aal151heavy
Air Canada 767-200 At SJC Today - What Happened?
Thu May 03, 2007 12:10 pm
An Air Canada 767-200 (flight AC 757) came into SJC late this morning and left about 3 hours later to its final destination of SFO. Anyone knows what happened?
http://flightaware.com/live/flight/ACA757
Interesting thing was all the flight trackers (including AC's own website) showed "arrived" at SFO at 11 am when in fact it was at SJC.
Friend working at the airport said it went to the cargo ramp - it didn't even go to a gate.
Ben
My airliners.net photos
RP TPA
RE: Air Canada 767-200 At SJC Today - What Happened?
Thu May 03, 2007 12:23 pm
It was due to "extensive ATC holds" at SFO. Arrived SJC 1203, departed 1346 and arrived SFO 1410.
Apparently there were low ceilings at SFO. The morning YVR-SFO flt (AC560) was delayed 1hr30, but that was mostly due to a late departure from YVR, awaiting a "wheels up" slot time. At least it wasnt stacked up like the YYZ arrival.
Must have been a fun mornng for United!!!  sarcastic
stealth777
Thu May 03, 2007 1:43 pm
I was at the SJSU campus and my classmates and I was very surprised when we saw this bird come in. After it landed it was parked over by FedEx area. I am surpised to see the schdule from AC that they have the one 767 flight but the remaining flights appear to be 319 aircrafts. Seems they have limited seats for the route to YYZ from SFO. I remember they used to to have a 767 as one flight and the other flights were 320's.
YYZ-SFO
Flight Aircraft Departure Arrival Travel Time Stops Via
AC 5659 319 07:25 09:46 5 hr 21 mn 0
* AC5659 OPERATED BY/EXPLOITE PAR/UA-UNITED AIRLINES
AC 757 767 08:50 11:15 5 hr 25 mn 0
AC 755 319 15:40 18:05 5 hr 25 mn 0
AC 759 319 20:45 23:10 5 hr 25 mn 0
SFO-YYZ
AC 758 319 07:00 14:50 4 hr 50 mn 0
AC 5660 319 10:45 18:32 4 hr 47 mn 0
* AC5660 OPERATED BY/EXPLOITE PAR/UA-UNITED AIRLINES
AC 756 767 12:35 20:25 4 hr 50 mn 0
AC 754 319 22:25 06:13 +1 4 hr 48 mn 0
yyz717
Fri May 04, 2007 1:48 am
AC has added the 762 back to some YYZ-SFO/LAX skeds recently, for the initial morning flights out of YYZ. Likely for connecting UA flights to Asia. I have not looked forward enough in the schedules to see how long this will last.
I dumped at the gybe mark in strong winds when I looked up at a Porter Q400 on finals. Can't stop spotting.
aa61hvy
Fri May 04, 2007 5:48 am
Quoting Yyz717 (Reply 3):
AC flies a lot of the same routes from YYZ as UA does from LAX. (Asia specifically)
Go big or go home
FLYACYYZ
Fri May 04, 2007 6:46 am
767's operate the YYZ/SFO run until May 31st inclusive on AC757/756
767's will operate the YYZ/LAX run from July 1st - September 2nd on AC791/792.
Mainly 762's with the occasional 763 on both of the above services.
Above and Beyond
stealth777
Fri May 04, 2007 1:14 pm
I find it strange that they would use a 767 on the SFO until May31, as the summer season kicks off after June 10th when they would want the increrase in capacity. The timing for LAX is ideal, the SFO does not.
n53614
Fri May 04, 2007 7:59 pm
Damn, too bad I missed it! Didn't even know Air Canada flew B767s to SFO...all I see are A319s/A320s.
B722 B732 B733 B734 B735 B73G B738 B739 B742 B752 B763 B772 A319 A320 A332 CRJ2 DHC8 DH8D E135 E140 E145 MD83
FLYACYYZ
Fri May 04, 2007 8:24 pm
I suspect that the 767 is a substitution aircraft while several narrow bodies are undergoing "XM" refurbishment.
Quoting Stealth777 (Reply 6):
There is a substantial capacity increase on the YYZ > SFO route during the summer schedule. There is an upgauge from 3 to 5 daily flights offering at least 200 extra daily seats on the route.
Above and Beyond
gilesdavies
Sat May 05, 2007 12:15 am
Quoting N53614 (Reply 7):
I was on AC756 yesterday (Thursday) and the flight was 100% full in Economy and First. It was operated by a 762 and was a very nice ride!
There were many unhappy passengers, as at boarding their was not enough space for roll-ons on and were making people leave them at the boading gate to go into the hold. The poor cabin crew got a right roasting from some passengers... Those overhead lockers on the 767-200's they operate are simply not big enough with todays hand baggage requirements.
