B752OS
BOS-MSY Service
Tue Apr 24, 2007 4:34 am
I was wondering why there is no non-stop service between BOS and MSY. It seems that MSY is one of the last major cities in the United States that BOS does not have non-stop service to. AA used to fly the route on a seasonal 7 month basis, but after Katrina, it never returned. I am surprised that B6 has not stepped up and started a daily non-stop flight using a 190, especially when you consider BOS is a major focus operation for them.
MSYtristar
RE: BOS-MSY Service
Tue Apr 24, 2007 4:43 am
AA did very well with its BOS-MSY service; in fact, I believe it was going year-round before Katrina, or at least extending the service for a couple of more months. The flights generally went out with 100+ pax everyday.
There has been constant talk about B6 starting BOS-MSY with the E90's, and I thought for sure it would happen when the airport annouced its new incentive plan....but, it didn't.
While the airport has "most" of its nonstop destinations back, some big names are still sadly missing, with Boston and San Francisco leading the pack.
ConcordeBoy
RE: BOS-MSY Service
Tue Apr 24, 2007 5:21 am
Quoting MSYtristar (Reply 1):
and San Francisco
...or the Bay Area in general. Also add IND to that list.
Aside from them; SEA, PDX, and CMH were essentially the last major metros to not have a nonstop to this area. Sad  Sad
MSYtristar
RE: BOS-MSY Service
Tue Apr 24, 2007 5:26 am
Quoting ConcordeBoy (Reply 2):
And PIT...and SAN...
walter747
RE: BOS-MSY Service
Tue Apr 24, 2007 6:10 am
Quoting MSYtristar (Reply 3):
No and No.
PIT by US
SAN by AA and B6 starting June 28
SEA is by B6
CMH by AE
PDX starting September 9 on AS
Hussel, Hussel, Husel, Grind, Grind, Grind
MSYtristar
RE: BOS-MSY Service
Tue Apr 24, 2007 6:15 am
Quoting Walter747 (Reply 4):
No and No.
I was talking about service to those cities from New Orleans...
walter747
RE: BOS-MSY Service
Tue Apr 24, 2007 6:35 am
Quoting MSYtristar (Reply 5):
Oh i got confused for a second. I thought you meant BOS.
Flighty
RE: BOS-MSY Service
Tue Apr 24, 2007 6:40 am
Quoting Walter747 (Reply 6):
I was gonna say, B6 SAN-MSY, oh man, we have another AirTran on our hands!!
ScottB
RE: BOS-MSY Service
Tue Apr 24, 2007 6:44 am
Quoting B752OS (Thread starter):
I suspect that part of the problem is that BOS-MSY traffic (as of 06Q3) fell dramatically in the wake of Katrina; it's just barely over half of pre-Katrina levels at relatively modest yields which are less than 2% higher than the pre-Katrina quarter (05Q2). Even if B6 were to enter the market non-stop, there's not a lot of room for low-fare stimulation when you compare to the yields they're seeing for BOS-AUS. Moreover, B6 may also be depending on some connecting traffic from BOS to make the JFK-MSY flights remain profitable.
I don't doubt that we would have seen B6 fly BOS-MSY but for Katrina.
MSYtristar
RE: BOS-MSY Service
Tue Apr 24, 2007 6:57 am
Quoting ScottB (Reply 8):
That doesn't surprise me, seeing as how the convention and tourist industry is still suffering big time down here.
On more than one occassion B6 folks told me that JFK-MSY was going to go to the E90's, but at the last minute B6 decided to keep the 320's on the route.
ScottB
RE: BOS-MSY Service
Tue Apr 24, 2007 7:12 am
Quoting MSYtristar (Reply 9):
I'd guess that there's the issue of yields versus CASM on JFK-MSY; they could reduce gauge to the E190 to try to improve RASM (flying with fewer empty seats and less reliance on connections), but that would increase CASM. There's not a lot of room for them to raise fares to compensate, since NYC-MSY is pretty competitive. But even if B6 went to the E190 on JFK-MSY, I still think they'd have trouble filling BOS-MSY on a consistent basis -- especially on the low-traffic days -- and there are almost no connections to help fill planes out of BOS.
MSYtristar
RE: BOS-MSY Service
Tue Apr 24, 2007 7:22 am
Quoting ScottB (Reply 10):
I think you're right... I don't think filling a 190 on a daily basis would be possible right now. It would be a perfect route for XE, for example, if they ever started BOS service, with the ERJ-145XLR's. I even think it could be a good Delta Connection route with the E70, and that may not be totally out of the loop down the road due to DL's increasing BOS presence. Unfortunately it seems to be too thin of a market for anything bigger than a 70 seater right now.
SANFan
RE: BOS-MSY Service
Tue Apr 24, 2007 7:38 am
and SAN...
The 3Q06 DOT figures place SAN-MSY at 159 O&D pax/day which is not too bad but probably not ready for a n/s yet; WN would be the logical cx to do it and we know how it's going between WN and MSY lately... I would certainly like to see it happen (for the sake of both cities.)
I do agree that B6 would be the expected provider of MSY-BOS service but as Scott so well put it
bb
MSYtristar
RE: BOS-MSY Service
Tue Apr 24, 2007 7:46 am
Quoting SANFan (Reply 12):
I wonder how much traffic has declined in the market since Katrina? Maybe when it gets over that 200 mark we'll see a nonstop again.
Likewise....
ConcordeBoy
RE: BOS-MSY Service
Tue Apr 24, 2007 8:01 am
Can you link me to where you derived these figures? Thnx in advance.
ScottB
RE: BOS-MSY Service
Tue Apr 24, 2007 8:36 am
Quoting ConcordeBoy (Reply 14):
DOT's Consumer Air Fare Report. The tab-separated data tables are:
3Q06: http://ostpxweb.ost.dot.gov/aviation/domfares/tab6063.txt
2Q05: http://ostpxweb.ost.dot.gov/aviation/domfares/tab6052.txt
Actually, I just looked at the 2Q06 numbers -- they're a little bit better than 3Q06 (~15% higher traffic on ~8% higher yields) probably due to seasonality; I assumed that 3Q would be better than 2Q given that the degree of post-disaster recovery ought to increase over time. But even the 2Q06 numbers are around 40% below the 2Q05 numbers for traffic.
ConcordeBoy
RE: BOS-MSY Service
Tue Apr 24, 2007 9:37 am
...preciate it  thumbsup
B752OS
RE: BOS-MSY Service
Tue Apr 24, 2007 9:45 am
I wonder if a non-stop flight would create better numbers between BOS-MSY?
ConcordeBoy
RE: BOS-MSY Service
Wed Apr 25, 2007 4:03 am
Quoting B752OS (Reply 17):
Possible, but fare's aren't all the high between the two cities currently... so it wouldn't be through prices stimulation, more along the lines to catering to a specific O&D; which may or may not be there right now as NOLA's worldwide image spirals further down the crapper.
