DIA
Who Will Take ANA's 747-400Ds?
Thu May 17, 2007 1:25 am
With ANA phasing out all 747s, who will take the 747Ds? JAL? Who else would use these short-range domestics?
**Bonus if you can list who took any of the 747SRs.
Photo © Kota murahashi
Ding! You are now free to keep supporting Frontier.
jimyvr
RE: Who Will Take ANA's 747-400Ds?
Thu May 17, 2007 3:59 am
They can be modified to regular 747-400 so other carriers would take it.
1000 - 01MAR07 | http://airlineroute.blogspot.com/
purplebox
Thu May 17, 2007 4:17 am
Quoting Jimyvr (Reply 1):
Yes, but the number of cycles will be huge - my HND-CTS flight at Christmas was only 1.5 Hrs!
PurpleBox.
Next Flights:LHR-BOG,BOG-GYE,MDE-BOG-PTY,PTY-BOG-CTG,SMR-BOG-LHR - all on AV
OceansWorld
Thu May 17, 2007 4:18 am
Quoting DIA (Thread starter):
Most have been scrapped. QR used two of them between 1995 and 1999, while Atlas Air bought some to get GE-engines for their ex. SQ PW-powered B742s, and perhaps spare parts too.
NH B747s & KZ B747s
Cheers.
SEPilot
Thu May 17, 2007 4:22 am
What about converting them to freighters? There's plenty of demand for those.
AV8AJET
Thu May 17, 2007 4:29 am
That's true, add back the fuel tanks and winglets then they could go almost anywhere. Maybe JAL could take them since they also operate the 744D.
"To fly or not to fly there is no question!"
MCOflyer
Thu May 17, 2007 4:30 am
How bout Oasis Hong Kong? They could convert them to regular 400 stats. Also, UPS could get them and convert them to F standards.
Hunter
OceansWorld
Thu May 17, 2007 4:38 am
Quoting PurpleBox (Reply 2):
Well, at least NH is not a complet newcomer to such conversion. At least two of their B747-481D served for a while as B747-481 before being converted back for domestic ops.
JA8955 was delivered in May 1992 as a -481D, was converted to -481 and operated as such between 12/1996 and 10/2001, before reverting to -481D.
Photo © Yakfreak - VAP
Photo © George iliopoulos
Same for JA8957. The aircraft was used as a -481 between 04/1997 and 04/2002.
Photo © Ky Cheng
Photo © Yuxiaobin
[Edited 2007-05-16 21:40:33]
United_fan
Thu May 17, 2007 5:06 am
Quoting SEPilot (Reply 4):
Wouldn't they be at a disadvantage because they were built stronger (heavier) to withstand more cycles?
I wonder if the 777's will be able to withstand all the short flights?
[Edited 2007-05-16 22:08:15]
Champagne For My Real Friends,and Real Pain For My Sham Friends
787EWR
Thu May 17, 2007 5:41 am
Quoting United_Fan (Reply 8):
I would think with modifications, this would not be an issue. I would further assume that they would go through a D check(allowing for such modifications) before going back into service.
I was unaware that they were using 777s for domestic services, although financially, it makes perfect sense. Not to answer a question with a question, but has Boeing created a 777 Domestic version?
DfwRevolution
Thu May 17, 2007 5:54 am
Quoting 787EWR (Reply 9):
Not exactly, but the 777-200 or 777-300 (non ER) would be suitable for domestic operations. However, the 787-3 would likely be an even better choice.
ANA is not (yet) phasing out the 747-400D. They are only retiring the 747 on long-haul international routes. The -400D will be around for some time.
Carpethead
Thu May 17, 2007 8:37 am
By the time NH and JL start retiring 744Ds, they will be approximately 20 years old and airframe cycles will be sky high. Any second-hand carrier will balk at the prospect of putting money in an airframe that will have extensive conversion costs and little remaining airframe cycles. Just like most of the 747SRs, they will be stripped of any valuables such as engines and scrapped at MZJ, VCV, or MHV.
Most of the NH 747-481s that are going to be retired the next couple of years have buyers. A few are going to Oasis in Hong Kong and a few to Air Atlanta Iceland for cargo conversion or charter config.
In short, no.
