MAH4546
Spirit To Start FLL-BOS
Tue May 08, 2007 5:10 am
With service to Providence permanently discontinued, Spirit will begin non-stop service between Ft. Lauderdale and Boston on 8 November 2007:
NK 107 BOS 0630-0945 FLL 319 Daily
NK 126 FLL 1950-2300 BOS 319 Daily
Currently, Spirit flies a daily FLL-MYR-BOS flight. Although Spirit will continue to operate FLL-MYR and MYR-BOS, it will no longer be a through flight and the FLL-MYR and MYR-BOS flights will be retimed.
Not including destinations which have yet been confirmed, Spirit Airlines will offer service between Ft. Lauderdale non-stop to thirty five cities effective 7 November 2007. The number will likely reach fifty by summer 2008.
Launching this fall - so far - will be Baranquilla, Bogota, Boston, Caracas, Chiclayo, and Port of Spain.
Aruba, San Francisco and San Salvador (El Salvador) are looking likely. Also being tossed around in the rumour mill are Belize City, Freeport, Georgetown (Guayana), Guayaquil, Maracaibo, Panama City, Ponce, Roatan, and Toluca.
Spirit Airlines is working with FLL officials to redesign Terminal 4 in order to better facilitate international connections, add better concessions, and expand gate space.
[Edited 2007-05-07 22:16:56]
a.
Humberside
RE: Spirit To Start FLL-BOS
Tue May 08, 2007 5:35 am
I take it this flight is designed for connecting traffic and not O&D?
Visit the Air Humberside Website and Forum
LH423
Tue May 08, 2007 5:46 am
Quoting Humberside (Reply 1):
I was going to ask the same thing. Not knowing much about NKs operations in FLL, do the times of the flights look conducive to Latin American connections?
LH423
« On ne voit bien qu'avec le cœur. L'essentiel est invisible pour les yeux » Antoine de Saint-Exupéry
MAH4546
Tue May 08, 2007 5:48 am
Both. When Spirit first started out, they had a pretty rigid system of banks, but that is no longer the case. Some services that were originaly designed for connecting passengers have prooven popular with local customers. For example, Ft. Lauderdale-Orlando was started for the sole purpose of feeding into the LatAm/Caribbean ops, but this fall they will be flying the route 3x daily. Ft. Lauderdale-Atlanta was originally also meant to be mainly for connections, but they have doubled frequency, and garnered strong local traffic on the route.
The Boston flight does, however, connect to the majority of their Caribbean flights. It will connect to everything except Chiclayo, Lima, Port of Spain, and San Pedro Sula.
One thing that Spirit is doing this winter, in light of international expansion which is putting a tight hold on aircraft availability (despite the fact they are still recieving new Airbus) is that some third daily FLL frequencies will be combined with other cities. The third daily FLL-DTW will become FLL-MCO-DTW; the third daily FLL-ACY flight will become FLL-MYR-ACY. Spirit will be able to split those flights again later in 2008.
[Edited 2007-05-07 22:50:39]
a.
nkops
Tue May 08, 2007 6:01 am
I had a feeling we were going to switch ops to BOS.... waiting for BOS-RSW to appear now, since PVD-RSW did very well.
Quoting MAH4546 (Reply 3):
I like that, MYR isn't real popular in the winter, so it makes sense to run a thru flight.
:evil:
B752OS
Tue May 08, 2007 6:11 am
This should be good news and good timing for the busy winter travel season. I don't see why they will have any problem filling a daily 319, FLL is a top destination out of BOS that sees around 2,000+ daily pax during the busy season. Add in the connections to Caribbean cities, and the flight should perform well.
walter747
Tue May 08, 2007 6:12 am
Quoting Nkops (Reply 4):
PVD-RSW
Its not operated anymore. Also Spirit is only seasonal now.  Sad
Too bad could get some good service out of PVD.
Hussel, Hussel, Husel, Grind, Grind, Grind
nkops
Tue May 08, 2007 6:25 am
Quoting Walter747 (Reply 6):
Let's hope it will be seasonal.... however, I would not be too surprised if PVD didn't come back at all. The reason I say this is because on our website, if you click on PBI it says service will resume in Nov., but doesn't say that for PVD. I hope it does return though.
