andz
15 Injured During Turbulence On SAA Flight
Tue Jun 26, 2007 3:46 pm
From Beeld newspaper, original report in Afrikaans:
15 passengers on an SAA flight from Johannesburg to New York on Sunday were injured when the plane hit severe turbulence. Some passengers had cuts and bruises and had to be treated for shock along with 3 cabin crew members.
According to Robyn Chalmers of SAA, flight SA203 hit the turbulence about 30 minutes before a scheduled landing in Dakar. The flight landed in Dakar around 04:30 local time. The aircraft, carrying 172 passengers, was checked before departing for New York around 5 hours late.
Wear your seatbelt!!!
raffik
RE: 15 Injured During Turbulence On SAA Flight
Tue Jun 26, 2007 8:31 pm
You should always wear your seatbelt when seated, but at 30 minutes before landing, I bet there was the usual rush for the toilets (there always is!)
172 passengers isn't alot. Do they make a profit on these services?
- Alec
LXA340
Tue Jun 26, 2007 8:47 pm
Flights are probably operated by a A343 or do they still have 744's in the fleet?
andz
Tue Jun 26, 2007 8:58 pm
Quoting LXA340 (Reply 2):
There are still 744s but they mostly do JNB-LHR. This flight was a 343.
LXA340
Tue Jun 26, 2007 9:05 pm
Quoting Andz (Reply 3):
Thanks, yeah, then 172 passengers isn't such a bad load then.
Qantas744er
Tue Jun 26, 2007 9:20 pm
It is to prevent things like this that LH since over a month has their seatbealt signs always ON!
This is a new policy they introduced after a couple of the same incidents like from FRA to DFW...
leo
You live and you die, by the FMA
davescj
Tue Jun 26, 2007 9:26 pm
Quoting Raffik (Reply 1):
I would think. And the air can get choppy w/o warning.
Quoting Qantas744ER (Reply 5):
The whole flight? At least in the States, if the light is on, you're not supposed to get up for the WC even. How do they resolve that issue? Or is the light merely to remind people to wear seatbelt when not walking about the cabin?
PlymSpotter
Wed Jun 27, 2007 12:16 am
But that leads to complacency - with the pax not knowing when it's just meant to warn them to keep it fastened just in case, or if it's actually on for a very serious reason; such as a severe bout of upcoming turbulence.
Dan Smile
Analog
Wed Jun 27, 2007 1:12 am
This is a joke, right? Are they trying to convince people that the signs are meaningless and to ignore crew instructions, or are they handing out adult diapers?
jimyvr
Wed Jun 27, 2007 1:50 am
FLIFO for SA203 on 24JUN07:
DOSA203/24JUN
* OPERATIONAL FLIGHT INFO * SA 203 -2 SU 24JUN
CITY INFO HOUR LOCAL)
JNB LEFT THE GATE 2027
TOOK OFF 2038
PASSENGERS ON BOARD 11/198)
PLANE IS LATE IN HOURS MINUTES) 0130
SCHD GRND TIME LESS THAN MAX GRND TIME
PLANE IS LATE IN HOURS MINUTES) 0007
OTHER INFORMATION
550KG FLT SPARES
OTHER INFORMATION
550KG FLT SPARES
ESTIMATED TIME OF ARRIVAL 0223 DKR
ESTIMATED TIME OF ARRIVAL 0235 DKR
DKR ESTIMATED TIME OF DEPARTURE 0630
DELAY LATE ARRIVAL OF AIRCRAFT
DELAY DAMAGED AIRCRAFT - FLIGHT OPERATIONS
AIRCRAFT LANDED 0231
ARRIVED 0245
OTHER INFORMATION
550KG FLT SPARES
LEFT THE GATE 0850
TOOK OFF 0900
PASSENGERS ON BOARD 24)
PLANE IS LATE IN HOURS MINUTES) 0022
PLANE IS LATE IN HOURS MINUTES) 0558
ESTIMATED TIME OF ARRIVAL 1233 JFK
ESTIMATED TIME OF ARRIVAL 1220 JFK
Looks like it's more than 200 onboard when it hit turbulent.
1000 - 01MAR07 | http://airlineroute.blogspot.com/
Arcrftlvr
Wed Jun 27, 2007 11:30 am
That can't be right. I smell Bravo Sierra
andz
Wed Jun 27, 2007 2:38 pm
Quoting ArcrftLvr (Reply 10):
It isn't. I flew FRA-BCN-FRA on LH at the end of May and the announcement said to keep your belt on throughout the flight (not "we suggest") and the sign stayed on.