Sorry, didn't get the number...
ATCGOD
Sat May 05, 2007 12:33 am
Quoting RP TPA (Reply 1):
Sounds like someone in flow control screwed up. That's a big error on someone in Oakland ARTCC's fault.
yyz717
Sat May 05, 2007 1:27 am
Quoting FLYACYYZ (Reply 5):
Thanks for the clarification Rod.
Quoting AA61Hvy (Reply 4):
You are correct Ryan. However, AC is currently running tight on wide-bodies (at least according to on-going discussions on this board) so they are ill-prepped to add more Asia flights. Perhaps the rationale is too feed the excess to their Star Alliance partner UA. The daily morning YYZ-SFO 762 is an upgrade from the 321, and flies (almost) parallel with a UA 319 on the same route, so the demand is there for Star Alliance YYZ-SFO. If UA cannot afford a spare 752 for this route, AC perhaps could respond with the 762.
Quoting Gilesdavies (Reply 9):
People need to travel lighter.  Smile
longhauler
Sat May 05, 2007 1:31 am
Quoting ATCGOD (Reply 10):
In my opinion, SFO is like PHX and LAS, in that they handle an incredible about of traffic when Visual approaches are warranted .... but .... slow down to a snail's pace when put in minimum IFR conditions. Not much any one can do when the weather decides to throw a monkey-wrench into things.
I have come close to diverting from SFO many times when this happens. Its a shame when it finally does happen!
timeair
Sat May 05, 2007 2:12 pm
Well, too bad for the passenger! There is way too much crap people feel is essential to take on an aircraft, and if the person travelling originated in another country, or with another carrier, one would think they would have checked on what the carry on restrictions are for each carrier they are scheduled to travel, and planned accordingly. I get sick of seeing some of the crap people try to take onboard an aircraft, saying "it is very essential".
Pack a change of clothes, a toothbrush and buy the rest at the other end!!!!!!!!
If you can't grasp the reality of there is limited space in an aircraft, and the carrier is looking out after "your" safety, please, please next time take a bus and save the rest of us the headache of hearing you whine and snivel as they place your article in the bulk pit below !! (not directed at Gilesdavies directly)
You can't get there from here.
hawaiian717
Sat May 05, 2007 4:13 pm
Quoting LongHauler (Reply 12):
SFO's parallel runways are too close together. In visual conditions they can do simultaneous approaches to both runways; typically, 28L/R for arrivals and a few heavy departures, with most departures on the intersecting parallels 1L/R. However, when the weather gets bad (which isn't all that common with San Francisco's reputation for fog), only one of the pair can be used, and as a result the airport's runway capacity is cut in half.
TropicBird
Sun May 06, 2007 1:27 am
For those interested. AC has also been overnighting an EMB 190 in SFO.
ATCGOD
Sun May 06, 2007 2:20 am
That's what flow control's job is, to keep airliners on the ground so congestion doesn't happen at airports during bad weather.
bmacleod
Sun May 06, 2007 3:24 am
Frequency seems to be the reason AC switched to 319/320s on YYZ-SFO and YYZ-LAX. Nice to see the 767 coming back to SFO after 15 years.
Photo © Mark Durbin
"What good are wings without the courage to fly?" - Atticus
chris133
Sun May 06, 2007 3:28 am
Or people justtry to bring to much stuff and are not curtious to their fellow passengers (i.e putting a jacket or briefcase in the overhead bins)
gilesdavies
Sun May 06, 2007 3:41 am
Quoting Chris133 (Reply 18):
Quoting Yyz717 (Reply 11):
It was just a flipant comment I put into my original thread, which I had noticed about the 767 when flying between SFO-YYZ-LHR... I did NOT have a roll-on with me...
As I had travelled from the UK originally, there was simply no way I was aloud to take that hand baggage with me into the cabin. All I had was a laptop, travel documents and MP3 player.
chris133
Sun May 06, 2007 6:35 am
Quoting Gilesdavies (Reply 19):
Oh its ok nothing wrong with carrying a bag on, as long as you are mindfull of others and put the smaller one under the seat and don't put things like jackets and small bags in the bins untill the roller bag are in there. People just don't seem to get it that there is space on-top of them in the end (but thats a different thread)
as739x
Sun May 06, 2007 6:45 am
Actually guys the reason for the 767 for one month is cargo. In particular its cherry season. The asian carriers also increase flights for this time. Iv'e personally seen China Airlines Cargo 747's loaded with half the cargo being cherries.
ASSFO
FLYACYYZ
Sun May 06, 2007 7:48 am
Even with the original style bins, baggage stowage is not usually an issue on the 767's.
There must have been a big sale at Macy's.  dollarsign   dollarsign   dollarsign
Above and Beyond
