Lumberton
I L F C Orders Trent 1000s For 40 787s
Sat Jul 07, 2007 10:27 pm
Just reported in Flight:
http://www.flightglobal.com/articles...0-ilfc-boeing-787-dreamliners.html
40 aircraft of 72.
Note the timing of the deliveries, 2010 through 2017....
[Edited 2007-07-07 15:31:37]
"When all is said and done, more will be said than done".
PM
RE: I L F C Orders Trent 1000s For 40 787s
Sat Jul 07, 2007 10:53 pm
How interesting. ILFC have 95 A330s on order and their preferred engine is the RR Trent. Does this suggest that the 787 will go the same way?
So far ILFC have placed 9 787s.
Aeromexico (3) and Air Seychelles (2) have taken GE.
Fluglobespan (2) have gone for RR.
Royal Jordanian (2) haven't yet chosen an engine.
So ILFC are putting their money on RR? Is this because GECAS are about to order a significant number of 787s with (yawn) GE?
cricket
Sat Jul 07, 2007 11:10 pm
I guess most carriers deal with both ILFC and GECAS, but GECAS preference for GE powerplants (I wonder if GECAS gets a good deal from GEAE?) could imply that ILFC favours RR.
My two paise only!
A300B2/B4/6R, A313, A319/320/321, A333, A343, A388, 737-2/3/4/7/8/9, 747-3/4, 772/2E/2L/3, E170/190, F70, CR2/7, 146-3,
baroque
Sat Jul 07, 2007 11:59 pm
Quoting Cricket (Reply 2):
The GECAS preference for GE engines presumably means that those wanting Pratt or RR means that they will be herded off to the other lease companies. Given that the P and R engines are reasonable, that presumably results in the other leasing companies having a preponderance of P and R engines or am I missing something?
Presumably it is a closed data set.
Lumberton
Sun Jul 08, 2007 12:29 am
Quoting Baroque (Reply 3):
Not to be flip, but there is a reason why GECAS is the second largest lessor of commercial aircraft in the world. I suspect they know what they're doing.  Wink 60 A320s at Le Bourget last month is not a small order. Didn't the head of GECAS remark that they didn't order aircraft "speculatively"? We can only speculate as to what their plans for the 787 are....
Unless, the customers demand CFM / GE!
lightsaber
Crew
Sun Jul 08, 2007 1:56 am
Quoting PM (Reply 1):
RR nailed the A330 engine. Pratt did too.. on the PW4168. Ugh... you don't know how frustrated the engineers were on the PW4172! We would have had the best fuel burn.  hissyfit
But that doesn't stop me from appreciating how well RR did on that airframe.  bigthumbsup
I find it very interesting ILFC went pure RR... This is going to drive quite a few of their customers to the Trent 1000... so quite a win for RR.  Smile Both lease companies are very smart... don't bet *against* either.
With this order, RR will have "economy of scale" in maintenance of the Trent 1000... that's very important. Why? Until 400+ engines are out there, it isn't worth it to invest in engineering upgrade kits. Customers, leasing companies, and most engineers in the propulsion market know about this "rule of thumb." So now RR can turn a profit doing improvements on the engine.  Smile (Yes... GE is there too...) These economies of scale are one reason that once GE fell behind on the A330, they couldn't catch up. So the 787 will have an engine horse race for a long time.  Smile
Lightsaber
baroque
Sun Jul 08, 2007 2:50 am
Quoting Lumberton (Reply 4):
But presumably in % terms, most those who wish the CFM/GE are going to go to GECAS leaving the others with other leasing companies.
It does not mean that some might not lease through GECAS but the non GE folks are surely going to sell more engines through non-GECAS avenues.
Looking at it another way, does GMAC lease many Fords?
baroque
Sun Jul 08, 2007 3:00 am
Quoting Lightsaber (Reply 5):
The 400 is magic without your knowledge. However, the concept you outline is fascinating but its inverse is a bit puzzling. I can see that at some number (400 is as good as any) they would have more money to upgrade. However you would think that if they could not manage the magic number there was even more reason to improve the engine so that it sells better.
