aeroman62
WN 737 Landing Gear Collapse In OAK
Mon Jun 04, 2007 8:50 am
Apparently a WN 737 had a landing gear malfunction, causing it to skid out on the Oakland runway at about 4pm today PDT. Anyone have details on this, I am stuck in ONT on an indefinitely delayed flight to OAK because of this, but the only information I can find is on a local TV stations site (KTVU, channel 2).
WeAreUnited
RE: WN 737 Landing Gear Collapse In OAK
Mon Jun 04, 2007 9:07 am
Just got off the phone with a friend..... don't really have details on this but...
She was on a flight (working) that was following the WN plane in.... and with the situation they ended up having to go around.
It sounds like a lot of people at the airport saw what happened and were kinda shakin up. She said everybody in the airport were talkin about it after she got off the plane to head to her layover.
I know this isn't any sort of 'factual' information but this is just what I heard from my FA friend.
It sounds as though it was the nose gear only that collapsed. Again- no confirmed info just what I heard from someone who saw the plane and heard some details from the pilots.
WeAreUnited
Mon Jun 04, 2007 9:12 am
OPNLguy
Mon Jun 04, 2007 9:14 am
KGO TV in Bay area is reporting that it was flight 3050 (SMF-SAN) and that it landed at OAK and the nose gear collapsed as it did so. No injuries. Aircraft is probably on their long runway (11/29, using 29), which would be closed for awhile. The delays are from having all their air carrier traffic having to use a shorter runway on the east side of the airport (09R/27L, using 27L).
71Zulu
Mon Jun 04, 2007 9:25 am
Look at the track coming into OAK
Clickable links only please!
OPNLguy
Mon Jun 04, 2007 9:54 am
71Zulu
Mon Jun 04, 2007 10:12 am
OPLN, what would be the dispatcher's duty after the nose gear problem was first discovered? I assume the pilots would contact you guys first right or would they go directly to maintenance?
3201
Mon Jun 04, 2007 10:36 am
I saw it live -- was out at Oyster Bay Shoreline with my wife, kids, and AltairF28. We weren't really paying too much attention, eating lunch at a bench, when we saw a WN flying by without landing, and figured it was a simple go-around, but weren't really sure why -- no one was holding in position, etc. We watched him do a pretty small pattern and come by and not land again, and at that point pulled out my little hand-held airband radio and poked around until we stumbled onto the WN company frequency. Heard the flight crew talking with MX cntrl and/or dispatch, discussing details of hydraulics, landing gear indicators, etc. He did several laps while they were troubleshooting it, and then came in to land. Main gear hit OK, little puffs of white smoke as any normal landing, but when nose went down it was clear it went too far and there was lots of the white smoke. We were blocked by the terminal building but at least knew there was no big fire, we'd have seen that. There were lots of sirens for the next 30-45 mins. Glad to hear everyone got out OK!
There was a WN 737-700 out holding short of the runway to depart, and he sat there for a very long time, at least 20 mins, after it happened, before eventually taxiing back towards the terminal via the runway. I'm not sure why he stayed out there so long, anyone know?
7 hours aint long-haul
OPNLguy
Mon Jun 04, 2007 10:46 am
I'm off on vacation, so this is a general response. When situations like this arise, that is, something that isn't a time-critical emergency (like a fire), the PIC contacts the dispatcher, and they discuss the issue and the options in dealing with it. We also have the comm ability to patch-in maintenance, as needed, to lend their expertise.
Some years ago, one of my SoCal-SMF flights called me up at about the halfway point to advise that he'd just lost his "A" system hydraulics. The aircraft was still flyable using the "B" system, and, of course, would have been out of service on arrival at SMF, where we use contract maintenance and not our own. Getting our own maintenance folks from OAK-SMF would taken awhile, and they might not know exactly what parts to take until they'd looked at the aircraft themselves. I sent the flight to OAK, and had plenty of time to set-up his being towed off the runway (this aircraft had nosewheel steering only from the "A" system). Our local ops had them towed off in a couple of minutes, and the airport never missed a beat, i.e. no holding. There as an aircraft swap was made and the folks went OAK-SMF, arriving about :40 behind their original ETA.
Landing nosegear up isn't "routine" in and of itself, but the method of how these and other situations is routine, i.e. you communicate and don't make unilateral decisions that might not be based on the latest info (like weather at diversion airports, etc. etc.). Dispatchers (at all airlines) are prepared to handle these kinds of situations at any time, just as pilots are, even if they don't do so every day.
Hope this helps...
