amax1977
EX-UA 744 For Iran Air
Thu Jul 26, 2007 12:47 am
Hi,
It seems N176UA ended up in THR... http://www.iraviation.com/Picture/OnePicture.aspx?id=101325
EI321
RE: EX-UA 744 For Iran Air
Thu Jul 26, 2007 1:01 am
What is it, a wet lease? Iranair could really do with some new or newish planes.
Norcal773
Thu Jul 26, 2007 1:34 am
Quoting EI321 (Reply 1):
From who? Can't be a US company, can it?
If you're going through hell, keep going
PanHAM
Thu Jul 26, 2007 1:40 am
...........with the friendly help of neighbouring Armenia (EK).
The old wisdom prevails, always be three steps quicker than the bureaucrat running behind you. Bazaris and the Wolrd's best traders cut a deal circumventing the embargo.  Wink
on the other hand, I would not want to be on a 744 that is 4 numbers too big for the carrier that operates it and for which IR cannot get spares direct, unlike for those aircraft that they have on their own register.
Was Erlauben Erdogan!!!
Pronto
Thu Jul 26, 2007 1:46 am
Wasn't this a British company? I could swear I saw in a past issue of Airliner World a picture of this aircraft with a British reg'n.(G-CEFE); now with Armenian? Could it be a "shadow" name for Iran Air? The mystery continues...
Poitin
Thu Jul 26, 2007 1:48 am
Quoting PanHAM (Reply 3):
Who ever wet leased it, which is what I suspect happened, is going to have a hard time getting it fixed. Boeing will be told to not send spares. That will cause the grey market to supply parts at much higher rates. However, I am sure whoever owns the plane knows that and is being paid for it.
Now so, have ye time fer a pint?
kc135topboom
Thu Jul 26, 2007 1:49 am
Quoting Norcal773 (Reply 2):
No.
I see no problem with IR leasing/buying US built airplanes through a third party. I suspect this deal was sealed somewhere in Europe. IR would not have gotten this B-747-400 if getting spare parts was going to be a problem.
Is this the first of several B-747-400s they want?
LAXintl
Thu Jul 26, 2007 1:56 am
Quoting Poitin (Reply 5):
Why should there be any issues getting spares for the planes?
Aircraft dont belong to Iran Air, they belong to a 3rd party operator whom Boeing would have absolutely no problem dealing with.
Anyhow much of IR's current B747 fleet is kept up thanks to the help of KLM and Lufthansa. While adding a middle-man, IR secures its needed supplies without much of a problem. Matter of fact one of the B747SP is currently in a D-check, something that would be impossible without a whole lot of replacement parts.
IR's real only recent problems had to with its A310 fleets GE engine overhauls, however they managed to work the issue thru with Turkish Airlines doing the work.
mnik101
Thu Jul 26, 2007 2:01 am
I have a feeling that picture is of a charter flight, but if its true, more power to IR. Correct me if I'm wrong but could'nt IR simply lease the aircraft from a third party, and as part of the terms of the lease have the third party responsible for maintance.
Hypothetical scinario, IR leases planes from a UAE based company. The planes are registered in the UAE but are in full IR livery. The UAE company does all the maintance for the planes, and sends IR a bill for it.
Can that be done or is that also illegal?
EI321
Thu Jul 26, 2007 2:04 am
Quoting Mnik101 (Reply 8):
If its wet leased, Iran Air won't be maintaining it and it will probably be maintained in another country. This would also apply to the A340 that they are leasing.
[Edited 2007-07-25 19:05:29]
LAXintl
Thu Jul 26, 2007 2:12 am
Absolutely legal. Thats how airlines such as Mahan manage to operate A320s.
Photo © A.Mahgoli
Poitin
Thu Jul 26, 2007 2:18 am
Quoting EI321 (Reply 9):
If the A340 has Rolls Royce engines, there is very little the US government can do. However, in the case of Boeing, who is a very large defense contractor, a private word from the State Department, would suddenly make spare parts "out of stock" when whoever has the airplane asks for spares, help, information, etc. That is what I meant when I said "Boeing will be told to not send spares." It has happened before and it will happen again.
