Philadelphia1
Qantas 7556 JFK-HNL Now
Fri May 11, 2007 10:49 pm
Hey, I finally got the guts to join Airliners.net, so here i am.
But the actual reason I'm here, is I was wondering if anybody has any info on Qantas 7556 which just flew over my house in Southeast PA, and is flying New York JFK to Honolulu. Aircraft is a 747-400, so its not a codeshare with AA, not that AA even flies New York-Hawaii, but is this a charter, ferry, or new service?
cloudyapple
RE: Qantas 7556 JFK-HNL Now
Fri May 11, 2007 11:06 pm
It's a freighter. It sometimes charters Atlas to fly for them.
A310/A319/20/21/A332/3/A343/6/A388/B732/5/7/8/B742/S/4/B752/B763/B772/3/W/E145/J41/MD11/83/90
as739x
Fri May 11, 2007 11:07 pm
Cargo Flight, no big deal
ASSFO
Philadelphia1
Fri May 11, 2007 11:11 pm
gotcha, never knew qantas and atlas had a deal, thanks
VHVXB
Fri May 11, 2007 11:16 pm
Quoting Philadelphia1 (Thread starter):
Just a note nearly all if not all QF flights which are 4 digits and begin with 7*** are cargo flights
Philadelphia1
Fri May 11, 2007 11:22 pm
Quoting VHVXB (Reply 4):
i never knew that either
Bluewave 707
Sat May 12, 2007 3:10 am
QFA7556 (JFK-HNL) and QFA7554 (TOL-HNL) both continue onto SYD. HNL is only a tech stop. The flights are operated by Atlas Air / Polar Air Cargo.
I believe ANZ does the same with ANZ6972, and uses HNL as tech stop as well.
"The best use of your life will be to so live your life, that the use of your life will outlive your life" -- D Severn
jfk777
Sat May 12, 2007 3:15 am
Atlas is like the ole Flying Tigers, covering every part of the world with big jets. Too bad the founder died in a plane crash in Colorado about 6 years ago, he was flying a fighter jet he owned.
N1120A
Sat May 12, 2007 3:18 am
Quoting Jfk777 (Reply 7):
And they almost went the way of Flying Tigers a few years ago.