OPNLguy
Mon Jun 04, 2007 10:57 am
Quoting 3201 (Reply 7):
Generally speaking, when there's an emergency on an airport, it doesn't necessarily end once the aircraft comes to a stop on the runway. There are emergency vehicles all over the place, and it takes a few minutes to assess the condition of the aircraft (hot brakes, any fire/smoke etc.). With an airliner fuselage obviously sitting on the runway, an aircraft isn't going to be moved within 15-20 minutes, and ATC probably needed a few minutes for things to settle down as they started working to get airline ops on 27R going. That runway is only 6,200 feet and change long, so there might have been some fuelstops made necessary due to the closure of the longer 29.
AirTranTUS
Mon Jun 04, 2007 10:58 am
That aircraft was to continue on from SAN to TUS-ABQ-MCI. WN has found a replacement aircraft that is currently en-route from SAN-TUS. It will be late, but at least the passengers will get where they need to go.
http://flightaware.com/live/flight/SWA8803
I love ASO!
LAXspotter
Mon Jun 04, 2007 11:07 am
Is there any restrictions for takeoff on 27L since its only 6200 ft. How long is 11/29 going to be shut down for?
"Patriotism is the last refuge of the scoundrel" Samuel Johnson
3201
Mon Jun 04, 2007 12:09 pm
Quoting OPNLguy (Reply 9):
Makes sense, I'd have thought they'd know certainly one place he didn't need to be was out there at an indefinitely-closed runway, but I guess that's a nice safe out-of-the-way place for him. It seems like one of the biggest problems using 27L, both from watching after the incident and from looking at the charts, is needing 1-way traffic on twy B, either inbound or outbound, between the 27's and the passenger ramp.
I didn't realize it was that short. Dunno which flight that was waiting, they certainly could have been unsure of whether they wanted to head straight to 27L or go back to a gate to offload payload and/or fuel if they were too heavy, and it certainly would be convenient for ground/tower to have one less tail to worry about while they sorted everything else out.
OPNLguy
Mon Jun 04, 2007 12:13 pm
Quoting LAXspotter (Reply 11):
Depends upon the overall weight of the aircraft, but short-haul flights should be OK, but longer ones might need to hop over to SJC, SMF, or RNO to take advantage of the longer runways there, until 11/29 re-opens that is.
I wouldn't be surprised if they have it cleared by the start of Monday morning's operation. Get a crane/sling and a flatbed, and tow it off to a maintenace area where it can then be jacked. I've got a video around of an Eastern 727-200 that made a nosegear-up landing at MIA, and that's how it went with that one, and some others I've seen.
OPNLguy
Mon Jun 04, 2007 12:18 pm
Quoting 3201 (Reply 12):
Yeah, I meant 27L. It doesn't make for a terribly efficient operation to use it, but when 11/29 is closed, it's not exactly like one has other alternatives, so you muddle through the best you can until 11/29 re-opens.
aeroman62
Mon Jun 04, 2007 12:28 pm
Well, we ended delayed only by about an hour in ONT, and had a fun experience landing on the shorter runway, though I suspect there are some less than happy people who are endearing noise from the adjusted approach pattern. As of 7pm, the plane was still out on the runway, and OAK was a mob scence inside, but things seemed to be moving. Don't know where Fed Ex and UPS are going to land their heavies, 6200 is tight for a MD11 or DC10 fully loaded.
OPNLguy
Mon Jun 04, 2007 12:35 pm
Quoting Aeroman62 (Reply 15):
...it'd be even worse getting them out of OAK using 27L.
I'm wondering if they'll be running the OAK flights split up between SJC and SFO just for tonight...
LAXspotter
Mon Jun 04, 2007 12:38 pm
Those need a minimum of 7000ft according to Wilco, the MD-11 FO at Lufthansa Cargo, it will be interesting what happens.
futureatp
Mon Jun 04, 2007 12:41 pm
My sisters ONT-PHX flight was delayed today because of this. She called me asked why her flight was delayed because of a problem in Oakland. I couldn't tell her as nothing hit the news that i could find but I told her that is probably where her aircraft was coming from and was probably just delayed getting out.
OPNLguy
Mon Jun 04, 2007 12:49 pm
Latest NOTAM says it'll be back open at 0600 local time...
A0221/07 (06/002) - RUNWAY CLOSED 11/29 04 JUN 08:30 2007 UNTIL 04 JUN 13:00 2007
ShannoninAMA
Mon Jun 04, 2007 12:52 pm
Anyone know what Reg it was?  Smile
Shannon
Shipwreck alert. Head on over to Airspaceonline.com.
