Cubsrule
Odd Runway Signage At STL
Tue Jun 26, 2007 12:41 pm
Near the end of 30L, there's a weird pair of signs on either side of the runway. They look like the signs that give the runway length remaining (approximately the same size and placement), but rather than a white number on a black background, they have a yellow circle on the black background. What are these signs? I've not seen them before.
adipasqu
RE: Odd Runway Signage At STL
Tue Jun 26, 2007 12:45 pm
Quoting Cubsrule (Thread starter):
Indicates the location of the BAK-12 arresting gear.
707 722 732 733 734 735 73G 738 739 741 742 752 753 762 763 764 D9S D10 319 320 321 M80 M82 M83 M87 M88 M90 SF3 ERJ CRJ
Cubsrule
Tue Jun 26, 2007 12:49 pm
That would explain why you don't see those signs much, wouldn't it? Thanks.
adipasqu
Tue Jun 26, 2007 12:53 pm
Quoting Cubsrule (Reply 2):
Correct. You would probably only ever see it at a joint use military/commercial airport.
OPNLguy
Tue Jun 26, 2007 2:08 pm
Quoting Adipasqu (Reply 3):
STL isn't a joint-use airport like CHS, ABQ, and YUM are, but they do have this little outfit on the NW side of the airport that makes F-15s....  Wink
KELPkid
Tue Jun 26, 2007 2:14 pm
Quoting OPNLguy (Reply 4):
Reminds me of one of my favorite videos from the Cold War era, I believe it was called "Eagle Country." On VHS, it had lots of shots of the McDonnel plant and Operation Red Flag up in Alaska...
OPNLguy
Tue Jun 26, 2007 2:35 pm
Quoting KELPkid (Reply 5):
Reminds me of one of my favorite videos from the Cold War era, I believe it was called "Eagle Country." On VHS, it had lots of shots of the McDonnell plant and Operation Red Flag up in Alaska...
Years ago, I was riding cockpit jumpseat on an Ozark DC-9, and we were position-and-hold on runway 06. There was a F-15 ready to go off one of the 12s, and they cleared him for takeoff. His takeoff roll was next to nothing in length, and he climbed out going straight up, and the DC-9's big eyebrow windows made for good viewing. The F-15 went to 10,000 feet and pitched over on his back, and then rolled 180 degrees, all within the airport boundary fence, and then he headed for McD's test area. Impressive as hell....
BHMNONREV
Tue Jun 26, 2007 4:35 pm
As you say, not a joint-use facility but the Missouri Air National Guard is a tenant there, flying those same F-15's which were made just across the field. But for how much longer is anyone's guess, they are slated to move under the latest BRAC...
chase
Wed Jun 27, 2007 12:12 am
Quoting OPNLguy (Reply 6):
Years ago
Yeah, my father recently told me about a time when he worked at Ozark, there was a Canadian Air Force a/c at STL for some reason. When departing, the pilot did a barrel roll *immediately* after takeoff, presumably "just because he could". Bet it was cool to see!
