rootsair
LTU BAe146 Where To?
Fri May 25, 2007 5:30 am
When I loooked up for LTU on wikipedia I saw that they have a Bae 146 . Found a pic on a.net
Photo © Lino Borges - Azores Spotters
Would you be able to tell me what routes they fly them to?
regards
BM  airplane  wave
A man without the knowledge of his past history,culture and origins is like a tree without roots
purplebox
RE: LTU BAe146 Where To?
Fri May 25, 2007 5:44 am
Quoting RootsAir (Thread starter):
It's leased from WDL...
These pictures should help you...
PurpleBox.
Next Flights:LHR-BOG,BOG-GYE,MDE-BOG-PTY,PTY-BOG-CTG,SMR-BOG-LHR - all on AV
Notarzt
Sat May 26, 2007 8:13 am
AFAIK, the BAe 146 is primarily used on city shutlle flights such as DUS-MUC.
oldeuropean
Sat May 26, 2007 4:56 pm
I also never noticed that plane and don't know any details .
But, if you look at the other pictures in the data base of D-AWBA, there are pics taken at PMI, MAD, LIS, FAO, and also one photographer mentioned the use on DUS-FCO. So it looks like short dated uses from DUS to different destinations around the Mediterranean Sea. It is leased from WDL.
Axel
Edit: Uups, sorry, I overlooked the same hint of PurpleBox in Reply 1.
[Edited 2007-05-26 10:13:08]
Wer nichts weiss muss alles glauben
stylo777
Sat May 26, 2007 6:18 pm
Legs of 26.05.2007
AB 8160 WDL 143 DAWBA DUS FCO 05:50 08:10
AB 8161 WDL 143 DAWBA FCO DUS 08:55 11:20
LT 128 WDL 143 DAWBA DUS CTA 14:45 17:20
LT 129 WDL 143 DAWBA CTA DUS 18:20 20:55
Legs of 27.05.2007
LT 144 WDL 143 DAWBA DUS LIS 12:10 15:30
LT 145 WDL 143 DAWBA LIS DUS 16:20 19:40
Legs of 28.05.2007
TriStar500
Sat May 26, 2007 6:47 pm
Quoting Notarzt (Reply 2):
The domestic flights are chiefly flown with widebody equipment in order to position the A330 for the longhaul flights between the two main bases (DUS, MUC). The WDL BAe is only used on international city shuttles.
