cardiffairtaxi
Landing In Heavy Fog At LHR
Sat Jun 30, 2007 11:59 pm
Check this video out.
Full autoland i guess!
http://www.liveleak.com/view?i=5f0_1183152276
OPNLguy
RE: Landing In Heavy Fog At LHR
Sun Jul 01, 2007 12:34 am
The guy who uploaded the video described it as "scary" but it looks rather routine. They have the approach lights in sight at 200 feet AGL and the approach lights and runway end in sight at 100 feet AGL.
Don't believe it was an autoland, as in CAT-IIIc approach, since there is no decision height (DH) for those and the robo-voice clearly states "100 above", "Minimum", and "100", the "100 above" meaning they were at 200 feet AGL or 100 feet above their 100-foot AGL minimum.
At my outfit, we have HUDS and hand-fly CAT-IIIa approaches down to RVR 700, so I've seen these on jumpseat rides, and it doesn't take away the PFM (pure freaking magic) of being able to land in such conditions. Great video!
BA777
Sun Jul 01, 2007 12:35 am
Nice video, though it isnt a 737 as the videographer claims.
cardiffairtaxi
Sun Jul 01, 2007 12:37 am
I suppose you like these landings,just for a bit of a challenge,from the everyday normal conditions.?
mcdu
Sun Jul 01, 2007 12:47 am
Quoting OPNLguy (Reply 1):
Sorry OPNLY but the world is different out side of a 737 and SWA. If you listen to the video you hear "100 Above" and "minimums" immediately afterwards. That was a 100' above TDZE approach handflown as the Dual A/P engaged lights were not illuminated. The only light on the MCP was the Auto-Thrust light engaged. One interesting fact about the bus is it calls "retard", "retard" whether the Autothrust is engaged or not. It is a real pain when hand
OPNLguy
Sun Jul 01, 2007 1:16 am
Quoting Mcdu (Reply 4):
Thanks, but I'd already long since figured that one out for myself...  Wink
I went back and listened to it again a couple of times and used the video's time counter as a reference. It's not "100 above" and "minimums" that are heard immediately afterwards, but rather "minimum" and "100" that are 1 second apart:
"500" callout at :08
"400" callout at :18
"300" callout at :26
"100 above" callout at :35
"Minimum" callout at :43
"100" callout at :44
Since their descent seems to be (based on the callouts) about 8-9 seconds for each 100 feet, the "100 above" callout would appear to be 9 seconds after the "300" callout, thus suggesting an altitude of 200-feet AGL, and thus 100 feet above their minimum. The "100" callout at :44 seconds is 9 seconds after the "100 above" callout, which, time-wise, also suggests it was 100 feet after the 200-foot point.
Accordingly, and with all due respect, I stand by my original statement..  Wink
DualQual
Sun Jul 01, 2007 5:56 am
Just to clear up a few things, OPNLguy is correct, it is not a CATIIIc approach. That would require autoland with rollout guidance and the weather was well above requiring that. Also, as he pointed out "Minimums" is called out above 100' AGL. In any CATIII approach the minimums are below 100' (50'). It could have been an autoland, I don't fly the bus so I have no idea what the configuration looks like or how the annuciations may differ. You can however, autoland out of any catagory of ILS approach (CATI, II, or III). My guess is they set up for a CAT II approach. Those have decision altitudes above 100' (which was annunciated) but below 200'. Given the time between "Minimums" and "100" that is my guess. I have devoted too many brain cells to this already.
There's no known cure for stupid
mcdu
Sun Jul 01, 2007 8:37 am
Quoting OPNLguy (Reply 5):
Still disagree. The mins and 100 being one second apart are because the machine has to process the words. If you look at the lights and the glow of the lights they are in sight at around 200'. As an operator and not a jumpseat driver I stand by my original post. Hand flown CAT I with 100' set in the Perf page for landing.
DeC
Nice video, thanks for sharing! Isn't that an A320?
DEC
OPNLguy
Sun Jul 01, 2007 8:42 am
Quoting Mcdu (Reply 7):
Roger that...
BALandorLivery
Sun Jul 01, 2007 5:49 pm
It had to be an autoland as there was no sound or visual alert to show that the autopilot was disconnected.
That is, if it were engaged prior to the video commencing.......
[Edited 2007-07-01 10:53:09]
BALandorLivery
Sun Jul 01, 2007 5:56 pm
Sounds about right but with a Cat I DH is normally 200 feet. Cat II DH is 100 feet but CAT II has to be an auto approach.
At least, thats the way we do it.
Something does not quite add up I think..............
[Edited 2007-07-01 11:02:07]
LXA340
Sun Jul 01, 2007 7:22 pm
Didn't LHR experience a simmilar situation at some point last year I think it was just about before Christmas and the Airport was almost completely shut down for days or at least only partially operating. I though if you make the landing with thr Autopilot you could always land no matter how thick the fog is?
