El Al 001
LH 744 With 410 Pax?
Thu May 17, 2007 4:13 pm
Hi,
A friend of mine who's working at TLV claims that LH comes to TLV with a 744 that sometimes carries 410 pax on board.
When I searched through LH website I've found that LH has 3 kind of configurations on its 744s:
16F / 52C / 310Y = 378 pax
16F / 62C / 274Y = 352 pax
16F / 80C / 234Y = 330 pax
Am I missing something here???? With what configuration LH comes to TLV???
Mike
ktachiya
RE: LH 744 With 410 Pax?
Thu May 17, 2007 4:15 pm
I can't speak for LH but 410 seems like a possible number.
JAL on their FCO or YVR route fly a B744 with 449 people. That's quite a high density.
Flown on: DC-10-30, B747-200B, B747-300, B747-300SR, B747-400, B747-400D, B767-300, B777-200, B777-200ER, B777-300
zvezda
Thu May 17, 2007 4:16 pm
I believe LH used to have 410 seat configuration, prior to the fitting of the new C seats last year.
LTU932
Thu May 17, 2007 4:25 pm
Judging from the fact that TLV is highly a successful and a high demand route for LH (or else they wouldn't have a second frequency with an A346), I wouldn't be surprised if they sent their highest density 747s, even at the expense of premium capacity.
Thu May 17, 2007 5:17 pm
I know we send over the 744 with the old C-class but the total amount of seats I do not know.
Why does LH not start operating MUC-TLV aswell? 'The flights ex FRA seem to be packed every day!
PanHAM
Thu May 17, 2007 5:28 pm
They don't have a special seat configuration for TLV. That's the normal 747 rotation and the plane serves other destinations as well, same as the 346. Even with the old C class, the 747 never had 410 seats
Rumour has it that LH was politely asked by the Israeli Government to restrict it's capacity, that's why they do not serve MUC-TLV.
Was Erlauben Erdogan!!!
SailorOrion
Thu May 17, 2007 5:52 pm
Quoting PanHAM (Reply 5):
From what I've heard, that's some VERY British understatement  Smile
SailorOrion
johnnybgoode
Thu May 17, 2007 6:15 pm
'politely' could be the rumor, but other than that, this is not a rumor at all. due to traffic right issues, LH had to leave the MUC-TLV market and stick with two dailies ex FRA.
If only pure sweetness was offered, why's this bitter taste left in my mouth.
HT
Thu May 17, 2007 6:28 pm
What was the capacity of the old 742's before they were retired ? I am under the impression that they had a bigger capacity than the 744's (more Y, less C and/or F) and that's why they were employed to MIA.
-HT
PanHAM
Thu May 17, 2007 7:16 pm
Quoting SailorOrion (Reply 6):
was intended as such
Quoting HT (Reply 8):
in 2000, FI., the yellow booklet shows under "742" F 8 C 51 M 330 ttl 389
airbazar
Thu May 17, 2007 10:03 pm
Quoting PanHAM (Reply 9):
Plus crew and that should approach the 410 number.
PanHAM
Thu May 17, 2007 11:18 pm
I traded with bazaris many times. ElAl001 said "410pax" and that does not include crew.
Deadheading crew are occupying pax seats.
LXA340
Thu May 17, 2007 11:46 pm
Did all 744's receive the new Business class by now?
UAL4ever
Thu May 17, 2007 11:48 pm
I am flying ORD-FRA-TLV in mid June and I am flying Business class. The FRA-TLV leg on LH is on a 744 and I have been informed that it is with the new business class. According to seatguru this plane is configured to hold 330 pax. It is configured 16F 80C 234Y.
SailorOrion
Fri May 18, 2007 12:27 am
All 747-400s do have the new C class meanwhile (thus named 74P). Standard configuration is 16/80/234, however LH is able to do QCs (Quick changes, they take 3 hours afaik) to adjust the number of C and M seats according to demand...
SailorOrion
El Al 001
Fri May 18, 2007 1:44 am
SailorOrion,
It took so many years for LH to convert its 744s and now you are saying that they can switch from C/cl seats to Y/cl seats in just 3 hours?
Can you specify a bit on that?
Do you have any kind of source to that available?
PanHAM
Fri May 18, 2007 3:18 am
LH Technik can change the seating from old C to new C within that time frame, inlduing taking out a section of Y class. They do that during regular stops, aircraft coming in from somewhere, as soon as pax are left they start with the work and the machine is ready to go after about 3 hrs.
However AFAIK the a/c stays in that configuration. They do not change "according to booking situation".
Tobi3334
Fri May 18, 2007 3:29 am
According to a tv-reportage it seems to be quite common for LH to switch seats during turnarounds.
They said that it is worth the money and the time if you can add more C pax instead of Y pax.
But in the TLV case it seems to be the other way around.
Lp0815
Fri May 18, 2007 11:42 am
There are 3 seating-versions of the 744 with the new business class:
16/52/310
16/80/234
16/66/270
744 with the old business class came in 3 different seating configurations:
16/64/310
16/78/274
16/99/234
LH 686/687 FRA-TLV-FRA is currently served with a configuration 16/52/310 (so is the case for 18MAY, 20MAY, 21MAY)
However, occasionally (according to demand) a different version is deployed on the route (for instance, 19MAY 16/80/234).
LH 690/691 is served with A346, configuration is 66/279.
Cheers (ve shabat shalom),
Lp0815
Time waits for nobody
SailorOrion
Fri May 18, 2007 6:02 pm
Quoting El Al 001 (Reply 15):
From what I know of LH personell, it takes 3 hours to convert the 74P from one configuration to another, assuming the plane is in FRA. LH also has Quick-Change options on the 346s, but in FRA only. No QCs can be done in MUC
SailorOrion
