direct with a stop in DKR on both ways.
I would still opt for South African Airways as from WAS they use the 346 which is a very good product (not only in Business).
Smooth as silk - Royal Orchid Service /// Suid-Afrikaanse Lugdiens - Springbok
lxlgu
Fri Apr 20, 2007 4:53 pm
Hi Swissgabe
SAA do fly nonstop now Washington Johannesburg sector only
Flight time 15h 15 min
Cheers!
Tony
Dirkou
Fri Apr 20, 2007 5:19 pm
If you want bad service, 1 stop in the way, an outdated airport in Lisbon and old flights attendants (in fact Air Portugal on long haul only has 40+ flight attendants due to union agreements) take TAP Portugal. If you want a world class airline then SAA is the way to go.
TAP1972
Fri Apr 20, 2007 7:23 pm
Quoting Dirkou (Reply 5):
Well you can see good looking 30 - flight attendants in the long haull flights of TAP.
I would take TAP if you upgrade to business class. The A340's of TAP are quite old so in economy class you won't have PTV's for example. In that cas going in Y class on a A346 might be better. If you upgrade to business class in TAP, then you'll have a flat bed, good food, good wine and entertainment. Plus you would be able to visit Lisbon
Umhlanga
Fri Apr 20, 2007 9:16 pm
SAA are doing IAD-JNB nonstop. But I recall that when they announced that nonstop flight several months ago, SAA mentioned that they would not fly IAD-JNB nonstop during the northern hemisphere summer, due to heat-imposed fuel load restrictions. The SAA timetable does not reflect this, so perhaps SAA have decided that it is possible to fly the route nonstop even with the Washington summer heat. Can anyone else shed some light on this?
Umhlanga
CV990
Fri Apr 20, 2007 9:54 pm
Hi!
Even if "breaks my heart" I think you'll be better with SAA!!! They fly with the Airbus 340-600 and TP is still flying with the good old 300 model ( but the 312 one, not the 300E or 313X ), no PTV's....screens TV style all around the cabin but.....the TP crews are usually nice, they will serve you nice meals and nice wines/spirits too!!! If you look to your "aviation side" with TP you can stop at MPM and see some pretty unusual airplanes!!! But you will decide wisely!
CV990, the Maserati of the skies!
tiago701
Fri Apr 20, 2007 10:17 pm
Just for the chance of spending the day at beautiful Lisbon i think it's worth flying with TP to JNB.
The only days TP flies nonstop to JNB is Thursdays and Fridays but this departs at 18:45 and 19:05 respectively and not at 23:00. Tuesdays and Saturdays it departs at 23:00 but stops in MPM. All the return flights to LIS from JNB stop in MPM.
I never flew SAA but i think if you can upgrade to Business with TP and spend the day in Lisbon i wouldn't think twice! Just my opinion.
tiago701
Fri Apr 20, 2007 10:28 pm
By the way, if you decide to book TP (flying from EWR) try to get the flight that arrives in LIS at 6:05 am (TP104) as this is an A330 with a much better economy cabin (with PTVs) than TP106 (arriving at 8:35 am) which is an old A310 with a much worse cabin.
airbazar
Sat Apr 21, 2007 12:14 am
I'm basically just reiterating what everyone already said. For inflight ammenities and shorter trip time, fly SAA. But if you wish to visit Lisbon and break up your trip, fly TP. LIS is right in the city so you can be just about anywhere you want within minutes of landing. It's a small airport so the security lines are short and quick and basically means you don't have to get back to the airport until maybe an hour before your flight. That gives you almost an entire day at LIS to do whatever you want to do. You may even spend the day at the beach if you want to. Just hop on a train to Estoril/Cascais, spend the day at the beach, eat a nice seafood lunch by the water, then get back on your flight JNB  bigthumbsup
sandrozrh
Sat Apr 21, 2007 12:20 am
I like that especially compared to a 4-8 hour layover in ZRH)
How come? ZRH is a modern, clean and comfortable airport, and the city can be reached within 15mins by train directly from the airport.
But hey, whatever makes you happy Big grin
CV990
Sat Apr 21, 2007 2:58 am
Hi!
I agree with SandroZRH regarding ZRH and the city! I was at Kloten just 3 weeks ago and the airport is still one of my favourites, they have the terrace on B terminal were you spot the airplanes quite good with a nice Snack-Bar too, also they have the BuchAir shop with lot's of good stuff to buy. And regarding Zurich itself, it's a very cosmmopolitanean city, with awesome shops, great sights by the Zurich Lake and in a mere 15 minutes by train......but Lisbon is also a great place to visit, maybe a bit longer to get down town and you have to be aware of the rush hour...it can be really disturbing if you don't program well your visit, and you might lose you flight then!!!
Flying Belgian
Sat Apr 21, 2007 4:31 pm
And it's an American who gives such a lesson ??
You need to see cute girls on board to compensate your home frustrations maybe ?
What a silly and childish comment...
FB.
