Alitalia744
Delta Plugging 737NG Windows?
Tue Jul 17, 2007 5:14 am
Any DL mechanics out there that can help out with this one - has DL started to plug up the 737NG eyebrows?
Photo © Oleg Shiryayev
Some see lines, others see between the lines.
by738
RE: Delta Plugging 737NG Windows?
Tue Jul 17, 2007 5:22 am
They woudnt be the first.....
727LOVER
Tue Jul 17, 2007 5:28 am
I rather see winglets on the damn thing! Is DL the only US carrier without winglets on the 737-800?
"We must accept finite disappointment, but never lose infinite hope." - Martin Luther King, Jr.
flytuitravel
Tue Jul 17, 2007 5:34 am
I may be a little slow here but why do airlines plug the "eyebrows"?
Whats the point ?? It's just a few windows...
FLYTUITRAVEL.
panamair
Tue Jul 17, 2007 5:36 am
Quoting 727LOVER (Reply 2):
DL will start installing winglets on 28 738s starting in late summer/early fall.
albird87
Tue Jul 17, 2007 5:37 am
Quoting FlyTUITravel (Reply 3):
may save weight??
belizexp
Tue Jul 17, 2007 5:38 am
You will see them soon. The first 737-800 will go into the shop after the summer skd ends.
Belize my home sweet home...
EMBQA
Tue Jul 17, 2007 5:39 am
Maintenance cost.
AlitaliaMD11
Tue Jul 17, 2007 5:40 am
Started a thread about this a couple of weeks ago after I saw the same aircraft at JFK.
Delta Getting Rid Of Eyebrows On 737 Fleet? (by AlitaliaMD11 Jun 17 2007 in Civil Aviation)
No Vueling No Party
flytuitravel
Tue Jul 17, 2007 5:48 am
So can "plugging" be done on 737 Classics as well?
FLYTUITRAVEL.
777gk
Tue Jul 17, 2007 5:53 am
Plugging the eyebrow windows on the 737 is a great idea. Saves weight, does not require inspection or replacement, cuts down on spare parts, and reduces glare in the cockpit. Quite often crews would simply stuff a few sheets of newspaper over the window to block out the sun, making the windows effectively worthless.
Over time, CO will plug the eyebrow windows on all 737s. A few 737-800s have been completed, and all new-builds come without them.
dl757md
Tue Jul 17, 2007 6:06 am
Quoting Alitalia744 (Thread starter):
Yes, we are plugging the eyebrow windows on our 738s for many of the reasons already cited.
DL757Md
by738
Tue Jul 17, 2007 6:56 am
Also because much better navigation and anti collision aids means there is less requirement for the extra cockpit visibility which was their original purpose.
mayhem
Tue Jul 17, 2007 6:57 am
Why do they still build them with eyebrows? IIRC, those were used on the classics to be able to navigate using stars?
Aren't those windows an option?
skibum9
Tue Jul 17, 2007 7:02 am
Quoting Mayhem (Reply 13):
Boeing stopped putting eyebrows in the 737 a few years back. It is not an option either.
According to the Boeing press release from 2005...."The design change reduces airplane weight by 20 pounds and eliminates approximately 300 hours of periodic inspections per airplane. Retrofit kits to cover eyebrow windows will be available mid-2006 for the in-service 737 fleet."
http://www.boeing.com/commercial/737...05/photorelease/q1/pr_050126h.html
Tailwinds!!!
1337Delta764
Tue Jul 17, 2007 7:55 am
Quoting Panamair (Reply 4):
These are the 737-800s that will get the Transcon IFE. Is that correct?
md80fanatic
Tue Jul 17, 2007 8:51 am
Eyebrow windows were/are helpful to get a look-ahead while in a steep bank. I guess "technology" has removed the need to see. Soon.....can we expect the entire cockpit window array to be plugged? Could save hundreds of pounds.  Yeah sure
OPNLguy
Tue Jul 17, 2007 9:05 am
They don't. Starting with Boeing line number 1650 (our N201LV), all NGs come without the eyebrow windows...
Photo © Ben Wang
ikramerica
Tue Jul 17, 2007 9:08 am
Quoting MD80fanatic (Reply 16):
The space program has tried from the beginning to do just that, but the astronauts have always balked at the idea.
EHRD
Tue Jul 17, 2007 6:01 pm
Quoting FlyTUITravel (Reply 9):
FLYTUITRAVEL.
Yes it can be done on Classics as well
Photo © Tim Perkins
dangould2000
Tue Jul 17, 2007 7:07 pm
Quoting EHRD (Reply 19):
FLYTUITRAVEL.
what about the -100/200 versions?
Next Flights:- wherever the airline sends me
BlueSkys
Wed Jul 18, 2007 12:06 am
As far as i am aware, Boeing makes the NG as of 2004 i believe WITHOUT the eyebrows ONLY?
