1337Delta764
Santa Fe Airport (SAF) Upgraded To Allow RJs
Fri Jun 29, 2007 3:39 am
http://www.usatoday.com/travel/fligh...06-10-santa-fe-regional-jets_N.htm
Could this really be a major milestone for the Santa Fe Municipal Airport? SAF has been a rather neglected airport, with most people choosing to fly into ABQ instead. The only current service that SAF offers is on Great Lakes Airlines to Denver on Beechcraft 1900D aircraft. Pacific Wings subsidiary New Mexico Airlines intends on starting connection service from SAF to ABQ on Cessna Caravan aircraft, however, that route has flopped in the past when Mesa used to operate the route. While the Cessna Caravan may be more appropriately sized than the Beech 1900D for the route, the upcoming extension of the New Mexico Rail Runner Express may kill the route. I am pretty sure that fares for the Rail Runner will be much cheaper than any airfare to ABQ.
The City of Santa Fe envisions potential routes to Dallas and to Los Angeles on RJs. However, I personally believe that they should better advertise the airport before any new routes to major hubs begin. Currently, Great Lakes codeshares with United and Frontier on the SAF-DEN route, but if the service expansion turns out to be a success, United just might upgrade the SAF-DEN route to RJs.
Does anyone have any thoughts on this?
graphic
RE: Santa Fe Airport (SAF) Upgraded To Allow RJs
Fri Jun 29, 2007 3:41 am
That airport probably couldn't support anything more than 1 RJ a day to DEN or DFW.
Demand Media fails at life
Tornado82
Fri Jun 29, 2007 3:45 am
Quoting 1337Delta764 (Thread starter):
Considering it's DEN and codeshared with UA... a Dash 8 and/or E120 would be a better first step before the high CASM RJ's. As for DFW/LAX, is 8342' going to be long enough for an RJ at an airport that is 6348' high? Summertime density altitudes have to be insanely high.
Boston92
Fri Jun 29, 2007 4:08 am
Quoting Tornado82 (Reply 2):
Dash 8
No  no
E120
Yes  yes
"Why does a slight tax increase cost you $200 and a substantial tax cut save you 30 cents?"
1337Delta764
Fri Jun 29, 2007 4:14 am
Actually, UA considered that a few years ago, but those plans have seemed to have been abandoned. About a year later, Great Lakes Airlines considered ending the SAF-DEN service, but the city fought hard to keep it.
Didn't there used to be SAF-PHX service in the late 1990s? If the service expansion is a success, I wouldn't be suprised if the route would make a return. An SAF-SLC route on Delta Connection/SkyWest might also work.
FATFlyer
Fri Jun 29, 2007 4:42 am
ExpressJet is supposed to be starting SAF-LAX as DLConn. This thread has a post that it was already internally announced with the public announcement coming soon. See reply # 34
http://www.airliners.net/discussions...general_aviation/read.main/3469933
"Travel is fatal to prejudice, bigotry, and narrow-mindedness." - Mark Twain
Evan767
Fri Jun 29, 2007 5:27 am
Quoting FATFlyer (Reply 5):
Can't wait to fly on that, my family has always wanted to go to Santa Fe.
DesertAir
Fri Jun 29, 2007 7:14 am
Quoting 1337Delta764 (Reply 4):
America West ran this service.
FATFlyer
Fri Jun 29, 2007 11:47 am
Already loaded into DL's desktop schedule:
SAF-LAX DL7708 dep SAF 8AM arr LAX 9AM
LAX-SAF DL7707 dep LAX 6PM arr SAF 9PM
1X Daily Starting Oct 5
rw717
Fri Jun 29, 2007 2:59 pm
I smell a Lynx in the air!
Reno Air - The Biggest Little Airline in the World
N1120A
Fri Jun 29, 2007 5:19 pm
Yes, and just as fast
Absolutely. The CR2ER can do a standard day take off at MTOW from 5800'. DFW and LAX are both well within normal range capabilities of the aircraft, so you are not worried about needing a full load of fuel, and the 2500' buffer aids as well
Quoting Boston92 (Reply 3):
Dash 8
No no
E120
Yes
The problem there is that the Brasilia didn't do particularly well with the altitude in Denver. I am sure United would love to have OO operating for them otherwise.
doug_or
Fri Jun 29, 2007 5:24 pm
Quoting N1120A (Reply 10):
Yep. AFAIK all of OO's Brasilias have been withdrawn from DEN.