NH & JL both operate basic 772 & 773 for their domestic operations.
However, they are both certified at the lowest gross weights.
(Why? Reduced fees all across the board. Why carry excess weight or certification around for an aircraft that would fly at maximum 2.5 hours.)
Motorhussy
Thu May 17, 2007 10:44 am
Maybe EK can take them for The Haj shuttles between DXB and JED?!
come visit the south pacific
Lufthansa747
Thu May 17, 2007 11:17 am
OX took 2 ex-JAL 74R's.
afterburner
Thu May 17, 2007 11:19 am
Quoting MotorHussy (Reply 12):
Hajj pilgrimage only happens once a year. What will EK do about them for the rest of year?
wcs
Thu May 17, 2007 11:36 am
Hi,
Sorry to answer a question by another but how far are going the modification for a "D" model? Is it just a matter of cabin conf', or is there anything more?
[edit] I saw on the picture that the winglets re gone, so I assume that isn't just a matter a cabin. I will be glad to learn about others modifications!
[Edited 2007-05-17 04:38:47]
FLY SKYTEAM JETS
MDorBust
Thu May 17, 2007 11:55 am
I was also under the impression that the Ds were heavier than a stock 744 because of reinforced floors and a couple of other things.
Wouldn't reconverted Ds be heavier than other 744s?
"I KICKED BURNING TERRORIST SO HARD IN BALLS THAT I TORE A TENDON" - Alex McIlveen
Carpethead
Thu May 17, 2007 12:36 pm
Quoting WCS (Reply 15):
If a 744D model is to be converted to a typical int'l configuration various plumbing work will have to be done beacuse the 744D don't have nearly the number of toilets as standard int'l ones and then there's the question of galleys, which 744Ds have very minimal of.
As for the airframe, the landing gear and surrounding structure is beefed up due to the the obvious.
The brake fan in the landing gear can probably be taken-off easily. This is due to a normal 744 doesn't see six cycles in a day!
I am not sure of other differences but there are probably some other minor details.
Of course, if a carrier wants to convert a 744D into a cargo config, all the pax systems are just ripped out and end of story. However, again considering the number of cycles, only two are probably going to be candidates for any future work: JA401A & JA402A, which have only recently (5/6 years ago) been converted to a 744D and airframe itself is about 10 years old. If I am not mistaken, I have seen a story on these two aircraft are indeed leaving in the next two years.
sllevin
Thu May 17, 2007 1:05 pm
But those cycles are accounted for differently when the aircraft is operated within the "D" parameters (which includes lower weights, etc).
Does anyone have a source for the "beefing" up? I know it was true for the SRs, but with the 400D's I believe the reverse is true; Boeing did everything to lighten the birds, and then built a different MX process for aircraft operated within the "D" parameters of lower landing weights, lower taxi and takeoff weights, etc. The stab tank was omitted, for example, because not having it and the associated plumbing saved significant weight.
Steve
Motorhussy
Thu May 17, 2007 4:09 pm
Quoting Afterburner (Reply 14):
Hence the ?! on the end of my comment!
cricket
Doesn't the lower MTOW make 400D's unsuitable for cargo opns?
A300B2/B4/6R, A313, A319/320/321, A333, A343, A388, 737-2/3/4/7/8/9, 747-3/4, 772/2E/2L/3, E170/190, F70, CR2/7, 146-3,
albird87
Thu May 17, 2007 9:11 pm
Could Boeing take them and make them into LRFs for the 787 program??
cyclonic
Fri May 18, 2007 12:54 am
Would it be wrong of me to say that I might feel uncomfortable flying on an aircraft with such high cycles and long life?
Or am I mistaken?
Either way, sad to see them go - have always wanted to see them in action.
Keith Richards: The man that Death forgot...
Tod
Fri May 18, 2007 2:07 am
Quoting OceansWorld (Reply 7):
NH also does this with their 777 fleet. Four of the International cofiguration 772 are currently being converted to domestic configuration.
Quoting Carpethead (Reply 17):
Not too tough of a job to install the applicable potable water supply, sink / floor drains and vacuum waste system plumbing.
Heath Tecna, Flight Structures and Jamco do this sort of work all the time.
Tod