Vir744
Sun Jul 01, 2007 7:25 pm
With regard to the "Minimums" and "100" calls, I thought that if the decision height was set at a round hundred feet figure it would override the hundred foot callout so if the decision height was set to 100' it would not have called "100'". If the DH was set at 110' then it would call "Minimums" and "100'". The other alternative is that minimums may have been set to MDA referenced to baro altitude.
I believe this is how the GPWC is set in terns of auto callout priorities.
Not flying these for a living a don't get a first hand experience of it, but from a maintenance experience I'm sure that's what it says in the books.
BigJimFX
Sun Jul 01, 2007 7:54 pm
OK.... well considering there wasn't an alarm for the disconnected A/P after touchdown... Not to mention someone calls "in sight"... I'm betting it's hand flown. Pilots flying single engine planes with an instrument tickets are right there...Plus there is actually like 7 seconds from the "100 above" and "minimums" Call out... Am I watching the same video?.... I clicked on the link... Maybe my net's on the fritz.
I'm not gonna argue with differing regs between UK and US because the similarities are 8 letters. But once a member of the flight crew calls "In sight" it's all good. The key to most Precision/Non-Precision approaches is the fact that you need to see the airport environment to continue below minimums.
I'd like to thank me for flying Me Airways...
flylku
Sun Jul 01, 2007 9:44 pm
That approach looked rather routine to me with the runway environment in sight at the "100" call out. I was a passenger on a UA 767-300 going into BRU and made it a point to look for the runway when we touched down. I felt the mains touch as the runway came into view. I went up on the flight deck later and the pilots confessed that it was the lowest any of them had gone outside the simulator. They said it was of course a CAT III approach and that at the "40 feet Auto Flair Engaged" call out and they could not see anything.
They also pointed out that their biggest concern was not getting the plane on the ground safely but getting it to the gate without incident. We may have had a "follow me" car for the taxi. I don't remember.
...are we there yet?
flylku
Sun Jul 01, 2007 9:58 pm
I wonder if Mcdu and OPNLguy disagree as much as they think? It looks like CAT I conditions (though barely) on an airplane setup for a CAT II approach.
jamesbaldwyn
Sun Jul 01, 2007 10:01 pm
For the first 10 seconds it looks as if they could be thousands of feet in the air!
Thanks for sharing  Smile
irobertson
Sun Jul 01, 2007 11:07 pm
Quoting Jamesbaldwyn (Reply 17):
Exactly my thoughts! I thought the video was going to be longer because when I saw the tops of the clouds I thought, oh we're just starting our descent. Then the computer said "500" and I thought WHAT!? What a great landing and great video. Kinda makes me wanna go to flight school.
SailorOrion
Sun Jul 01, 2007 11:35 pm
CAT II and CAT III approaches are "autoland" normally, even though there are some exceptions (like LH's CRJs with HUDs).
CAT IIIc is afaik not certified at any airport in the world for commercial operations. IIIb is at good as it gets (no DH, 150ft RVR)
SailorOrion
Skyweasy82
Mon Jul 02, 2007 12:00 am
Correct me if I am wrong by heard on of the crew members say runway in sight just before 100 feet.
flylku
Mon Jul 02, 2007 1:15 am
Quoting SailorOrion (Reply 19):
SailorOrion:
Please take a look at the following link which is a PDF of the approaches at JFK and scroll down to page 12 which shows the ILS 22L CAT III approaches. There is a Cat IIIc listed at the bottom of the plate and I believe the NA means "Not Applicable" and not "Not Authorized".
I stand corrected. I checked the abbreviations section of the Terminal Procedures: N/A is Not Applicable and NA is Not Authorized.
JFK/IAP/all/pdf" target=_blank>http://flightaware.com/resources/airport/JFK/IAP/all/pdf
[Edited 2007-07-01 18:33:47]
[Edited 2007-07-01 18:34:22]
mcdu
Mon Jul 02, 2007 1:20 am
Quoting BALandorLivery (Reply 10):
No, AP was not engaged. On the MCP you can clearly see the A/T light illuminated. Had it been coupled you would be able to see both the A/P lights just above the A/T light. That is the reason for no "chirp chirp" of the A/P disconnect. The bus is really easy to fly and doing a handflown CATII is not legal at my company I am guessing this was an approach that was pretty close to CAT I limits and they were legal to hand fly. Besides, that is more fun than watching!
SailorOrion
Wed Jul 04, 2007 6:15 am
Quoting FlyLKU (Reply 21):
Good. I'm not the only one who gets confused by NA and N/A  Smile
What would be the point of CAT IIIc anyway? Unless someone finally gives airlines a way to find their gate in zero visibility, you can do exactly N CAT IIIc approaches at a given airport, with N being the number of CAT IIIc-read runways.
SailorOrion
irobertson
Wed Jul 04, 2007 1:15 pm
Quoting Skyweasy82 (Reply 20):
That's because you CAN see the runway at 100 feet. It's impressive but I'm guessing poor video camera quality or YouTube conversion made it harder to see than it actually was.