The concept outlined almost suggest if you spend to launch an engine, and then if it does not reach X sales, then you more or less cut it adrift. I find that puzzling. I can see why sinking money into a loser is not a great idea, but it would have been a bit early to have considered either of the 787 engines a loser.  worried
lightsaber
Crew
Sun Jul 08, 2007 3:15 am
Quoting Baroque (Reply 7):
GE did the upgrade without the numbers to justify it on the GE-90. So you are correct; there are exceptions.
However, with 400+ engines in the field, airlines *refurbishing* their engines will make the upgrade kits profitable for the engine maker *without* additional orders.  Smile
So it is a business decision. For example, I think Pratt was stupid not pursuing the PW4172 more.  cry  I also thought it was crazy for GE to invest so much in the GE-90... but it turned out to be "crazy like a fox."  Wink
Neither 787 engine is a loser. Both are achieving economy of scale. Both will sell for years in the future. I do see clear markets where one is better than the other (hence this thread). However, I expect the 789 engines to receive quite a bit of upgrade. Yes, the most modern engines on the planet *must* be upgraded to stay competitive! I love it!  bigthumbsup  (if one upgrades and the other doesn't... the orders will shift to the upgraded engine).
What can be upgraded on them? Both GE and RR has much better IBR compressors ready. RR will probably change the fan material. (its not that hard... The 94" PW4000 went through 4 fans.) Much of the "improvement" will be optimizing what's already there. (Blade shape, cooling pattern, etc.) Every iteration of the 787 is going to restart this horse race. And I don't believe for a second that GE won't compete against the 777 on another airframe. Eventually it will be time "to eat the young" as must happen in all heavy R&D industries.  Smile I wonder if there is a non-compete clause in the 777 contact... but those clauses *always* have expiration dates.  scratchchin
Lightsaber
Lumberton
Sun Jul 08, 2007 6:15 am
AFAIK, this is the first time. They have specified GENx on 20 others; 13 airframes still are undecided.
vv701
Sun Jul 08, 2007 6:57 am
They have not. Two of their customers have gone for GE engines:
and, with 72 aircraft on order there are some that they have not yet committed to either RR or GE.
With this order, RR will have "economy of scale" in maintenance of the Trent 1000... that's very important. Why? Until 400 engines are out there, it isn't worth it to invest in engineering upgrade kits.
On the Rolls-Royce web site their latest Press release - their is none mentioning the ILFC order as yet - says:
'over 500 Trent 1000 engines [have been ordered] by 15 operators and three leasing companies'
qqflyboy
Sun Jul 08, 2007 9:17 am
I say they went with RR because those 40 frames are for AA.  stirthepot
The views expressed are mine alone and do not necessarily reflect my employer’s views.
lightsaber
Crew
Sun Jul 08, 2007 9:42 am
Quoting Lumberton (Reply 9):
Aaagh... I am corrected. Thanks.
Quoting QQflyboy (Reply 11):
Leased?
I believe AA will order the 787. Due to their route structure... the Trent 1000 would make sense. But AA likes to buy, not lease. However... "cashflow issues" might force a lease...  scratchchin
It will be fun to find out who these are for.
Lightsaber
DeltaAVL
Sun Jul 08, 2007 10:34 am
Did anyone else initially read this as "I L F C Orders 1000 787s"?
I almost fell out of my chair.  bouncy
"We break, We bend, With hand in hand, When hope is gone, Just hang on." -Guster
PM
Sun Jul 08, 2007 11:06 am
Quoting VV701 (Reply 10):
Just to be a nit-picker, it was 'four' leasing companies. (ILFC, CIT, Peagus and LCAL.)
By the way, and pace some posts above, I don't see any way that ILFC would ever put all their eggs in one basket. Both GE and RR can expect continued business on the 787 from SUH.
lightsaber
Crew
Sun Jul 08, 2007 1:06 pm
Quoting PM (Reply 14):
My bad.  blush
But on the 787... it matters less. One engine one day... the other the next. How/if the engine swaps work will be very interesting.
Lightsaber
PM
Sun Jul 08, 2007 1:24 pm
Quoting Lightsaber (Reply 15):
I wonder if it will ever happen - or happen much. Some good ideas don't seem to work out in practice. (Remember the 777's folding wings?)
I'm thinking of the equivalent of AA taking over TWA's fleet of 757s. AA have RR. TW had PW. So they've had a mixed fleet for a while but, as far as I know, the TW/PW fleet is set to be disposed of over the coming months. Had the engine change option been available this would seem the kind of circumstance when it would happen. i.e. AA would have replaced the PW2000s with RB211s. But would they? Would the cost of acquiring the engines and hanging them have been worth it?