Am i wrong?
da man
Wed Jul 18, 2007 12:10 am
Quoting Dangould2000 (Reply 20):
I would think that since these airframes are nearing the end since the youngest -200 is nearing 20 years old; The cost of the modification would probably outweigh the benefits of the lower maintenance costs for the time remaining on the airframe.
War Eagle!
PC12Fan
Wed Jul 18, 2007 12:11 am
I believe the 100/200 series are also referred to as "classics".
Quoting BlueSkys (Reply 21):
I don't know the exact date, but you are correct. No new 737's, military excluded, come with the eyebrow windows.
Just when I think you've said the stupidest thing ever, you keep talkin'!
PGNCS
Quoting 777gk (Reply 10):
Yes it is wonderful. Lower MX costs, cooler cockpit, and they were utterly worthless as windows to begin with.
Quoting BY738 (Reply 12):
Well they were there for maneuvering flight, particularly thought useful in circle-to-land approaches (they weren't). They were never a good feature, and Boeing and operators are wise to delete them.
You have never flown the 737, I see. These windows are utterly useless regardless of bank angle.
OPNLguy
Wed Jul 18, 2007 12:15 am
Quoting OPNLguy (Reply 17):
We took delivery of N201LV in February 2005, and the decision on discontinuing the eyebrows came before that, so your 2004 date seems about right (probably when it was announced). AFAIK, there is no option to have the eyebrows anymore--they all come without them now.
PHLBOS
Wed Jul 18, 2007 12:32 am
Quoting Skibum9 (Reply 14):
A similar move was done towards the latter 2 years or so of 717 production.
"TransEastern! You'll feel like you've never left the ground because we treat you like dirt!" SNL Parady ad circa 1981
727LOVER
Wed Jul 18, 2007 12:37 am
Quoting PC12Fan (Reply 23):
Actually, I believe that term only apllies to the -300,-400,-500
So will winglet installation, eyebrow removal and repainting all happen to each aircraft at once? Talk about a makeover!
Or will I be able, and I;m hoping, that I will be able to see an aircraft with old scheme,with eyebrows an w/ winglets?
And what will DL put on he winglets, the widget or delta.com or something else?
PC12Fan
Wed Jul 18, 2007 12:41 am
Quoting 727LOVER (Reply 27):
You're probable right. Although I don't think it would make much dirrence as I don't believe there was a change in cockpit window design from the -100 series through the NG series up to the time they came with no eyebrow windows.
Alitalia744
Wed Jul 18, 2007 12:44 am
dark blue as of right now, unless they decide to put the circum-widget on em'
jetlanta
Wed Jul 18, 2007 1:15 am
Quoting Alitalia744 (Reply 29):
Are you sure? An internal winglet safety document shows an artist's rendering of the 737-800 with winglets in the new shade of red. Looked sharp.
For the record, someone at Delta sent it to me. I am not a Delta employee.
yow
Wed Jul 18, 2007 1:33 am
Yes. Air North has plugged the windows on at least 1 of their 2 732s. There's already at least 1 pic of it eyebrowless on a.net, but I'm too lazy today to look for it.
All out of production 737 models are "classics". Y
S12PPL
Wed Jul 18, 2007 2:36 am
Oh good grief. Calm down, skippy. It isn't that big a deal....
Next Flights: 12/31 AS804 PDX-MCO 2/3 AS19 MCO-SEA QX2545 SEA-PDX
Viscount724
Wed Jul 18, 2007 2:44 am
Quoting OPNLguy (Reply 25):
Boeing item on the first 737 built without eyebrow windows, rolled out late January 2005.
http://www.boeing.com/news/releases/...05/photorelease/q1/pr_050126h.html
md80fanatic
Wed Jul 18, 2007 3:14 am
Quoting PGNCS (Reply 24):
You are right there.....and I wouldn't fly one even if given the opportunity. The MD-80 series has the same eyebrow windows and more than once I have seen in-flight cockpit shots where the pilot flying is looking out of the eyebrow window while in bank. Perhaps he was simply checking his "look" in the reflection prior to landing?
Maybe you could enlighten me as to the reason why manufacturers would put two to four of these "utterly useless" windows into every airliner made prior to just recently? Did they have a bunch of extra glass lying about and needed a place to stick them?
Alitalia744
Wed Jul 18, 2007 3:21 am
Quoting Jetlanta (Reply 30):
Could very well be. On the DLX planes they're blue and the thought was it would be rolled-out fleetwide, however may have changed. I think red would be nice.
Boeinglover24
Wed Jul 18, 2007 5:32 am
Big version: Width: 1280 Height: 960 File size: 1011kb
Took this one just last friday. I don't know if it's already plugged in or just temporary glareshield or something. Maybe someone can enlighten me on that.
Uhhh What?
dl757md
Wed Jul 18, 2007 5:49 am
Quoting Boeinglover24 (Reply 36):
It's plugged.
DL757Md
