rsbj
Questions On Airbus's Long Term Product Strategy
Sun May 20, 2007 12:27 am
1). How does the A350XWB fit into a 20 year vision? By that, I mean it seems to leave a big gap between it and the A380, and it would also seem to leave a big gap below it assuming an A320 replacement is roughly the same size.
2). Will Airbus try to fill these perceived holes with a 450 seater and a 225 seater meaning 4 different production lines with 4 different fuselage's? Has this been part of the plan since the A350XWB's inception?
3). I don't expect the 747-8I to sell too well (though I hope I'm wrong) so negating that, what pros or cons are there with Boeing's 3 aircraft lineup (Y1, Y2, Y3) versus Airbus's possible 4 aircraft lineup? To me, 4 sounds about right as it covers a lot of range with regards to seats with less compromise that's inherent in long stretches or shrinks.
4). Is Airbus's long-term product strategy negatively altered because they have to react to the 777/787 combination?
5). Would the A350XWB be different if the A340NG was competitive? How?
6). I really like the nose of the A350XWB; very sleek, and the only way for me to tell it apart from the 787. Will they really change it and put on the A380 style nose?
7). Can this be discussed with civility on A.net?
I fly really fast and take a lot of chances.
JayinKitsap
RE: Questions On Airbus's Long Term Product Strategy
Sun May 20, 2007 1:24 am
Quoting Rsbj (Thread starter):
You inidcate a 450 seater and a 225 seater, that is two added models besides the 320 350XWB and 380. I believe Airbus will only be able to fill one of the gaps. The gap above is the 346-773-747 area which is good but probably has only around 1,000 frames needed in 15 years. The timing for replacements in this area will have a good peak in about 10 years.
Below it is the area previously filled with the A300, A310, 757, and 767. The replacement cycle is currently in a peak now. I believe that Airbus should update the A330 along with the 330F using new engines and some other easy improvements. That would give them a player in the size range with a better draw than the current 330 and extend the life of the 330. At least this option has a relatively low R&D cost compared to a new bird.
rsbj
Mon May 21, 2007 12:47 am
Sorry, yes that adds up to 5 different frames. So you think they'll abandon the 350-550 seat range? That seems like a big hole if you ask me, one that Boeing could easily fill with the 747 and Y3.
Interesting theory on the A330, but I think it's future is getting dim.
Thanks for your input.
Rick
EI321
Mon May 21, 2007 1:15 am
As things stand, the XWB will be the staple aircraft in Airbus' 200-400 seat category for the foreseeable future. The question of the perceived gap between it and the A380 is valid, although we have to ask ourselves is there much demand for an aircraft that fills that gap?
No, there is not enough demand for an aircraft in the 400-500 seat category. This is reflected by sales of the passenger versions of the 747-400 and 747-8 since the start of the century.
Well the Intercontinental has the advantage of being relatively cheap, as its being developed in tandem to the Freighter, for which there is demand. The disadvantage of the Intercontinental is that because its a cheap derviative, its unlikely to win any new market share for Boeing against the A380.
The 787 definitely had a major influence on Airbus' decision to launch the A350.
Yes, if the A340-500/600 were equally competitive with the 777-200LR-300ER, its likely that Airbus would have sized the A350 similarly to the A330, as Boeing did with the 787.
Its unlikely that the A350 will feature the A380s nose.
Can anything be discussed with civility on A.net?
[Edited 2007-05-20 18:19:19]
BoomBoom
Mon May 21, 2007 3:04 am
Quoting EI321 (Reply 3):
And the disadvantage of the A380 is that it's a very expensive new design, its CASM will be higher than that of the A350-1000 and perhaps the 787-10. So it will have a very short life and never come close to recovering it's development cost, IMHO.
Our eyes are open, our eyes are open--wide, wide, wide...
EI321
Mon May 21, 2007 3:35 am
Quoting BoomBoom (Reply 4):
Thats all possible now, but none of it was relevant when the aircraft was designed. Even Boeing is saying that the market for aircraft in this size is approx 1000 frames over the next 20 years. Thats with both the 787 and A350 at the table. Boeing also says that it expects the Intercontental so account for 2/3 of 747-8 sales. Assuming that the A380 break even point is 450 frames, will Boeing sell 550 747-8s?
[Edited 2007-05-20 20:53:40]
ConcordeBoy
Mon May 21, 2007 3:46 am
The A340"NG" is competitive with the 777, but it is not the twinjet's equal in the majority of applications. Quite the difference between that and not being an appreciably competitive product at all.
