Codasco
Enough Time For A Connection At O'Hare?
Fri Jul 27, 2007 6:19 am
I'm flying AA tomorrow....my flight gets into O'Hare's K concourse at 9:55, and my next flight leaves the G concourse at 10:35.....so 40 minutes. Is this enough time to switch terminals??....re-entering security could take 40 minutes alone!
smcmac32msn
RE: Enough Time For A Connection At O'Hare?
Fri Jul 27, 2007 6:28 am
You don't have to switch terminals by going through security again. It should take no more than 15 minutes to get gate to gate. All terminals except T5 are interconnected so you can pass through without going through security again. The only time you would need to pass through security again is going to T5 (International). Hope this helps.
http://www.flychicago.com/ohare/concessionsohare/pdf/T3B.pdf
Edit: Just added a link to the map of the terminal you'll be in.
[Edited 2007-07-26 23:31:42]
Hey Obama, keep the change! I want my dollar back.
ORDZW
Fri Jul 27, 2007 6:30 am
Terminals 1, 2, and 3 are all linked inside security. It is not too far from K to G - it should only take you about 10 minutes, depending on how fast you walk. 40 minutes will be plenty of time!
Enjoy O'Hare!
9E, AA, AQ, AX, BA, CO, CP, DH, DL, EV, F9, FL, HA, HP, KL, NK, NW, OH, OO, QX, RP, RW, S5, TW, UA, US, WN, YV, ZK, ZW
bwohlgemuth
Fri Jul 27, 2007 6:38 am
Isn't there a bus between G & K?
smcmac32msn
Fri Jul 27, 2007 6:40 am
Nope, just your own feet and a hall between them. Your probably thinking about the bus in the United (T1) terminal over to concourse E in terminal 2.
[Edited 2007-07-26 23:43:34]
Users browsing this forum: 767333ER, 787fan8, coolian2, diverdave, durangomac, flymco753, Google Adsense [Bot], HELyes, jfk777, jrpswede, LeCoqFrancais, poolkeeper, scbriml, Sightseer, StTim, sunking737 and 323 guests
