mjzair
ATC - Callsigns
Wed Aug 09, 2000 4:09 am
While listening to ATC, I sometimes hear a letter designation after the call sign and number. For example:
Speedbird 150 Whiskey
or
Air Malta 110 Alfa
Why are some flights given this extra designation?
Aer Lingus
RE: ATC - Callsigns
Wed Aug 09, 2000 4:51 am
All I know is that callsigns such as "XXX 128F" (Foxtrot) identify a cargo flight
"XXX 128C" (Charlie) can sometimes mean an extra flight and Brittania uses the Alpha and Bravo endings to signify the outbound and inbound flight respectively
wjcandee
RE: ATC - Callsigns
Wed Aug 09, 2000 6:09 am
Sometimes when the airlines run an extra section, or when two different planes handle a flight bearing the same number through a hub, an "Alpha" is appended to the latter flight for ATC purposes. For example, if one flight is an hour late coming into a hub and the operations department decides to have it terminate there while they send its continuation out on time using a substitute aircraft (which would then originate with the same flight number while the inbound is still in the air), the newer flight may bear the same flight number with an A at the end, or some digits may be added to the beginning, just to keep them separate and eliminate the possibility of confusion.
--Bill