:evil:
RL757PVD
Tue May 08, 2007 6:34 am
This spring NK increased their PVD seats by over 100% and their pax loads didnt even flinch (stayed strong in the mid 80's). If NK chooses not to return to PVD at least seasonally, it will almost certainly be someone else's (FL/B6) gain in 2008 or 2009.
exrtremely low hanging fruit, ripe for the picking is PVD to:
RSW
PBI
MIA and
FLL (despite 1x WN, low season is 400+O&D)
even TPA and MCO are slighly held back due to a lack of competition...
Id like to see FL come to PVD with RSW PBI TPA and maybe even MIA, since we all know AA wont touch it. The have B6 tackle FLL and MCO and perhaps complementing FL seaosnally to RSW and PBI
[Edited 2007-05-07 23:35:53]
Experience is what you get when what you thought would work out didn't!
nwa757boy
Tue May 08, 2007 6:35 am
BOS-RSW
Doesnt DL run BOS-RSW? might be some competition on that route. Does DL run BOS-FLL as well? I wonder if or how they will retailate.
B752OS
Tue May 08, 2007 6:42 am
Quoting NWA757boy (Reply 9):
DL, B6, and FL all operate non-stop BOS-FLL. DL and B6 operate non-stop BOS-RSW. There is enough demand on BOS-FLL that a daily 319 should have no problem being filled.
MAH4546
Tue May 08, 2007 6:45 am
Quoting Nkops (Reply 7):
PVD is not returning to the Spirit network. That is why they are adding FLL-BOS.
a.
nwa757boy
Tue May 08, 2007 6:46 am
as long as their is enough pie for all to be had Smile
Quoting B752OS (Reply 10):
MAH4546
Tue May 08, 2007 6:48 am
Not sure if FL flew RSW-BOS last winter, but they will this winter, daily 73G.
a.
RL757PVD
Tue May 08, 2007 7:32 am
NK filled nearly 450 daily seats for PVD-RSW during this past spring, so anyone who doesn't want to "fight for a slide of the pie", or is loosing for less competition, knows where to find it.
It remains to be seen, but i do believe that NK leaving PVD could be a blessing in disguise if a real LCC moves in their place next winter/spring.
styles9002
Tue May 08, 2007 6:28 pm
Which terminal will NK operate from at Logan? Will they remain in Terminal B? Is there gate availability for them?
It is what it is.
Humberside
Wed May 09, 2007 2:08 am
Is this new flight seasonal or year round?
MAH4546
Wed May 09, 2007 3:36 am
Quoting Humberside (Reply 16):
Currently set to run November 7th through April 30th, but I think it will likely become year-round.
a.
LH423
Wed May 09, 2007 5:08 am
Quoting Styles9002 (Reply 15):
Currently they lease space from US Airways. I'm not sure how many gates they're guaranteed though they still have a fairly limited schedule so they can probably still get by with one gate. If they needed more, however, the former America West gates are still vacant, so I imagine they could move there if space constraints were an issue.
LH423
walter747
Wed May 09, 2007 5:34 am
Quoting RL757PVD (Reply 8):
Why?? I am still waiting for AA to put mainline back into PVD.
RL757PVD
Wed May 09, 2007 6:27 am
Quoting Walter747 (Reply 19):
AA is not terribly fond on PVD, as evidenced by their extreme schedule slash last year. I wouldnt be suprised if DFW came back since its AA's power hub. PVD-MIA would be a perfect 100-120 seater route, kinda long for a CR7 and a 738 might be too big.
[Edited 2007-05-08 23:27:51]
MAH4546
Wed May 09, 2007 6:29 am
Quoting RL757PVD (Reply 20):
A 738 is not at all "too big". The route would easily fill a 757 between October and April and a 738 the rest of the year. Sadly, AA doesn't have the aircraft to go around, nor do they have an interest in the PVD market.
a.