3201
Mon Jun 04, 2007 1:03 pm
I saw a FedEx MD11 on final for OAK around 1800 local, confirmed by flightaware:
http://flightaware.com/live/flight/FDX963
UPS757Pilot
Mon Jun 04, 2007 1:06 pm
Luckily we've got only 1 scheduled departure, 767 OAK-PHL but it looks like it had diverted to SJC on the inbound . Not a problem on a Sunday night.
[Edited 2007-06-04 06:08:23]
QANTAS747-438
Mon Jun 04, 2007 1:14 pm
I believe it's N356SW, a -300.
futuresdpdcop
Ah man! I missed my chance to take off from the north field. Was scheduled to fly WN 220 (OAK-SAN) this evening. Canceled my trip up to the Bay Area this weekend however. It's probably for the best. Flight 220 is only delayed 10 minutes as of now. That could still change in the next 30 minutes though.
3201
Mon Jun 04, 2007 1:17 pm
Quoting OPNLguy (Reply 16):
Quoting LAXspotter (Reply 17):
Definitely NOT fully loaded... but depending on the slope and obstacle situation (neither of which I know), and the temperature, a DC10-30 may be able to do a 6200ft runway with 150k-200k lbs of fuel/payload, based on numbers here. For the MD11, that same source does indeed start at 7000ft min. There may be higher-fidelity data that extend lower, or maybe they just landed tonight with a tail that doesn't need to leave OAK until tomorrow after the runway is scheduled to re-open.
B52overSMF
Mon Jun 04, 2007 1:24 pm
Hmmm... I'm curious as to what the cause will end up being. I'll have to get in contact with one of my ramper buddies for WN at SMF and see what he hears. He may have even worked the flight!
airbuster
Mon Jun 04, 2007 1:25 pm
I find it strange they didn't do an emergency evacuation on the runway, the overwing escape hatches seem not to have been used.....when during your landing roll you have a gear collapse you don't know what other problems await you....at least when i get it in the sim it sure is a on ground emergency!
rgds.
AB
FLY FOKKER JET LINE!
skoker
Mon Jun 04, 2007 1:33 pm
Southwest claimed that the slides were used..., however, I didn't see any!!
Only a lowly ladder.
bayareablue
Mon Jun 04, 2007 1:37 pm
I was actually en-route to OAK on AS 425 from SNA. We aporached OAK in a different way that told me we were landing on North Field (27L). Upon landing, I caught the glimpse of the a/c with it's nose on the ground, emergency equipment everywhere.
Anyhow, it will be very interesting and busy tonight in OAK. The taxiway between the terminal and 27L only has one place where one a/c can step aside and let another pass. The heavies and those heading to the East Coast as red eye flights will not be able to make it out on 27L due to the length. They will have to take less fuel and divert somewhere else for a fuel stop. I remember last year while working at OAK, the 1:15 to JFK was running a little late and the Port was going to close 29 for an hour for some Maintinence. We were told that we needed to get the a/c off the gate by 1:50 so it could depart before the closure or else they would be there for a while since North Field was too short.
Thankful everyone was safe and great job to the pilots for keeping the a/c on the runway and in control.
3201
Mon Jun 04, 2007 2:49 pm
Quoting UPS757Pilot (Reply 22):
Flightaware shows it as having departed OAK, does anyone know if that is accurate?
This source indicates that a 767-300 with CF680B2C7F engines might depart at up to around 360 klb at sea level on a standard day from a 6200' runway, which should not limit it at all for an eastbound flight to PHL.
727forever
Mon Jun 04, 2007 2:51 pm
Quoting OPNLguy (Reply 13):
Would be interesting to see that video. My airline is still flying that airplane to this day.
727forever
727forever
ONTFlyer
Quoting Aeroman62 (Thread starter):
Aeroman, what flight were you on? I was scheduled for 234 but had to change plans literally as I walked into the terminal. Go figure...According to Flightaware it looks like it was only running about half hour behind though.
ONT
Doin' just fine thanks...
asuflyer05
Mon Jun 04, 2007 3:32 pm
The only flag stop I could find was JBU110 OAK-JFK which operated OAK-SLC-JFK. Though JBU476 OAK-BOS hasn't departed yet.
isp
Mon Jun 04, 2007 3:59 pm
JBU OAK-IAD redeye was also routed OAK-SLC-IAD
aeroman62
Mon Jun 04, 2007 9:26 pm
Quoting ONTFlyer (Reply 32):
ONT
I was on the 4:15pm flight, which operated with an inbound OAK/ONT flight, we left around 5:30pm, the poor WN employees in ONT knew less about what happened than the passengers, who got online and/or called people in the Bay Area, it was one of the passengers who told them it was one of their aircraft.