Motorhussy
Mon May 21, 2007 6:03 am
Yes, to counter both lines is why they didn't make a direct one-for-one competitor to the 787. The negative impact is that they don't have a new product in the 787-800 class and will have to rely on the ageing A330-200, but they would always have been playing catch-up on this market anyway.
The real opportunity is in the 787-900 to 777-300 class where, in the case of the 789, there have yet to come huge amounts of orders (compared to 788) and, with the 777, airlines will soon be looking beyond it (and/or to replace their existing Airbus equipment).
MH
come visit the south pacific
keesje
Mon May 21, 2007 6:28 am
I think they have been a long time in the 250-300 segment with the A330/a340. In the 2001-2007 they dominated the segment. So I don´t think Airbus's long-term product strategy is altered with the A350, it continues, Boeing is fighting back with the 787.
I think those holes have been there e.g. the 707/767 - 747 hole for 25 yrs until the 777 arrived in 1994.
zvezda
Mon May 21, 2007 6:35 am
The replacement for the A320, code-named NSR, will almost certainly have a CFRP fuselage, the inherent rigidity of which means that NSR can stretch beyond the length of the 757-300.
EI321
Mon May 21, 2007 7:08 am
Quoting Zvezda (Reply 9):
That does not mean that it will be suitable for long haul operations though. While the A320 replacement may indeed be stretched beyond the length of the A321, I cant see it being offered as an effective long haul aircraft. For instance, if the NSR was to be offered in lenth as long as the 753, it would need larger wings than the A318 sized NSR.
zvezda
Mon May 21, 2007 2:28 pm
Quoting EI321 (Reply 10):
As has been much discussed in the context of Y1/737RS, it would be possible for Airbus to develop wings in two sizes for NSR. There will be a large market for NSR/737RS with transatlantic range.
terry
Mon May 21, 2007 3:15 pm
The initial posting I think reflects a bit of wishful, unrealistic thinking. Boeing has always outgunned the opposition with a bigger range of models and I can't see that changing.
History: B's 707, 727, 737, 747 (4 models) beat the DC-8, DC-9 and DC-10 of Douglas.
Present era:
B's 737, 767/787, 777 and 747 will take care of A's 320, 330/340/350 and A380 ranges.
With 4 models Boeing obviously offers a more focussed product than competitor 3-model range.
And Airbus seem to think that 3 is enough - I haven't heard/seen any proposals for a new model (even if they could afford to develop one!)
zvezda
Mon May 21, 2007 3:19 pm
Quoting Terry (Reply 12):
Boeing's announced strategy is to transition to 3 models:
Y1/737RS
787
747-8/Y3
astuteman
Mon May 21, 2007 3:32 pm
When Airbus produced the original A300, they found it extremely cost-effective to stick with that fuselage to produce a whole range of widebodys, the A330, A340, and A340NG. It seems very obvious to me that this is their intent again.
 checkmark
The -XWB cross-section will be Airbus's staple widebody for the forseeable future. The gap between the current A320 and the A350 will easily be filled with a combination of a) larger variants of A320RS, as Zvezda says, and b) a "smaller" derivative of the A350XWB.
Smaller in every sense, not just an A350-700 style shrink. Think more along the lines of a reincarnation of the A300, but based on the A350 fuselage, all-CFRP, and damned efficient. From a capability viewpoint, such a plane might re-create the capabilities of, say, the A330-200, but on an MTOW of c. 400 000lb.
I'd expect a 225 seat, 6500-7000 Nm range, and a 250 seat 5500 - 6000Nm range variant
Shorter ranges at this capacity would be narrowbody. IMO.
We may see a 400 seat A350XWB-1100 someday.
I would guess the gap between this and the A380 will remain until the A380 is replaced with a "look-alike" Y3 style aircraft, sometime after 2020
zvezda
Mon May 21, 2007 3:42 pm
Quoting Astuteman (Reply 14):
Think A305, the model that was cancelled the day after the WhaleJet was launched.
I agree. An A350-1100 is a possible response if Boeing build a 787-11.
astuteman
Mon May 21, 2007 3:44 pm
Quoting Zvezda (Reply 15):
Think A305
Thanks. That's the one.....
Be interesting to see where they'd pitch the MTOW, if it ever came about...
deltadc9
Mon May 21, 2007 9:55 pm
That is probably true for the passenger market and incorrect in the freighter market. It would not shock me to se a few new customers.
Isnt it ironic this formum is called "CIVIL Aviatiaon"?
Quoting Zvezda (Reply 13):
Y1/737RS
787
747-8/Y3
True, but is is likely that Y1 will be two planes and Y3 will be offered along side the 748F.
