Lufthansa
PW A330 Performance
Thu May 24, 2007 11:17 am
Hi folks
I'm interested to know how the fact that PW didn't release a 72 000 lb version of the PW 4000 for the A330 affects
its performances. The reason I ask is this. I've been spending a bit of time out MSP way, and obviously NW has a big fleet of A330-300X out there. Now I've noticed some of these are used on some quite long legs. Being PW powered, they must be powered by the 68 000lb thrust engine, the PW4168A.
This is apparently the most efficient engine option on the A330. So here is my question.? Just how much does the fact that this aircraft only has a 68 k engine limit its operations? NW seems to use them on some quite long legs? Is it at typical weights of passengers plus fuel basically able to do all the same jobs as the rest? Do they need to limit cargo more often, or is the 68 000lbs of thrust more then enough to do the job for the 333x?
Any insight at all welcome...especially from the engine guys out there.
LH
LTU932
RE: PW A330 Performance
Thu May 24, 2007 11:32 am
PW was developping a 72,000 lb rated engine for the A330, named the PW4172. US was the launch customer for that engine, if I'm not mistaken, but IIRC there were problems during development (including one which required the engine to get a brandnew cowl designed just for it) which eventually forced Pratt to stop development of the PW4172.
MCOflyer
Thu May 24, 2007 11:42 am
Could we get some long A333 routes and compare performance with those figures?
MCOflyer
Lufthansa
Thu May 24, 2007 11:49 am
Quoting MCOflyer (Reply 2):
excellent idea!
I second that!
MCOflyer
Thu May 24, 2007 2:21 pm
According to the a/c data site we have, it list the performance w/ P&W at 4550NM for the 333 w/ P&W engines.
http://gc.kls2.com/cgi-bin/gc?PATH=s...E=best&RANGE-COLOR=navy&MAP-STYLE=
This one long route NW flies but its a 200 and that Air Asia new startt up w/ A333's will have some long runs too. Doesn't QF do some long runs on their 330's?
MCOflyer
[Edited 2007-05-24 07:22:18]
LTU932
Thu May 24, 2007 2:32 pm
Quoting MCOflyer (Reply 4):
Don't trust the A.net aircraft data site, as it's generally out of date. According to Airbus, the stated range for an A330-300X, with full fuel, pax and their bags, is more around 5,500 nm. 4550 nm sounds more like a possible payload range for an A333, though even A330-300s that are not HGW models can do 4550 nm. NM used a former EI A330-301 on the MAD-SJO-PTY-MAD run, and the MAD-SJO leg was flown nonstop, despite still air distance being 4593 nm.
trex8
Thu May 24, 2007 8:41 pm
off the top of my head airline website says NW A330-323X 233K with PW4168A has about 4600nm range, a CI A330-302 with 230K GECF680EA4 has 4000nm
Flying Belgian
Thu May 24, 2007 9:15 pm
IIRC, QF's longest leg with the A330-300 is BOM-SYD (with some payload restrictions I guess). But the Westbound leg is stopping in SIN. Don't forget that QF operates GE CF6 powerplants.
Pratt powered A333's longest routes are operated by NW (SEA-AMS, SEA-NRT) and KE I think (ICN-PRG).
I hope this helps.
FB.
Life is great at 41.000 feet...
CHRISBA777ER
Thu May 24, 2007 9:40 pm
EI use them DUB/SNN - LAX thats got to be up there, but i'd assume they are payload restricted. (5122 mi)
I thought CX's runs HKG - MEL (4590 mi)
SYD (4581 mi)
...are used sometimes with the A333 - thats got to be a bit of a trek.
Do AC use their A333s LHR/FRA-YVR? (4723 mi)
SK use theirs ARN-ORD i think (4272 mi)
What do you mean you dont have any bourbon? Do you know how far it is to Houston? What kind of airline is this???
andrewtang
Thu May 24, 2007 9:48 pm
Quoting CHRISBA777ER (Reply 8):
Aer Lingus uses Airbus A330-200 on this route.
PM
Thu May 24, 2007 9:59 pm
For a long time the PW4000 was the lead engine on the A330. It was the engine of choice. The RR Trent made a good initial showing but was still eating PW's dust (!). GE was nowhere. The CF6 wasn't popular at all. Then RR began pulling ahead of PW and GE won (or bought?) some useful orders (QR and QF being the most obvious). GE are still in third place but not far behind PW. RR are well ahead. Latterly PW have picked up Kingfisher and Grupo Marsans (= Aerolineas Argentinas among others) but most new orders are contested between RR and GE. RR appear to have gained an early (but still small) advantage on the A330F and that may be the best seller over then next five or more years.
By the time Airbus have sold 1,000 A330s (and who's to say they won't?) RR will have 40-45% of the sales and GE and PW will be fighting over the remaining 55-60%. My guess is that when the music stops it'll be something like RR 45%, GE 30% and PW 25%. In other words, a rare defeat (these days) for GE.
