gothamspotter
Investigation: Where's The Safest Seat On A Plane?
Thu Jul 19, 2007 2:22 am
The FAA, NTSB and Boeing all claim that there is no section on a plane that is safer than another. Analysis of the NTSB's own records, however, tells a different story. Popular Mechanics combed through NTSB data from every crash in which there were deaths and survivors since 1971 and for which detailed seating records were available. The analysis reveals that seats behind the trailing edge of the wings were the safest, and seats up front were the least safe.
Full story: http://www.popularmechanics.com/science/air_space/4219452.html
spacecadet
RE: Investigation: Where's The Safest Seat On A Plane?
Thu Jul 19, 2007 2:28 am
The wing box is the strongest part of any plane, and the front of the plane is usually what hits first in an accident (though not always), so it's not surprising that the rear of the wing box is technically the safest place to sit in an accident.
But I don't think it's really statistically all that significant of a difference. In terms of your chances of actually dying any given time you get on a plane, it's maybe the difference between a 0.000007% chance and a 0.000008% chance. And in some accidents that I know of, those in the wing box area died some pretty terrible deaths - worse than those in the rest of the plane. (Pan Am 103 for example.)
JeffB
Thu Jul 19, 2007 2:32 am
In the very last row in the back of the plane. Why? Well... Have you ever heard of a plane backing into a mountain?
(sorry, old joke, couldn't just let it go by)
DeltaAVL
Thu Jul 19, 2007 2:34 am
It's funny you should mention that, because to this day, the only seat that my mom will sit in is the very last row in the plane. She's always told me it's the safest part and she'd have the best chances of survival sitting there. I suppose she's not too far off base...
"We break, We bend, With hand in hand, When hope is gone, Just hang on." -Guster
UnknownUser
Thu Jul 19, 2007 2:37 am
I maybe more likely to die in First class than coach, but at least I will be comfy and have my extra leg room while I die!
Die Skybus!!! You need to die for the good of the industry!
Viscount724
Thu Jul 19, 2007 2:44 am
In photos of many accidents, the only part of the aircraft that seems to survive relatively intact is often the tail, sometimes with at least part of the fuselage attached.
It's ironic that during the propeller era that's where first class passengers were seated. Now, it's passengers paying the cheapest fares who may possibly have the best survival chances at least in some accidents (not sure if there is any data showing a link between seating location and survivability).
One further suggestion: sitting adjacent to a door or emergency exit might help a bit.
Markhkg
Thu Jul 19, 2007 2:49 am
The safest seat on any aircraft, from a technical standpoint, is the rear-facing flight attendant seat. Typically, this seat is the only seat on a Part 121 aircraft that is rear facing. Fairly sure this study looked only at the passenger seats though.
Also, the study is severely limited at the fact that it appears they only looked at crashes. There have been more than 20 accidents that the study cites in the history of aviation. Think about in-flight fires (AC Flight 797) which did not actually crash, but still resulted in fatalities. In these types of accidents, being in a lower-density class configuration (i.e. first class, being in the front of the aircraft) may save your life, as it will allow you to evacuate faster. (Think Manchester Air Disaster.) Other factors such as being close to an exit may be even more important.
Finally, the study does not discuss the role of brace position use.
The bottom line is that for a specific set of aviation accidents, i.e. crashes, sure, it appears that sitting in back appears to protect you in a crash. That's simple physics. But in the whole breadth of aviation disasters, beside crashes, there truly is no "Safer seat".
Why did Popular Mechanics use the Aloha Airlines pictures? Wasn't actually a crash...and the only death was due to the flight attendant not even being in a seat...
Thu Jul 19, 2007 2:57 am
Quoting Gothamspotter (Thread starter):
Please note the first word in "Popular Mechanics".
There isn't enough data to support any such conclusion based on statistics. If we had 30 or more crashes for each aircraft type AND type of crash, the data might be somewhat reliable. Bundling a runway overrun with a controlled flight into terrain and a ditching yields poor statistics since the mechanics involved are quite different. Also, there are so many random factors like terrain, tree density, elevation, temperature, proximity of buildings, wet or dry runway...
What the data does support is the thesis that flying is very safe and that you would be better off worrying about other things than which seat is most survivable.
Boogyjay
Thu Jul 19, 2007 3:16 am
The rear part of an airplane is often not damaged, or at least less damaged than the front part. There are 2 reasons for that : 1/ the front often crashes first and takes most of the crash loads and 2/ the rear part is less pron to fire as the tanks are farther forward.
Tails very often remain fairly intact : look at the recent JJ 3054 in CGH, or Helios B737 in ATH :
Photo © Kostas Iatrou
the list could be endless...
