United Airline
Why Did Airlines Order The B 747-300?
Wed Aug 01, 2007 12:50 pm
Airlines clearly knew that the B 747-300 has shorter range and the B 747-400 would be available soon. Why did they order it still?
BTW where does QF, JL and TG fly their B 747 classics to?
OB1504
RE: Why Did Airlines Order The B 747-300?
Wed Aug 01, 2007 12:58 pm
They probably didn't need the range. Same reason NL and JL ordered the 747-400D.
Charles79
Wed Aug 01, 2007 1:06 pm
Quoting OB1504 (Reply 1):
True, or simply couldn't wait for the 744 variant to enter service. As for their routes, I've seen QF's 743s here in LAX quite often this summer, doing MEL-LAX routes if I'm not mistaken (which I probably am).
Charles
United Airline
Wed Aug 01, 2007 1:51 pm
What's the longest ever B 747-300 flight?
OB1504
Wed Aug 01, 2007 2:02 pm
Probably AKL-LAX at 5,652 nm.
United Airline
Wed Aug 01, 2007 2:11 pm
What about Rome-Bangkok by TG? And SR's ZRH-HKG?
[Edited 2007-08-01 07:11:58]
pilotdude09
Wed Aug 01, 2007 3:17 pm
Quoting Charles79 (Reply 2):
Yeah wrong  Smile it was doing AKL-LAX to cover the 744 due to shortages and maintenance requirements.
If it did attempt MEL-LAX you certainly wouldnt need a return ticket!
Qantas, Still calling Australia Home.........
Leskova
Wed Aug 01, 2007 3:21 pm
Did the airlines really know that the B747-400 would be available "soon"? The first B747-300 was delivered to UTA on 1 March 1983, the first B747-400 was delivered to Northwest on 26 January 1989: that's a difference of six years, too much if you need new planes with increased capacity and any other upgraded equipment (not sure how much more in that regard the -300 had to offer compared to the -200).
For airlines needing planes, and not really needing the -400's range, the -300 was a good choice, especially if they didn't want to wait for more than half a decade to receive it - and that's only if Boeing had already told them at the time that the -400 was on it's way...
Smile - it confuses people!
swissgabe
Wed Aug 01, 2007 3:30 pm
Quoting United Airline (Reply 5):
And SR's ZRH-HKG?
SR routed the HKG via BOM and so it won't be the longest flight at all.
Quoting OB1504 (Reply 4):
Did QF route via AKL to LAX or which Airline did so?
Smooth as silk - Royal Orchid Service /// Suid-Afrikaanse Lugdiens - Springbok
N1120A
Wed Aug 01, 2007 4:02 pm
Quoting United Airline (Thread starter):
Because it made sense over the 742 for a lot of routes, particularly at that time, and the 744 was still half a decade away, as Frank said. Remember, carriers like KLM even purchased the SUD option for their 742s to increase capacity.
That is only part of the story really. Since the 744 burns significantly less fuel than the 743, it makes plenty of sense to just use the 744 on routes you would use the 743 on. The main reason was the 6 year difference.
You are only sort of right. They aircraft routes MEL-AKL-LAX. The 743 does not have nearly enough range to do MEL-LAX non-stop.
Quoting Leskova (Reply 7):
The same number as the -400 has over the -200. The -400 and -300 are the same size.
Quoting Swissgabe (Reply 8):
QF still uses the 743 on that route.
Carpethead
Wed Aug 01, 2007 5:30 pm
- Clearly in the late 1970s, airlines such as SQ & JL wanted more lift than the 742. Nobody was planning for the 744 back then.
- For additional capacity, KL converted their 742s into 742SUD.
- By the mid-1980s, it was becoming clear the 744 was going to materialize and hence the lack of new orders for the 743.
- Had the 744 not come out sooner, then more 743 sales could have been realized but it was just a matter of time before 767-era technology was incorporated into the 747. And the rest is history....
columba
Wed Aug 01, 2007 5:48 pm
Btw was the 747-300 the last new developed aircraft with a three man cockpit ?
It will forever be a McDonnell Douglas MD 80 , Boeing MD 80 sounds so wrong
FlySSC
Wed Aug 01, 2007 6:05 pm
They didn't need more range. They needed more capacity.
The B743 was available well before the B744.
The first B743 was delivered to Swissair early 1983.
Quoting Carpethead (Reply 10):
UTA did so to in 1989 with F-BTDG and F-BTDH.
