cba
Why Is The 777-300ER Called The 77W?
Mon May 14, 2007 4:58 am
Does anybody know what the W is supposed to stand for? I find it odd because both the 762ER and 763ER are coded as 762 and 763 respectively. Same with the 772 and 772ER, so why the change in this standardization with the 773?
gigneil
RE: Why Is The 777-300ER Called The 77W?
Mon May 14, 2007 5:01 am
The 77L and 77W are physically different than their precesessors, unlike the 762 and 763. They're about 14 feet wider, if I'm not mistaken, so classifying them differently could be valuable to ground controllers as well as the company employees on the ground.
NS
IADCA
Mon May 14, 2007 5:03 am
I believe it's for the Boeing-given "Worldliner" nickname. Is that right?
gigneil
Mon May 14, 2007 5:04 am
The worldliner is the 777-200LR, which is abbreviated 77L.
NS
IADCA
Mon May 14, 2007 5:15 am
Quoting Gigneil (Reply 3):
That's what I thought...but it seemed too logical to pass up...
cba
Quoting Gigneil (Reply 1):
14 feet wider? That can't be true, and the different 772 and 773 models have the same respective lengths. The only difference I could find is that the longer range 777's (77L and 77W) have a slightly larger wingspan (60.9 vs. 64.8 meters).
Would the difference in wingspan be enough to have the plane classified as a different code?
Stitch
Mon May 14, 2007 5:17 am
Quoting Cba (Reply 5):
Yes, as it can affect ground ops. So the (almost) 14 foot wider wingspan of the 772LR and 773ER would mean they might not be able to as easily squeeze through an opening compared to the 772, 772ER or 773. So it would be helpful for Ground and the Tower to know they're dealing with a wider (via wingspan) plane.
gigneil
Mon May 14, 2007 6:55 am
13ish feet, sorry.  Smile
NS
[Edited 2007-05-13 23:57:14]
PHKLM
Mon May 14, 2007 7:26 am
777 - Boeing 777-all pax series
772 - Boeing 777-200 or Boeing 777-200ER
77L - Boeing 777-200LR
773 - Boeing 777-300
77W - Boeing 777-300ER
I stand corrected...
Mon May 14, 2007 12:12 pm
So no one has answered the question... What does "W" and "L" stand for?
jumboforever
Mon May 14, 2007 12:28 pm
The L stands for LONG range (from LF)
The W stands for the raked WINGTIPS of the 777-300ER
JumboForever
Carpethead
Mon May 14, 2007 12:37 pm
So most carriers seem to use '77W' for the 773ER but it seems NH doesn't abide by these rules and uses the generic code 777 for all of its int'l 777 ops.
On domestic schedules, '772' is used despite the fact that most flights are not 772ERs and 777-381s are '773.'
Milesdependent
Mon May 14, 2007 12:56 pm
Quoting Jumboforever (Reply 13):
This makes sense - but is this you using logic or has this been publicly stated by Boeing somewhere?
mD
ikramerica
Mon May 14, 2007 1:10 pm
Yes. The original 777s were "200 foot" planes, fitting in just a hair under 200 feet width.
The 777 longer range aircraft (77F, 77L, 77W) have the same wingspan (roughly) as the 744.
OGGFBORefueler
Mon May 14, 2007 1:20 pm
200 feet width or 200 feet length?
I'm guessing everyone is talking about wingspan and/or fuselage length.
Aloha!
Keone
[Edited 2007-05-14 06:22:20]
BPA Emp#0254/AOA Badge#69879
remcor
Mon May 14, 2007 2:27 pm
Along the same lines, where did 73G come from? This refers to the 737-500 and -400 right?
AJO
Mon May 14, 2007 2:35 pm
Quoting Remcor (Reply 19):
737-400 = 734
737-500 = 735
737-700 = 73G
They probably chose 73G for the -700, because "737" already means 737 - all series, and the G is the seventh letter of the alphabet. FYI, 737-800 = 738, and in the same logic as 73G, the wingletted 737-800 is known as 73H.
bla
TrijetsRMissed
Mon May 14, 2007 2:40 pm
Quoting OGGFBORefueler (Reply 18):
The original 772's are:
length: 209 ft.
width (wingspan): 199 ft.
There's nothing quite like a trijet.
SA7700
Mon May 14, 2007 2:46 pm
73G = Boeing 737-700 pax
73H = Boeing 737-800 (winglets) pax
73W = Boeing 737-700 (winglets) pax
734 = Boeing 737-400 pax
735 = Boeing 737-500 pax
SA7700
When you are doing stuff that nobody has done before, there is no manual – Kevin McCloud (Grand Designs)
777law
Mon May 14, 2007 5:08 pm
Quoting Ikramerica (Reply 13):
As I understand it, though, the "200" in 777-200 does not refer to the width / wingspan of the aircraft, it refers to the passenger capacity. Thus, 772's (ER & LR ) can carry 200+ passengers while 773's and 77W's can carry 300+ passengers.
That is where the numbering designation originates, correct?
If its not a Boeing I ain't going
Oroka
Mon May 14, 2007 7:14 pm
Quoting 777law (Reply 19):
Dont think so. Following that logic, the 747-8 can only carry 8 passengers and the 747-100 can carry 100 passengers?