The other scenario is a 787 changing hands relatively early in its life and going from an operator of engine A to a big engine B fleet. Then I can see the engine switch happening. But that kind of thing doesn't happen much. Very few 777s have changed hands, for example, and I can't think of any major 777 operator who has taken odd planes into its fleet with the "wrong" engines.
I guess that leaves us with leasing companies. ILFC place a 787 with customer X for three years and then move it on to customer Y - who wants the 'other' engine. Think of the two 777s that flew for a few years with Aeroflot. Once they were built with GE90s then that's what they are going to have for all time. ILFC wouldn't be in that position on the 787.
I may be wrong (heck, it's going to have to happen some day) but I just wonder if the option to switch engines will end up being terribly significant in practice.
I suppose it will give all those GEnx customers the chance to correct their mistake...  duck
baroque
Sun Jul 08, 2007 5:15 pm
Quoting PM (Reply 16):
Well at least the easy interchange on engines has a fair chance of flying better than the folding wings!
I hope I am not taken to imply that ILFC would ever buy GEs, just that with one of the opposition more or less tied to GE, it would hardly be surprising if the opposition turned up more than overall % on the ILFC planes.
Interesting lines as to where improvements are likely La. How will we know of updates? Can we ask in advance to be updated when either of the donks gets a makeover. Pretty please!  Smile  Smile
PM
Sun Jul 08, 2007 5:47 pm
Quoting Baroque (Reply 17):
Actually, the GE90 is by far ILFC's preferred engine on the 777.  Sad
donks
"donks"??  Confused
Tristarsteve
Sun Jul 08, 2007 5:59 pm
Quoting PM (Reply 18):
"donks"??
Old British RAF slang for an aircraft engine.
PM
Sun Jul 08, 2007 7:11 pm
Quoting TristarSteve (Reply 19):
Huh. Never heard that one before. Thonks!
amirs
Sun Jul 08, 2007 7:35 pm
The main reason being that 77L and 77W are only available in GE. Even if a carrier orders 772ER, they will probably want to order GE so that in the future they can easily order 77W and 77L an keeping the same engines.
BTW - Are we going to hear today for who those 787 are for?
PM
Sun Jul 08, 2007 7:53 pm
Quoting Amirs (Reply 21):
That would make sense but it's not the reason. ILFC's preference for GE on the 777 was established before the 77W and 77L were even launched. ILFC have 33 777-200ERs with GE and most were ordered more than 10 years ago. They have 6 with PW and 4 with RR.  Sad
Out of interest, GECAS ordered 4 (!) 777-200ERs (with GE of course) compared to 33 with GE for ILFC.
In fact, in total GECAS have ordered 39 777s (all models) and all with GE. ILFC have ordered 79 777s (all models) and 61 have GE.
baroque
Sun Jul 08, 2007 9:31 pm
Quoting PM (Reply 22):
I did say it would be hardly surprising if.... which allowed the odd reversal. Not training for politics but.... It was wording that our nice Mr Howard himself would have been proud of. The point still remains, that if GECAS are pulling GEs preferentially, you would expect a good chance of ILFC going another way.
Yes, you have the donkey at the front pulling. Common Aus slang too for the motor in a motor car. Never mind PM soon we will soon have you able to Ajax your carby (hope I have that correct, if not someone will sharp correct me).
lightsaber
Crew
Mon Jul 09, 2007 12:17 am
As you noted, the engine change option will most likely be implemented by the leasing companies. How often? Not very. But it isn't unheard of for the airframe with the "wrong engine" to be worth 20% less then one with the "desired engine." That's enough, after scrapping the nacelle and engine for their part values, to easily pay for the other engine. I think it will happen... but when? How often?
 rotfl
I like the fact this brings the 787 back to being a true "horse race."  spin
Lightsaber
Lumberton
Mon Jul 09, 2007 12:42 am
Quoting Lightsaber (Reply 12):
My guess is that these are for AA or BA, but I would like to be proven totally wrong and see them go to UA!
Both AA and BA are confronting "challenges" from their labor forces at the moment, so leasing may be preferred.