Before & After :
Photo © John Kelly
Photo © Mika B Virolainen - FAP
Note that F-BTDG was a -Combi, used in a very particular configuration as the Cargo compartment could carry 11 Freight palets, starting at the Doors 3, unlike most of the other -Combi, carrying 7 palets, with a Cargo compatment starting at the Door 4.
You can see on the following pictures that only the 3 first doors are painted in Green, the last 2 beeing in the Cargo section and "neutreulized".
Photo © JetPix
N1120A
Wed Aug 01, 2007 7:06 pm
Quoting Columba (Reply 11):
Well, it wasn't exactly a new aircraft. It was more a development of the 742. The 744 was the truly new aircraft. Still, it is the last western aircraft I can think of that was introduced with a 3-member cockpit.
1stfl94
Wed Aug 01, 2007 7:40 pm
The 744 partly materialised because of airline disappointment with the 743. It became clear soon after the 743 entered service that more needed to be done to the 747 and in 1985 Boeing announced the all new 747-400
ikramerica
Wed Aug 01, 2007 7:55 pm
Quoting 1stfl94 (Reply 14):
Bingo. The 743 was underwhelming, and Boeing had to scramble and introduce a real new 747, one with 2 man cockpit, greater range and greater efficiency. But when ordering the 743, airlines had no idea the 744 was going to come along. The premise that airlines knew and ordered the 743 anyway is false.
dutchjet
Wed Aug 01, 2007 7:58 pm
Exactly which airlines were disappointed with the 743? Most 743 operators went on to order 744s later on.....as stated above, the 743 was basically nothing more than a capacity upgrade over the 742 while the 744 project was complete update of the 744 incorporating new technology (developed from the then new 757/767 programs) including the two man cockpit.
QF108
Wed Aug 01, 2007 8:54 pm
If im not mistaken that QF flight MEL-AKL-LAX is about to or has become an A330, which will leave only SYD/MEL-PER with regular 743 service. VH-EBX was recently damaged in MEL due to brakes failing on a baggage loader. So I think its basically one flight per day with the 743 SYD-PER, MEL-PER.
Blessed are the Cheesemakers !
United Airline
Wed Aug 01, 2007 11:52 pm
The B 747-300 didn't sell very well.
What about Rome-Bangkok by TG? Wasn't it the longeset B 747-300 flight?
Really?
dutchjet
Thu Aug 02, 2007 3:09 am
Quoting United Airline (Reply 18):
Depends upon how you look at it, the B743 gave a boost to the 747 program when airlines were loosing interest in ordering new build 742s; the 743 also was introduced when many carriers worldwide, and especially US carriers, were beginning to take delivery of smaller widebodies such as the 767 and A310 which gave the carriers new options and choices. The 743 offered just enough to revive interest in the 747 Classics; Boeing then went to work on the 744. I always considered the 743 a ""transition"" aircraft.......a step inbetween the 742 and 744. Also consider that some airlines (like SR, SN, KL) ordered 743s to replace early build 741s and 742s......which was a very positive thing for Boeing and the 747 program.
Really?
Yep, Swissair's 743 flights between ZRH and HKG were routed via India; until the 744 (and other longer range widebodies that followed it) was introduced, most flights between Europe and Asia had to make atleast one stop enroute.....things have changed!
[Edited 2007-08-01 20:11:17]
[Edited 2007-08-01 20:11:40]
Viscount724
Thu Aug 02, 2007 3:43 am
The 81 747-300s built far exceeded the 45 747SPs, not to mention certain models of more recent Boeing types, e.g. 55 757-300s and 37 767-400s. And apart from 3 -300s bought new by KL, they also converted 10 -200s into -200SUDs which for all practical purposes were identical to factory-built -300s.
The 747-300's extra seating capacity could generate a lot of additional revenue over the -100/-200. I recall SR had 69 economy class seats on the upper deck of their -300s.
[Edited 2007-08-01 20:59:42]
OceansWorld
Thu Aug 02, 2007 3:45 am
Yes, only 81 were delivered, -300 (56), -300SR (4) & -300M (21)
Quoting Dutchjet (Reply 19):
Indeed SR replaced its early B742s with B743s and B743Ms, while KL only ordered three -306M (received between 1980 and 1984) as they converted 10 -200B to -200B/M SUD. Of their early birds, six left the fleet between 1989 and 1991 only, so I can't consider their order as a true replacement of older aircraft.
SN was a late comer for the -300. The Belgian airline received its first in 1986 and the second in 1990. And it is only when that second -300M arrived that SN removed from service one of of its two older -100Ms.