hiflyer
Mon Jun 04, 2007 9:51 pm
Best I can see from a picture out of the San Fran Chronicle looks like nose resting on nose gear door. #2 looks like on the ground...or damn close. Picture from Oakland paper appears to show a little clearance...whew! Can't tell if the reversers are fully stowed....wonder if they used them on landing?
http://www.sfgate.com/cgi-bin/object...c/a/2007/06/04/MNGLJQ755M1.DTL&o=0
http://www.insidebayarea.com/oaklandtribune/ci_6056877
MD11Engineer
Mon Jun 04, 2007 10:01 pm
Most airports have a set of aircraft recovery equipment (usually somewhere in the fire house), which consists of jacks, pneumatic cushions, planks, special towable cradles for the fuselage, a rhino jack etc..
In Europe special equipment to move a heavy aircraft, which had to do a belly landing is stowed at several major airports (e.g. the closest one to us would be in FRA). It is palletised and needs to be trucked over if needed. It contains special slings, dismanteable flat bed trolleys etc.. A crane would normally be contracted from an external hauling company if needed. If e.g. a jumbo or a A340 sits on it's belly on a runway, it would take time anyway to get the gear in.
Jan
altairF28
Tue Jun 05, 2007 1:09 am
They did about three or four go-arounds before they decided to send the ARFF equipment out, which surprised all of us (3201, his family and I) and then had to do another one while the apparatus got into place. Hearing the sirens for about 30 minutes after the incident made me think there were some injuries. At one point the pilot said he had enough fuel for "another couple of laps" so they were almost out when they landed. On the late news last night they said 11/29 was going to close overnight for maintenance anyway (like what BayAreaBlue was talking about) and expected to have it fully moved by then.
A detour is a choice between two tasks, each with its own pros and cons
flyinryan99
Tue Jun 05, 2007 1:19 am
Quoting Hiflyer (Reply 36):
My guess is not because the thrust reverse would cause the nose to come down. I would also think they cut the engines just after touchdown to try and minimize fod and fuel flow to cause a fire. Those are just my thoughts though.
OPNLguy
Tue Jun 05, 2007 1:30 am
Quoting AltairF28 (Reply 38):
No, they were not.
When a crew says something like this, they're referring to how much time (fuel) they have left before they need to land while still having sufficient fuel remaining. They were originally fueled for the SMF-SAN flight, and even with multiple approaches at OAK, they would have had plenty when they eventually landed there.
71Zulu
Tue Jun 05, 2007 2:01 am
Thanks for the replies OPLN guy and may you enjoy your vacation. Would love to hang out in the dispatch office one day.
Quoting Flyinryan99 (Reply 39):
Would this really be done? Kill the engines once on the runway? What about hydraulic pressure for the brakes? From the APU?
3201
Tue Jun 05, 2007 2:24 am
Quoting OPNLguy (Reply 40):
No, they were not.
I actually didn't think they were that low on fuel. They were probably racetracking over the bay for about 30 mins at 1000-3000 AGL (I'm a bad judge of heights) which should take a little less than half their planned trip fuel without eating into any of their reserve fuel. Assuming their takeoff, climb, and the path shown on flightaware for their diversion took no more than half of their planned trip fuel, that would indeed indicate that they had at least all their reserve fuel left when they landed, and in fact probably some of their trip fuel as well.
flyinryan99
Tue Jun 05, 2007 2:32 am
Quoting 71Zulu (Reply 41):
I honestly don't know the systems on the 737 so I couldn't tell you. I watched a Citation 650 do a nose gear up landing once and they killed the engines just as they touched down (it was at night so you could hear them). It's only a thought but I guarantee they didn't use thrust reversers as they would've wanted to have kept the nose off until the very end (ala soft field landing).
av8orwalk
Tue Jun 05, 2007 7:36 am
I just wonder how this did not end up on the news. The Cessna 310 that circled and landed gear-up in Tampa gained national news coverage. Was the time span too quick between the report of the emergency and the landing?
Drew
The safest place to be in an airplane crash is on the ground.
BigWNFan
Tue Jun 05, 2007 10:46 pm
Do we know for sure if it was N356SW involved?
flyinryan99
Tue Jun 05, 2007 11:58 pm
Quoting BigWNFan (Reply 45):
Affirmative.
Users browsing this forum: Alexa [Bot], blooBirdie, David_itl, eadc8, Eyad89, GloomyDe, hkcanadaexpat, Mani87, mjoelnir, MrHMSH, Revelation, sassiciai, SQ22, Thule, Tokushima, torks, Whoopeecock and 175 guests
