edelag
American Operated By Alaska
Sun Jul 15, 2007 7:42 am
This Thursday I will be flying MTY-DFW-SNA-SEA, it was a bit cheaper to fly this route instead of DFW-SEA, and quite frankly I don't mind it. Its all AA except the last leg. SNA-SEA.
I will be flying on AA 7119 or AS 481.
When I arrive to SNA will I have to get out of the terminal and the security zone to check in, or can I do it in the gate? Or will I have a boarding pass issued in MTY by AA?
And secondly if my flight DFW-SNA gets delayed by AA's fault and I miss my connecting flight in SNA, will I have to go to AA customer service or AS customer service to get into a later flight?
Thanks in advance,
Edelag
It's not just the destination, it's the journey.
pdxcof9
RE: American Operated By Alaska
Sun Jul 15, 2007 7:56 am
You should get a boarding pass for all your segments in MTY. In SNA it's all one terminal so it's easy to connect. AS and AA are fairly close to each other gate wise. If you don't have a boarding pass in SNA issued by AA, AS can easily issue you one. I did a AA to AS transfer in SJC and AA issued a ticket all the way through.
If your flight from DFW is delayed you can probably talk to either one. But AA is most likely going to help you out because they delayed you.
Flown:733,4,7,8,752,763,TU3,CRJ,7,EM2,ER3,4,318,19,346,M80,90 Worked:CRJ,7,9,EM2,ER4,733,5,7,8,9,752,3,318,9
edelag
Sun Jul 15, 2007 8:01 am
Quoting Pdxcof9 (Reply 1):
Thanks that's all I needed to know. Thanks again.
AirframeAS
Sun Jul 15, 2007 8:02 am
Quoting Edelag (Thread starter):
SNA-SEA
AS
Just go to the gate. Your bags will be checked all the way through.
Go to AA's customer service and they will help you there since, in your scenerio, it would be their fault.
Venezuela747
Sun Jul 15, 2007 11:45 am
Your bags should be checked all the way....if you do not have a boarding pass, you can still get one from AS at the gate, so just head over to the AS gate without leaving security
ROLL TIDE!!!
FLY777UAL
Sun Jul 15, 2007 11:50 am
Quoting AirframeAS (Reply 3):
...and, as it is booked as a codeshare PNR (in AS' reservations), any changes must be made through the ticketing carrier (AA).
F L Y 7 7 7 U A L
AirframeAS
Sun Jul 15, 2007 4:11 pm
Quoting FLY777UAL (Reply 5):
I left that out. Thanks, FLY777UAL. My bad!
edelag
Mon Jul 16, 2007 1:32 am
Thanks guys, I wasn't going to start this thread and just go to the airport and see what happens. But in A.net, any question can be answered.
Thanks for the 5th or 6th time.
Matterhorn
Mon Jul 16, 2007 2:03 am
hi guys,
just another question which goes in that direction: i will be flying LAX-SFO on AA Metal, but i purchased an AS- Ticket..
Where do i have to check in? on a AA counter or AS counter? or are they using the same terminals/ check in counters at LAX?
Last Flight: BSL-AMS on EZY, Next Flight: ZRH-LHR on LX
socalatc
Mon Jul 16, 2007 2:19 am
Quoting Matterhorn (Reply 8):
You will check in with AA terminal 4. AS is in T-3.
AirframeAS
Mon Jul 16, 2007 6:52 am
Like Social said, T4 with AA. AS does not do LAX-SFO service.
ONTFlyer
Mon Jul 16, 2007 9:30 am
Quoting AirframeAS (Reply 10):
I'm booked on AS 105 Aug. 14. and AS 102 for the return the next day. Is that not on AS metal? Just want to be sure.
ONT
Doin' just fine thanks...
FLY777UAL
Mon Jul 16, 2007 9:44 am
Quoting ONTFlyer (Reply 11):
ONT
You're correct, ONT...you will be flying on AS for both of those flights. AS operates two dailies between LAX and SFO, the morning AS105 and the evening AS277 (with the reverse as morning AS510 and evening AS102).
F L Y 7 7 7 U A L
AirframeAS
Mon Jul 16, 2007 9:53 am
Looks like it is on AS metal, Im really surprised by that. Two flights a day. Yet the routemap doesn't show it. Thats new to me. But I've always known that AA does the route on their metal.
Edit add: I think the route map on Alaskaair.com is old. They need to update it.
[Edited 2007-07-16 03:19:23]
FLY777UAL
Mon Jul 16, 2007 10:08 am
Quoting AirframeAS (Reply 13):
AS105 continues to SEA as AS 399, the 9:03a departure.
AS277 is a thru flight from SJD...sits on the ground in LA for roughly 2 hrs before continuing.
F L Y 7 7 7 U A L
socalatc
Mon Jul 16, 2007 2:32 pm
Yes they do. Flt 105 which continues to YVR then ANC and 277 which is a continuation from SJD.
ONTFlyer
Mon Jul 16, 2007 2:47 pm
Quoting FLY777UAL (Reply 12):
Thanks for that info!
ONT