When in doubt, one B pump off
Tornado82
Sat Jun 30, 2007 6:37 am
A "standard day" takeoff and a takeoff at 6348' elevation on a 90 degree summer day are such drastically different things it's worse than comparing apples and oranges. They're both fruits and have at least that much in common.
You're talking a density altitude that will try to reach for 10,000 feet on the hottest of days at SAF. For instance right now (3:26p MDT on Friday the 29th) they're at 9200' DA. Your figures for the CRJ are SL and ISA. That means the density altitude is ZERO. Airplane performance changes drastically between a 0' DA and 9200' DA.
The CR2 is well known as a runway hog, and that 5800' number is irrelevant to any airport with elevation. Look around here and you'll see a plethora of comments about CRJ's in the Rocky Mountain region being penalized, and those are at airports alot lower than SAF. Someone with intimate knowledge of the CRJ can tell us more, but I'm willing to bet good money that a CRJ is NOT going to be penalty-free out of SAF in the summer, and even the "hot rod" ERJ-145XR has to be cutting it close. I'll be interested to see what the guys from ExpressJet have to say about theirs too once it is up and running.
CV880
Sat Jun 30, 2007 6:55 am
In addition to the LAX schedule, there will be 2 SLC departures, one each for OO & XJet/ CRJ & ERJ
N1120A
Sat Jun 30, 2007 6:31 pm
Quoting Tornado82 (Reply 12):
I realize they are two different things and that the CR2 is a runway hog, but LAX-SAF is only 617nm. The aircraft needs nowhere near a full fuel load to make that flight, which significantly mitigates restrictions of economic impact.
DeltaMIA
Sun Jul 01, 2007 1:36 am
There will also be an ATL flight.
It's a big building with patients, but that's not important right now.
EXAAUADL
Sun Jul 01, 2007 1:48 am
Quoting FATFlyer (Reply 8):
Bad timings..this market will be LAX POS..should be like LAX 0900 SAF 1200
SAF 1230 LAX 1330
I can see the potential for service to/from DFW, DEN, SLC,PHX, LAX
EXAAUADL
Sun Jul 01, 2007 1:50 am
Quoting DeltaMIA (Reply 15):
Youre kidding...I think DL might be overdoing it...SAF is like so many other cities located close to a large successful WN station. It wil lbe tough to get people to change their habits and fly from SAF versus driving from/to ABQ
1337Delta764
Sun Jul 01, 2007 2:01 am
Does a CRJ-200 have the range? I don't know if Delta would be able to fill a CRJ-700 on the route. Delta seasonally flies 757s on ABQ-ATL, but I don't know if passengers would really be willing to fly to Santa Fe from Atlanta.
SLC is quite a possibility, and so is PHX. Maybe CO could make an SAF-IAH route work.
DeltaMIA
Sun Jul 01, 2007 3:26 am
Quoting EXAAUADL (Reply 16):
SAF 1230 LAX 1330
Not if the XR goes to ATL in between
commavia
Sun Jul 01, 2007 3:32 am
I think that AA Eagle doing 2x daily ERJs DFW-SAF would be quite successful, especially with the ski traffic during the winter.
Evan767
Sun Jul 01, 2007 3:33 am
I would definitely fly ATL-SAF, always wanted to go there.
flyingcat
Fri Jul 13, 2007 11:31 am
Sorry to burst your bubble but it is not happening at least not until SAF has a chance to prove what traffic it can build.
N1120A
Fri Jul 13, 2007 3:03 pm
Quoting 1337Delta764 (Reply 18):
If DL can be successful to any station from any station, it is ATL because of the sheer hub presence there. Still, I would doubt the CR2's range on that route, as it is more than 400nm longer than out of LAX.
Quoting EXAAUADL (Reply 17):
Not only that, but the Railrunner has a station near ABQ, which will make things all the easier
