SuseJ772
Interesting "New Mini-Wings" On The Dreamlifter
Wed May 30, 2007 12:23 am
I was looking at the "Top Photo" of today which was of the Dreamlifter and I noticed a "mini-wing" on the top of the fuselage about 3/4 way back. I checked out other photos, but didn't see it there. Is it new? Did they add this after flying around a bunch and realizing they needed extra lift?
Photo © Tony Marlow [Airplane-Pictures]
Photo © Peter Nickerson
Photo © Kris Baillie - Euroshots
Actually, now that I look at it. It seems all the photos that have these "mini-wings" on them are on the right side of the aircraft (or left, depending on how you look at it  Wink )
Photo © Martin Fenner
So what's up?
Currently at PIE, requesting FWA >> >>
smokeyrosco
RE: Interesting "New Mini-Wings" On The Dreamlifter
Wed May 30, 2007 12:26 am
They are hinges for opening her rear end
John Hancock
shamrock350
Wed May 30, 2007 12:27 am
If your referring to the bumps on the fuselage, they are hinges that open the back of the aircraft enabling it to swing open. That's how the 787 parts get in the aircraft.
steman
Those are not mini wings but simply the swing tail actuators!
Ciao
Stefano
atnight
Wed May 30, 2007 12:40 am
I'm not sure what are you talking about, I don't see any "mini-wing" on either side... I think you should double check a picture carefully next time..... the only thing that seems to be somewhat close to the direction you're talking about are the two fuselage hinges that are placed on the side to secure the swing tail, which wide opens to the left (if you look at the plane from behind).... is that what're you talking about? If that it's so, those are not wings, but again, the big swing tail hinges...
[Edited 2007-05-29 17:42:53]
B707 B727 B733/5/7/8/9 B742/4 B752/3 B763/4 B772 A310 A318/319/320 A332 A343 MD80 DC9/10 CRJ200 ERJ145 ERJ-170 Be1900 Da
Sketty222
Quoting Smokeyrosco (Reply 1):
SuseJ772, Smokeyrosco makes sense. If you look at the above, the photos without the 'mini wings' are taken when the aircraft is travelling from left to right. The photos with the mini wings are taken whilst the a/c is travelling form right to left.
This makes sense as in these would be the hinges where the rear end would open up
Lee
JRadier
Wed May 30, 2007 12:51 am
Quoting SuseJ772 (Thread starter):
sides of aircraft, boats, trains, cars and whatever are always seen from the direction of travel
