BHD
How Acurate Is Flightaware.com
Wed May 02, 2007 11:38 pm
I all
I was wondering if anyone has had any problems with flightaware.com before, of have they found it to be acurate most of the time. I think it is a brilliant piece of software and all credit goes to the developer(s). Yesterday, (Tues), GSM825 from BFS-SFB was recorded has having flown as a 767, however, their fleet listing currently shows no active 767s due to their lease at Air India. Has flightaware.com recorded yeserday's flight acuratly?
Many thanks
Woody
RobK
RE: How Acurate Is Flightaware.com
Wed May 02, 2007 11:43 pm
There's nothing wrong with flightaware, it's Globespan's website that's the issue.
Globespan have 2x 767s :
G-CDPT (had it for over 12 months)
G-CEFG (had it for over 6 months)
Presumably one or both of them are back from AIC lease.
R
[Edited 2007-05-02 16:45:31]
bond007
Wed May 02, 2007 11:45 pm
It's as good as the data it gets from the FAA ... which originates initially from the flight plan.
Jimbo
star_world
I've yet to see an error on it - aside from map errors on international flights that are outside its coverage area. It gets its data directly from the FAA systems, so assuming the flight plans, etc. are filed correctly there it should translate into accurate coverage.
RobK
Wed May 02, 2007 11:48 pm
Further to my post above, if they're both still with AIC then what about one of the NOS aircraft listed on the page you refer to? I doubt that the type was NOT a 767, although it does occasionally happen that the wrong aircraft type is filed in flight plan system.
R
BHD
Wed May 02, 2007 11:55 pm
Quoting RobK (Reply 4):
Thanks for all replies so far... this is what i had thought also, althogh they weren't expected from middle of May.
Thanks again
Woody
RobK
Wed May 02, 2007 11:57 pm
My contact at GLA says it was G-CEFG, so presumably this one hasn't gone to AIC for the Summer after all, or at least not yet anyway.
R
BHD
Thu May 03, 2007 12:20 am
Quoting RobK (Reply 6):
Thanks RobK - the following site also has recent photos of G-CEFG still operating for GSM. This is a twist as up until now, other posts on this site have assumed both 767s have been at Air India. Seems this isn't the case - thanks for the help, it is much appreciated.
Woody