Not to forget that the Russian air space was closed to western airlines for many years. IIRC, late in the '90s, a SR B743 bound non-stop for NRT or PEK had to turn back because the captain had a cerebral stroke.
Thu Aug 02, 2007 4:07 am
Indeed. I remember when I was a kid flights to the Far East were always via Dehli, Abu Dhabi or somewhere else. I also remember when I first saw that CX flew HKG-LHR direct. I was like "wow, that's far." Nowadays it's commonplace.
Yes and no. Just like other niche types it's not really a type by itself. It was made on the same production line and shares the same wing as the -100/-200. So it's just a variant. You cannot consider the isolated sales number as a sole indicator of success.
YULWinterSkies
Thu Aug 02, 2007 4:34 am
What is the actual technical difference among a 742SUD and a 743?
When I doubt... go running!
dutchjet
Thu Aug 02, 2007 5:01 am
Quoting YULWinterSkies (Reply 23):
743 = an aircraft built as a 747-300 with the streched upper deck.
742SUD = an aircraft built as a 747-200 and later modified to add the streched upper deck.
Quoting Starlionblue (Reply 22):
Good point. I agree.
ShootTheMoon
Thu Aug 02, 2007 5:03 am
Are the engines on the 742 and 743 the same? I know the 744 has newer, more efficient engines, but what about the 743?
dutchjet
Thu Aug 02, 2007 5:11 am
Quoting ShootTheMoon (Reply 25):
The 742s and 743s were equipped with the same generation of engines from the engine manufacturers.
Didnt NW actually purchase two of SR 747-300s for parts and engines.? NW of course never operated the 743 in revenue service, but the SR 743s had so much in common with the NW 742s that it made sense to use the ex-SR 743s for spare parts, engines, etc. One of those strange stories.
Thu Aug 02, 2007 5:18 am
Quoting Dutchjet (Reply 24):
Similar to the distinction between new build 747 Freighters designated 747-xxxF and converted freighters designated 747-xxx(BCF) or 747-xxx(SF).
This whole designation madness could lead to such tongue twisters as: "747-206B(SF/SUD)"
Photo © Josef P. Willems
Trivia: did you know the 747-400F has the old short hump?
[Edited 2007-08-01 22:19:49]
[Edited 2007-08-01 22:23:21]
OceansWorld
Thu Aug 02, 2007 5:22 am
Quoting Dutchjet (Reply 26):
Yes, the first two B747-357 of the fleet ex. HB-IGC/D were bought by NW. Their engines were used for the freighter fleet.
DIA
Thu Aug 02, 2007 5:30 am
Interesting thread about an (almost) overlooked model of the 747.
Somone want to write down a quick list of all the original 743 operators here? I know Varig was one, I don't think I saw them mentioned above.
Ding! You are now free to keep supporting Frontier.
MAS777
Thu Aug 02, 2007 5:31 am
Quoting FlySSC (Reply 12):
But didn't the 743 signal the first LHR-SIN nonstop service for SQ....or was it at the cost of a 'reduced load' (which was negated by the larger capacity the 743 provided) compared to the 742.
Superfly
Thu Aug 02, 2007 5:41 am
The last western aircraft perhaps but remember the IL-96 is a three man cockpit and still in production.
Los Angeles - Auckland is further distance.
Bring back the Concorde
Viscount724
Thu Aug 02, 2007 5:59 am
Quoting DIA (Reply 29):
From Boeing website orders/deliveries data :
Air India
Cathay Pacific
Egyptair
Japan Airlines
Japan Asia Airways (JL subsidiary)
KLM
Korean Air
Malaysian Airlines
Qantas
Sabena
Saudi Arabian Airlines
Saudi Arabian govt. (VIP aircraft)
Singapore Airlines
South African Airways
Swissair
Thai Airways
UTA
Varig
Also 4 delivered to leasing company ILFC. Not sure who operated those.
OceansWorld
Thu Aug 02, 2007 6:13 am
Quoting Viscount724 (Reply 32):
Here's your list with the details for each operators.
Air India (2)
Cathay Pacific (6)
Egyptair (2)
Japan Airlines (13)
Japan Asia Airways (JL subsidiary) (1)
KLM (3)
Korean Air (3)
Malaysian Airlines (1)
Qantas (6)
Sabena (2)
Saudi Arabian Airlines (10)
Saudi Arabian govt. (VIP aircraft) (1)
Singapore Airlines (14)
South African Airways (2)
Swissair (5)
Thai Airways (2)
UTA (3)
Varig (5)
UTA B747-3B3 F-GDUA was destroyed by fire at CDG, 03/1985.
vikkyvik
Thu Aug 02, 2007 8:00 am
Quoting Starlionblue (Reply 27):
Indeed. And the -400D has the long hump, but no winglets.