That's a good reason why FAR 25.1459 about the Flight Recorders requires that ... :
"Each nonejectable record container must be located and mounted so as to minimize the probability of container rupture resulting from crash impact and subsequent damage to the record from fire. In meeting this requirement the record container must be located as far aft as practicable"
petertenthije
Thu Jul 19, 2007 3:24 am
You know the C in C-class stands for crumple zone? Well, perhaps not officially but in most cases quite correct anyway.
Attamottamotta!
ehho
Thu Jul 19, 2007 3:26 am
Quoting JeffB (Reply 2):
Not that far off the truth actually, remember the FV IL-86 that crashed shortly after takeoff in SVO in 2002, due to a faulty horizontal stabilizer? Two of the 16 crew members aboard the repositioning flight to LED survived because they were in the tail section that disintegrated from the rest of the fuselage upon impact. One of the two wasn't even seriously injured.
"Get your facts first. Then you may distort them as much as you please" -- Mark Twain
Poitin
Thu Jul 19, 2007 3:30 am
With few exceptions, the majority of survivors are in the last few rows because it tends to break off and stay in one piece or it is the last part of the airframe to impact and so has been slowed down by the carnage in the front. However, I think the safest place in an plane crash is someplace else, as far away as possible.
Now so, have ye time fer a pint?
SJCRRPAX
Thu Jul 19, 2007 3:47 am
Quoting DeltaAVL (Reply 3):
When someone drives her in a car, does she take the middle seat in the rear, because statistically that is the safest seat. The right front passenger seat is the most dangerous because the drivers tends to avoid obstacles on their side. Just pointing out that if she does not do that in a car she is not being consistent, as she is probably 100x times more likely to be injured in a car accident.
AlexPorter
Thu Jul 19, 2007 3:49 am
And the regional crashes get ignored again, because nobody ever flies on regional planes (tell that to people from Ohio, for one): The article ends with "There hasn't been a single U.S. commercial jet passenger fatality — front cabin or rear — in more than four years."
So, never mind the Delta Connection crash in Lexington, the US Airways Express crash in Charlotte, the American Connection crash in Missouri... (granted, the last two weren't actually jet fatalities, but the Delta Connection one was a CRJ-200. I believe that crash in August 2006 ended the nearly five-year streak since American 587 in November 2001.
Last Flight: SCX701 MSP-PHX B738 8Jan2008
Thu Jul 19, 2007 4:02 am
Quoting AlexPorter (Reply 13):
So true. I will again point out the first word in "Popular Mechanics".
SEPilot
Thu Jul 19, 2007 4:03 am
Seeing as the absolute safest way to get from point A to point B is by scheduled airliner, I'll worry more about being struck by lightning. It's much more likely to happen to me than being killed by an airliner crash. In fact, I probably have as great a chance of being killed in my car by an airplane crashing into it as being killed on a full-sized (i.e. DC-9 or larger) airliner.
Thu Jul 19, 2007 4:06 am
Quoting SEPilot (Reply 15):
So true. In fact, right after posting this I'll run outside in the thunderstorm and hold my cell phone over my head. Big grin
flybyguy
Thu Jul 19, 2007 6:26 am
Quoting BoogyJay (Reply 8):
 checkmark  You guys are on the money... I suppose that it comes as no surprise that aeronautical engineers fix the flight data and flight voice recorders to the empennage of the aircraft as opposed to any other region within an aircraft for those very reasons.
Quoting Spacecadet (Reply 1):
Wing Box? It's the best place on the plane if you want experience a first hand barbeque. Many wires, electro-mechanical and hydraulic equipment within the vicinity of the belly and wing fuel tanks, can't make this area the safest section of the plane. Certainly, during a crash landing with slow fire propagation people in the wingbox area can use the ample emergency exits in that area with relative ease. However, in high impact crashes I suspect areas with the greatest quantities of fuel burn quickly and violently.
"Are you a pretender... or a thoroughbred?!" - Professor Matt Miller
SWISSER
Thu Jul 19, 2007 8:48 am
Airbus states that the least risk area is at the R4 door, but that is in the case when you move a bomb...
In the middle of the aircraft you have a fuel tank, engines sucking you in the intake or burning your skin off just aft of the wing, and in the back the jetblast is still dangerous, for engines on wing mounted aircraft.
The front is then very prone to break off, roll over or crunch and not be able to provide a slide.
From my point of view (the FA seat) I just have to pull the lever to actually get out (if I was not there to safe the pax *sses),
So maybe that is the safest seat if you exclude the duty's attached on the seat!
On the other hand you might get lucky if the fuselage breaks near your seat, so you can "walk out"!
What time is top of descent?
jbernie
Thu Jul 19, 2007 9:32 am
Quoting Starlionblue (Reply 7):
On one hand, you can only go off the data you can gather, on the other hand, with way so many variables involved it is next to impossible to really replicate anything ..let alone cost effective to try it. A plane crashing into a river in mid summer has a better chance of survival than the same exact crash in winter when the water is at or below freezing, you can survive the crash but the environment you are in may not be survivable even for someone who was not in a crash, ie just fell through ice.