Viscount724
Thu Jul 26, 2007 8:47 am
Last October the US government approved the export of GE engine parts for Iran Air Airbus engines to comply with an FAA airworthiness directive. The exception was made on safety grounds. Relevant press release:
http://www.state.gov/r/pa/prs/ps/2006/73811.htm
A340313X
Thu Jul 26, 2007 9:16 am
I'm going to presume the A340 tehy are leasing is an older one? If memory serves an A340-211? If that's the case it'll have CFM56-5C2 engines, CFM being a joint venture between General Electric and some other parties. Should be no issue getting engines for that though.
OceansWorld
Thu Jul 26, 2007 9:27 am
Quoting A340313X (Reply 13):
Yes, the 31st off the production line.
The other party being the French Snecma.
UnitedTristar
Thu Jul 26, 2007 9:53 am
According to Airfleets, Mahan is getting an Ex UA bird, could this be the second one? Maybe the Caption was in error.
http://www.airfleets.net/ficheapp/plane-b747-24363.htm
-m
[Edited 2007-07-26 02:57:36]
MCOflyer
Thu Jul 26, 2007 2:06 pm
I hope all goes well for this ex UA machine.
Hunter
PanHAM
Thu Jul 26, 2007 2:32 pm
The deal is that IR gets spares for whatever they had in their Boeing fleet before the embargo took place, but does not get new planes delivered.
That is why they don't have problems with D checks. The relation to Lufthansa Technik dates back more than 40 years, I met the then IR tech rep in Hamburg once in 67. IR is absoluteley capable of doing the maintenance, it's just another operating environment and it is more difficult than without the embargo.
The opeator, whoever that is, registered the plane in Armenia, spares officially go to that country. Omn every export declaration it says that "diversion is contrary to US law". This is indeed a grey zone and whatever is done in grey zones does not make the operation safer.
Shenzhen
Thu Jul 26, 2007 5:06 pm
Quoting PanHAM (Reply 17):
I'm sure they get spares for their Boeing Airplanes, but it isn't directly from Boeing. There are plenty of middle men out there who will buy parts, mark them up 25 percent then sell them to you. Many airlines that can't get parts from Boeing/Airbus due to millions owed on their spare parts credit go thru these brokers as well.
Vietnam Airlines wet leased 767 airplanes long before the embargo was lifted.
Bofredrik
Thu Jul 26, 2007 8:08 pm
It is terrible with this sanctions that give the iranian airline passengers less security than us.
PanHAM
Thu Jul 26, 2007 8:32 pm
Quoting Bofredrik (Reply 19):
It's up to them to get the ban lifted.
CHRISBA777ER
Thu Jul 26, 2007 8:40 pm
Thats great, great news - I am so pleased.
IR are a wonderful airline and I am so pleased to see them get some really capable 744s. It really will be a quantum leap ahead for them after the classics they have so faithfully kept going. At last they have something that can really do the business on their THR-LHR route. I would think it has the range to do CCS as well non-stop.
Tehran is definitely on my "must see again properly" list of cities. Wonderful people and wonderful Persian hospitality. Sad that politics has caused this magnificent airline to suffer as badly as it has. The media here would have us believe the Iranians are all stone age barbarian suicide bombers, but that just is not the case. Yes, their Government has some distinctly archaic and repressive policies, but it is nowhere near as bad as Saudi Arabia. I dislike Ahmadinejad and I dislike Bush, but that doesnt mean I wont enjoy visiting Iran and the US regardless. I am just very lucky that I am able to, and have the freedom to do so.
Good on them for moving on up and making steps forward. I just hope the Americans do not find some way of stopping this deal going through like they did with the Blue Wings A330s.
Congrats IR - look forward to seeing these big birds at LHR soon!
What do you mean you dont have any bourbon? Do you know how far it is to Houston? What kind of airline is this???
RayPettit
Thu Jul 26, 2007 9:43 pm
Here is a thread with some background info. http://forum.keypublishing.co.uk/showthread.php?p=1043124#post1043124
Just wondering where else these aircarft have been seen. Do they only operate within the Middle East?
mnik101
Fri Jul 27, 2007 12:37 am
Quoting PanHAM (Reply 20):
Safety should not come second to politics. Especially when it comes to flying