Dont take life too seriously because you will never get out of it alive - Bugs Bunny
Stitch
Mon May 21, 2007 10:09 pm
Airbus has a very strong product in the 225-seat market right now - the A330-200. So I don't believe they really need to play that low because by the time the 787 comes to dominate that segment, Airbus will have had a fantastic run with the A332. It's much the same with Boeing and the VLA segment. Airbus will come to dominate it thanks to the A380, but the 747 made Boeing a shedload of money during it's life.
The real battle is going to be in the 250-350 segment and that is where the 787 and A350 will go head to head, taking over for the 777 and A340.
As to "gaps", right now the demand for long-range large narrowbodies (757/A321 class) is just starting to grow, driven mostly by domestic competitive pressures. If WN wasn't beating the US majors into the ground in North America or FR/U2 doing the same to the EU majors in Europe, I don't believe we'd be seeing the trans-Atlantic expansion via 757 ops that we are now. They're going international because their competitors are not. So Boeing not having a 757 replacement and Airbus not having an A321 that can cross The Pond are not real hindrances right now, I believe.
And both the 787 and A350 should be able to grow one step larger (787-11/A350-1100) which will offer growth options and flexibility to long-haul airlines.
zvezda
Mon May 21, 2007 10:35 pm
Quoting DeltaDC9 (Reply 17):
True, but is (sic) is likely that Y1 will be two planes and Y3 will be offered along side the 748F.
Either of those are possible, but I don't believe either are likely, if by "two planes" you mean two different cross-sections.
Quoting Stitch (Reply 18):
 checkmark
EI321
Mon May 21, 2007 10:53 pm
The A300-500? Tell me more!  Wink Where can I get info on that design?
While these models are stong future possibilities, I dont think we will see them for a while. Do you think the current A350 wing is sufficient to support a -1100 length aircraft (lets assume a range of 7500m) without modifications?
Whats you opinion on re-engining the A330-200, and putting her on a diet? Something similar to what Emirates Mr Clark wants Boeing to do to the 777?
zvezda
Tue May 22, 2007 12:09 am
Quoting EI321 (Reply 20):
A300-500?
No, I think it was A305-200.
Ask Lightsaber. RE: Leahy: Airbus Was 'caught Napping' By 787 (by Lightsaber Apr 27 2007 in Civil Aviation)
Larger wingtip extensions to increase the swept area would probably be required for good field performance.
I would just put on new engines. I wouldn't spend a lot of development money on weight or aerodynamics.
Stitch
Tue May 22, 2007 12:26 am
I imagine it wouldn't hurt, and could put the A332 in a similar situation to the 787-8 where the 763ER is to the A332 - around a 2:3 sales ratio (two A332Es for every three 787-8s). It would also make the A332F even more effective.
EI321
Tue May 22, 2007 12:33 am
Quoting Stitch (Reply 22):
All considered, I dont think they will do it, as they would be shooting themselves in the foot, with regards to A350 sales. I think GE and Boeing are in a similar boat regards the GEnx A350, 787-10 & 777 GE90 - all potentially fighting in the same ring.
BoomBoom
Wed May 23, 2007 5:18 am
Richard Aboulafia:
Original plans called for Airbus’ new
product spending to ramp down after first
A380 deliveries, in early 2006. This
would have allowed Airbus to focus on
satisfying shareholders while maintaining
a 50+% market share position with a new
product line. Yet thanks to the A380’s
marginal commercial relevance, the 777’s
victory over the A340, and Boeing’s renewed
commitment to the market in the
form of the 787, Airbus has no choice but
to press ahead and generate the cash any
way it can (increase production of its
existing models).
http://www.aiaa.org/aerospace/images...eimages/pdf/insights.layoutMAY.pdf
astuteman
Wed May 23, 2007 5:35 am
The current A350-1000 is a 295t aircraft.
It has roughly the same wingspan as a 360t 777-300ER.
The A350-1100 you describe (i.e. 7 500Nm) would in all probability be the same MTOW as the 8 300Nm A350-1000.
In reality, I suspect an A350-1100 would have to grow to 320t-325t in order to achieve 8 300nm ish range.
As the current wing is the same span as a 360t aircraft, it should be sufficient.
However, against he envisaged stiff competition, sufficient won't be good enough.
As increased span reduces drag, the wing span would need to increase from 64m to c.67m in order to deliver a proportional Lift/Drag.
Quoting Zvezda (Reply 21):
In reality, this may well be the result.
[Edited 2007-05-22 22:35:50]