The Mythbusters had on one episode the story of I believe a Russian FA who was in the rear of a plane and survived a crash of some description, given the testing they did it was a drop from some height, can not recall if it was a mid air break up though. They went out and cut up the tail of a jet, they were weight limited which made it harder to get accuracy and dropped the section from a decent height to see what would happen. Their results weren't that inspiring, but in saying that, how do you replicate what are in effect "one off" accidents?
I think this episode had them dropping Buster from the helicopter strapped to an emergency chute/raft and he floated down quite gently. Amazing stuff to watch.
DeltaAVL
Thu Jul 19, 2007 9:42 am
Quoting SJCRRPAX (Reply 12):
I know that, and I've told her a million times about how much safer the airlines are than cars, but she still prefers the back row.
I've never heard of anyone afraid of riding in a car, but fear of flying is rather common.
Thu Jul 19, 2007 10:24 am
Quoting Jbernie (Reply 19):
Indeed. I am not opposed to the idea that there are safer areas. I am opposed to the idea that this hypothesis has been statistically tested.
I have noticed that the Mythbusters, while being some of my favorite people to watch on TV, tend to fall down rather hard when it comes to aviation myths.
Quoting DeltaAVL (Reply 20):
It's a natural instinct. Twin fears of heights and enclosed spaces (both present in the reptile brain for good reasons) combined with the fear engendered by not being in control. Add to that the ever helpful media and it's a wonder anyone flies at all.
Markhkg
Thu Jul 19, 2007 3:34 pm
Vesna Vulovic, off a DC-9, due to a bomb explosion.
http://www.damninteresting.com/?p=18
ehho
Thu Jul 19, 2007 5:13 pm
Quoting MarkHKG (Reply 22):
Yeah, Russia, Croatia or Czechoslovakia, same difference..  indifferent   no
You can read about the actual Russian tail-section-survivor incident in my post nr. 10.
kuhne
Thu Jul 19, 2007 5:28 pm
It is so true that you are safer on a plane than anywhere else (well maybe not in your room inside your bed) but still.
You guys say that schedueled airliners are the safest way... does that include an older, 737-200 from Aviacsa as well? cos I am about to fly it and I am quite nervous...
Bongodog1964
Thu Jul 19, 2007 5:45 pm
IMO Instantaneous death in a wingbox fireball may well be preferable to being a groaning jellifed heap with every bone protruding. It is however pure conjecture as there's not a single person who's ever come back to tell us about the experience.
pdxtriple7
Thu Jul 19, 2007 6:36 pm
Discussions like this have popped up in the past. I'm about to read the article, but my personal opinion is that if any seat actually has a better chance of saving your life, it would be in the rear of the aircraft. I base my assumption on this because although the wingbox is the strongest part of an aircraft, that doesn't really in crash when you are sitting on all the fuel, also, it appears the very rear tail section remains intact to a certain extent, probably because the front of the aircraft takes so much of the impact forces. Also, you are near an exit, since in a fair amount of accidents/crashes, the fire and smoke inhalation can prove to be the most deadly. However, this would also mean first class would be better if the plane is mostly intact with a lower passenger density to exits.
Finally, there was a Czech f/a who survived an in-air explosion and subsequent fall from a cruising altitude of 33k. She was in the tail of the aircraft. http://en.wikipedia.org/wiki/Vesna_Vulovi? I guess one explanation is that the tail floats down instead of plummetting. But let's face it, it's all luck or God depending on your views.
Thu Jul 19, 2007 8:29 pm
Quoting Kuhne (Reply 24):
Can of worms!  Wink
The aircraft age has little impact as long as it's properly maintained. The operator (and thus maintenance regime) has a big impact. That is, a 50 year old 707 operated by BA is safer than a 2 year old 777 operated by the Central African People's Liberation Front.
kuhne
Thu Jul 19, 2007 9:20 pm
Quoting Starlionblue (Reply 27):
Can of worms!
Well this is a 727-200, I am pretty sure it's quite old, this link I will post is a picture of what I am sure is the same plane I am going to fly in. (possibly) since it is a 737-200 from aviacsa in the las vegas airport.
http://www.airliners.net/open.file?i...=2&prev_id=1234104&next_id=1195621
Sorry for the long link... anyways, being that said plane flies from monterrey to las vegas directly (mexico to usa, non stop) that should mean that the airplane's maintenance is good right? I mean the FAA had to aprove that plane as well because it is entering us airspace?
Thu Jul 19, 2007 10:17 pm
Quoting Kuhne (Reply 28):
Depends on Aviacsa maintenance and operations.
Yes they do have to approve it. But I have no idea about the maintenance.
kuhne
Thu Jul 19, 2007 11:01 pm
I hope that the FAA leting aviacsa go into las vegas is a telling of their good maintenance