Thu Aug 02, 2007 8:14 am
In 1999-2000 JL still operated the 743 nonstop over Russian airspace e.g. NRT-AMS. Quite a distance too!
moek2000
Thu Aug 02, 2007 8:18 am
I know SV has a lot of 743's...I used to fly them every 6 months back in the 90's, always had a great experience!
As far as why SV ordered 743's, I would have two guesses:
-They were growing in the 80's and needed immediate jumbo's for hajj flights
-There was a political motive between the Saudi Govt. and U.S. govt (similar to the huge 744, 772, MD11, and MD90 order SV placed in mid 90's).
Quoting United Airline (Reply 3):
I regularly flew the JFK-JED route using the 743 in the 90's...6365 miles...And at that time, it was the only route that flew over 4 continents (Asia, Africa, Europe, America)
Max Q
Thu Aug 02, 2007 8:41 am
Well CX flew the -300 on HKG-YVR and HKG-LGW prior to them switching into LHR.
It was not a regular thing as they preferred tp use their -D4 powered -200's but they did it !
N1120A
Thu Aug 02, 2007 10:05 am
Quoting Viscount724 (Reply 20):
Out of more than 1300 aircraft, both numbers are rather small.
Quoting MAS777 (Reply 30):
The 747-200B should have had plenty of range and payload uplift to run the route.
YULYMX
Thu Aug 02, 2007 10:06 am
Corsair had B743 until last year... and qantas use them as sub on SYD-LAX
N1120A
Thu Aug 02, 2007 10:13 am
Quoting YULYMX (Reply 39):
I do not think that is true, except maybe in a dire emergency. They would have to make a non-revenue stop in Honolulu or somewhere else along the way. They would be better suited to take a 744 off the Kangaroo Route and stick the 743 on that.
YULYMX
Thu Aug 02, 2007 10:20 am
Avianca
Thu Aug 02, 2007 10:25 am
very intresting! btw do you know on what routes they used these "special" combis..???
SEPilot
Thu Aug 02, 2007 10:30 am
From what I've read Boeing was quite reluctant to develop the 744, preferring to rest on their laurels. It was pressure from the airlines, who could see that it could be substantially improved that caused them to do it. Clearly the Boeing malaise that was so evident in the 90's had its start in the 80's; Boeing wanted to take a break after the 757-767 program. So the idea that the airlines knew the 744 was coming when they ordered the 743 I believe is false; it could well be that some of the 743 purchasers were among those who pressured Boeing. More likely, it was airlines that refused to buy the 743 (NW?) that told Boeing that they needed to do better.
malaysia
Thu Aug 02, 2007 11:40 am
Quoting Moek2000 (Reply 36):
I was a bit too late, I ended up only flying the 743 only between JED-BKK and RUH-BKK and a 744 between RUH-JED-JFK and IAD-JFK-JED and Cockpit jumpseat on the 744 unfortunately for a full flight segment, but I only had chance to stay in cockpit during midflight on a 743.
There Are Those Who Believe That There May Yet Be Other Airlines Who Even Now Fight To Survive Beyond The Heavens
Leskova
Thu Aug 02, 2007 3:05 pm
Quoting N1120A (Reply 9):
I was thinking more in terms of technology - I'm aware that they're the same size.
Quoting N1120A (Reply 13):
While it wasn't introduced with it, the B767 was available with a three-member cockpit as well, though, if I recall correctly, only Ansett ever took that option.
Yup - no use for the extra space, but much use for the reduction in weight by not having it...  Wink
Carpethead
Thu Aug 02, 2007 4:28 pm
Thanks. I was using KL just as an example.
Other than UTA & KLM, did other operators convert an existing 742 into an 742SUD?
JL had the 741SUD but that aircraft actually was delivered new to JL.
N1120A
Thu Aug 02, 2007 5:16 pm
Quoting Leskova (Reply 45):
Ah. In that case, not much if anything.
Yes, there were those, but the aircraft had to actually be altered by Boeing to provide the option. It was designed as a 2 crew aircraft.
Thu Aug 02, 2007 5:22 pm
Basically yes, but more because you can uplift 4 Q7 sized pallets (instead of Q6 size). That's a main issue for the operators.
N1120A
Thu Aug 02, 2007 5:30 pm
Quoting Airbuseric (Reply 48):
How does the SUD make a difference there?
