DABTH747
Help! 10 Year Background Check US Customs!
Wed May 16, 2007 10:18 pm
HI everyone in the States I just needed your help, I dont want to give up a fantastic job oppurtunity in the US, and wanted to know if its really hard to get a ten year background check done, are they really strict, or how does it work? ( I have a Pakistani background and lived there for 3 of the ten years for the check)
Any help will be appreciated thanks!
SkyexRamper
RE: Help! 10 Year Background Check US Customs!
Thu May 17, 2007 12:12 am
Well if you have major jail time, then well, you're probably not going to pass. What is the job you're trying to get? But as long as you've been employed and a good person you shouldn't have an issue. On the other side, it's the US Gov.
Good Luck to all Skyway Pilots! It's been great working with you!
searpqx
Thu May 17, 2007 1:34 am
Quoting DABTH747 (Thread starter):
Assuming its roughly the same one you go through for the airlines, you just need to prove employment for the last 10 years (they will verify w/ the employer), or if not employed, provide references/proof of what you were doing. That and verification of no jail time or pending criminal actions and that's about it. Even being terminated from a previous position won't necessarily be a problem as long as A) You're honest on the application about it B) You were terminated for something that disqualifies you for the job.
"The two most common elements in the universe are Hydrogen and stupidity"
Ken777
Thu May 17, 2007 1:50 am
Be clear and honest - incorrect statements about your past throws up a huge red flag. Not as bad as a criminal record, but enough to disqualify you, or cause a very long delay while things get cleared up.
Good luck on your new job - hope things work out well for you.
BigOrange
Thu May 17, 2007 5:41 am
If it's the 10 year criminal record requirement for a visa don't worry about it. Just go to your local police station and tell them you need proof of no criminal record. They will most likely give you a form to fill out to send to the national police headquarters (Scotland Yard is the UK equivalent)
In the UK this only goes back 5 years, but the report does not specify how far back it goes, so it is accepted by USCIS.
fxramper
Thu May 17, 2007 6:00 am
From your stated occupations you'd be required to take the 28 Crimes (felony) background check mandated by the Federal Aviation Administration and conducted by the Federal Bureau of Investigation.
DABTH747
Thu May 17, 2007 10:30 am
Quoting FXramper (Reply 5):
thanks everyone, it was an LH job internal one, so it was a requirement on the posting to be able to obtain a ten yr background check by US customs, I am of pakistani background and lived there from 1997 to 2000..thats why I needed your help and opinions, I appreciate it all the responses