-100, -200, -300, -400 is simply a way to differentiate between models. When there are varying versions of specific models (like 777-200, 200ER, 200LR) they user letters (ie 77L). Most airline configuration gets even more specific, for example some of Qantas's 747s are 747-438. For handling purposes it will be refereed to as a 744, but internally it is a 747-438.
[Edited 2007-05-14 12:15:14]
MEA-707
Mon May 14, 2007 7:20 pm
Adding to Oraka's explanation, after the 747, Boeing skipped the -100 series as these were seen as the less efficient versions with toothing problems. Now it's all messed up even more, that both Airbus and Boeing start their newest models A350, A-380 and 787 with -8 or -800 versions instead as 8 seems a lucky number.
nobody has ever died from hard work, but why take the risk?
B747-437B
Mon May 14, 2007 7:26 pm
Quoting MilesDependent (Reply 12):
Boeing doesn't determine this. The determination is made by IATA who publish an annual "Coding Directory" that incorporates all of this and more.
The "W" and "L" in the 77W and 77L don't stand for anything particular. Similarly the "H" in 73H or numerous other examples. These were selected by a committee who probably used similar logic to what was mentioned here when coming up with them, but officially are just random selections.
"The A340-300 may boast a long range, but the A340 is underpowered" -- Robert Milton, CEO - Air Canada
777law
Mon May 14, 2007 8:48 pm
Quoting Oroka (Reply 20):
Quoting MEA-707 (Reply 21):
I guess I should have better explained my point. . . I realize that my comments don't make sense when applied to the entire Boeing and Airbus fleets. But I was not saying that Boeing relied on passenger numbers when designating all aircraft like the 747-8 or 737-9 -- obviously the 739 doesn't carry 900+ passengers. My comments were limited only to 777 designations. I recall reading that Boeing decided to use aircraft capacity when designating the 772 and 773.
Stitch
Mon May 14, 2007 9:18 pm
The -100 models for the 757, 767 and 777 were reserved for future shrinks of the "baseline" -200 configuration, but the economics never worked out so they never were formally developed. In the case of the 777, the 777-100 would have been a shrink designed for ULR missions and this role was taken by the 777-200LR.
[Edited 2007-05-14 14:19:21]
Milesdependent
Mon May 14, 2007 9:21 pm
Quoting B747-437B (Reply 22):
Well there you go - that I did not know. Learn something knew every day. Thanks!
deltadc9
Mon May 14, 2007 9:50 pm
I have been waiting WEEKS for a thread as informative as that single post.
Dont take life too seriously because you will never get out of it alive - Bugs Bunny
YULWinterSkies
Tue May 15, 2007 12:35 am
Well, in this precise case, it only means that it is a 744 initially delivered and configured for QF by Boeing. If QF gets a second-hand 744 from, let's say, BA, it will be called a 747-436, and that number will follow the aircraft until the end of its life, whoever operates it.
Ironically, this system does not even tells apart engine types: BA has two subfleets of 772ER, one with GE engines, one with RR engines, and they are both called 777-236ER..., while GE-equipped AF's 772ER (identical to BA's) are named 777-228ER, or SQ's RR-powered are 777-212ER.
Airbus uses the engine maker and engine generation for the code, and 2 airlines with identical engines will share a same code (eg 380-841, 4 standing for RR, and 1 for 1st generation of the RR engine -implicitely the A380 RR engine-)
such as the A388 being a luck for Airbus! (cough...)
When I doubt... go running!
ManchesterMAN
Tue May 15, 2007 1:20 am
Quoting YULWinterSkies (Reply 27):
Yeh, but its lucky for all those airlines who got cheap A330s because of it!
Flown: A300,A319,A320,A321,A330,A340.A380,717,727,737,747,757,767,777,DC9,DC10,MD11,MD80,F100,F50,ERJ,E190,CRJ,BAe146,Da
ConcordeBoy
Tue May 15, 2007 1:34 am
Uh, no. Has nothing to do with either of those.
The "2" is used because the initial plans for a 777-100 were scrapped, and "00" is Boeing's production code. Thus, an undelivered (or generic name for the) aircraft is 777-200.
Once the aircraft is completely outfitted for delivery, the "00" becomes the code of the company whose specifications it was built for. Delta's code, for example, is 32. So a 777-200ER built for them, would eventually be delivered and operated as a 777-232ER.
.....keep in mind this only applies to Boeings. Airbus' code specifies the derivative type, the engine type, and the production version number.
United787
Tue May 15, 2007 2:10 am
What is the 77F?
SA7700
Tue May 15, 2007 2:15 am
Quoting United787 (Reply 30):
What is the 77F?
777 freighter model
SA7700
Aircellist
Tue May 15, 2007 2:18 am
Quoting Jumboforever (Reply 10):
Even if it was set by IATA...
... how about 77Large and 77Wide???  Smile
(keeping in mind that "wide" means "large" in french)
"When I find out I was wrong, I change my mind. What do you do?" -attributed to John Maynard Keynes
LY777
Tue May 15, 2007 5:56 am
Quoting PHKLM (Reply 8):
I
I read somewhere that the 777-200ER code was 77E
clickhappy
Tue May 15, 2007 6:00 am
Boeing does append a second letter (Wx) for use on their internal docs and flight numbers.
