LipeGIG
TAM To Begin GRU-FRA Eff. Nov 30 With A345
Sat Aug 18, 2007 11:47 am
TAM today receive approval to fly daily to FRA as well as announced that the daily flights with their new A340-500 planes will begin November 30
JJ8070 GRU 2240 FRA 1330 (+1)
JJ8071 FRA 2230 GRU 0740 (+1)
The A340-500 will not present a First Class cabin (only 42C 225Y).
MAD will begin in December, also from São Paulo with daily M11.
The two new A332 planes should be used on MXP, which will begin overnight service both ways shortly.
Felipe
New York + Rio de Janeiro = One of the best combinations !
RJ_Delta
RE: TAM To Begin GRU-FRA Eff. Nov 30 With A345
Sat Aug 18, 2007 1:39 pm
The A345 will operate only on GRU-FRA route or could be used to others TAM medium haul routes during the day, specially to other points in South America?
HB-IWC
Sat Aug 18, 2007 2:32 pm
Quoting RJ_Delta (Reply 1):
Seeing as how JJ always gets the most out of its widebody fleet, one can expect the aircraft not to sit on the ground in GRU for 15 hours too often. A regional rotation is more than likely in between the GRU FRA trips.
A388
Sat Aug 18, 2007 3:29 pm
Quoting HB-IWC (Reply 2):
As much as I understand the reason for not letting the A345 just sit on the tarmac soaking up the sun, wouldn't it be overkill to use the A345 on these shorter sectors? The A345 is an ultra longrange aircraft, a nonstop flight between GRU and FRA already is far within the capabilities of the A345 as the A332 can fulfill this role already. Maybe JJ can use the A345 to MIA/JFK as well?
A388
HB-IWC
Sat Aug 18, 2007 6:36 pm
Quoting A388 (Reply 3):
With only 2 aircraft in the fleet and the proposed GRU FRA schedule, there is no way that JJ can schedule another longhaul rotation with these aircraft. My guess is, as such, that, rathen than having the aircraft sit on the ground in GRU for 15 hours every day, the airline will pencil in a regional rotation at least on certain days of the week to increase utilization rates. As for the A345 being overkill for such routes, SQ schedules two daily A345 roundtrips on the 1h30 SIN CGK sector...
OceansWorld
Sat Aug 18, 2007 6:44 pm
Quoting LipeGIG (Thread starter):
Just to check, are these still the two AC aircraft ?
PHKLM
Sat Aug 18, 2007 6:57 pm
Quoting HB-IWC (Reply 4):
A possible deployment of the A345 could be by combining JJ8000 and JJ8010 GRU-EZE by operating a new flight in between the two scheduled departure times (9h00 and 10h30). This will free up two A320 frames on those days.
PHKLM
Sat Aug 18, 2007 7:09 pm
Quoting OceansWorld (Reply 5):
Yes. Judging by the number of seats (42J and 225Y) they are the Air Canada birds. JJ will use the AC cabin, a clear sign that they do not intend to hold on to these birds for a long time. Most likely until the 77W arrives.
Edit: This thread seems to contradict all this. Where Are AC's 345s? (by ZBBYLW Aug 17 2007 in Civil Aviation)
[Edited 2007-08-18 12:31:43]
dellatorre
Sat Aug 18, 2007 8:09 pm
Felipe, could you share the sorce with us??? I'd like to know if TAM got 4 extra frequencies to fly daily or 7 new frequencies adding to those 3 they already had.
A350XWB
Sat Aug 18, 2007 8:39 pm
Thank you for sharing this information. Great for JJ and LH.
So we'll see FRA-GRU three times daily between 10pm and 11pm:
RG 8741 22:05-07:00 B763
JJ 8070 22:30-07:40 A345
LH 0506 22:45-07:30 B744
[Edited 2007-08-18 13:40:33]
OceansWorld
Sat Aug 18, 2007 8:50 pm
Quoting PHKLM (Reply 7):
Yes, that's why I'm asking questions in both threads, and am looking forward for more detailed informations regarding JJ's source for these aircraft as well as what will happen on AC's side.
jog
Sat Aug 18, 2007 9:10 pm
Quoting Dellatorre (Reply 8):
According to their press release they got four new frequencies, i.e they have 7 in total now.
PHKLM
Sat Aug 18, 2007 9:22 pm
Quoting A350XWB (Reply 9):
Is the A345 really that slow?
I mean a full 30 minutes slower than the 744 on a 5300nm route?  Wow!
I can imagine if you loose an hour on every round trip it starts to add up...
SAOAP
Sat Aug 18, 2007 9:42 pm
TAM usually has 2-3 widebodies (2x332 and 1xM11) sitting all day long in GRU. The execption might be the winter when we see a lot of charter flights within South America, especially between Brazil and Argentina.
Cheers!
Marcelo
PS: anyone know who granted TAM the extra four slots? It's my understanding they only had three. Was it ANAC?
"When it's dark enough, you can see the stars" - Charles A. Beard
HB-IWC
Sat Aug 18, 2007 10:04 pm
Quoting SAOAP (Reply 13):
Of the 3 A332 frames on the ground in GRU during the day, JJ uses one for a GRU MAO and another one for a GRU SCL roundtrip. Since the daylight departures to MIA and JFK have been introduced the utilization of the A332 fleet has been considerable increased because of reduced ground time at GRU.
LipeGIG
Sun Aug 19, 2007 6:20 am
As per HB-IWC comments, nowadays they keep 1 M11 from CDG and 1 A332 (depending on maintenance schedule could be CDG, JFK, LHR or MIA) at GRU.
With not only the 2 future A345 but also 3 more A332, TAM will keep (by the fact MXP would become a overnight flight) 5 frames at GRU.
I expect a daylight service to CDG in the near future, EZE could be back as an A332 route but we couldn't expect domestic services like SSA, REC or FOR to become A332 as JJ now will receive some A321 with more Y seats than the entire A332 can provide.
About sources, TAM issued yesterday a press release with the additional 4 frequencies as the bilateral has been revised to 21 frequencies (pax) plus 7 cargo against 22 all-in frequencies in the past. The timetable was issued by TAM also yesterday and will be advised to the market during the next week.
As we discussed in the past seems to be a huge increase on seats South America-Germany this year, and in fact at least in Brazil, fares are down this off-season.. it's easy to find out a US$ 899 R/T to Europe from Brazil as well as airlines are financing again in 5x installments without interest (for Brazilians).
Over 2006, LH increased their service to MUC, establish a new service from EZE to FRA, JJ will begin it's own service, RG resume GIG-FRA, as well as for the rest of Europe, additional seats to AMS (using the 77W), MAD (new JJ service, more IB and UX frequencies), LIS (more GIG/GRU service as well as BSB-LIS), MXP (the JJ service was established this year), CDG (two more GIG-CDG daily services as JJ one begin on january)....
Felipe
vega
Sun Aug 19, 2007 6:58 am
Quoting LipeGIG (Reply 15):
Has TAM actually shown anywhere, within the past week, that this route will be flown with a 340-500 rather than the 332? I ask this ? because the 345s have been removed from TAMs Fleet configuration by several internet based sources and someone mentioned in another thread yesterday that the 345 transfer was canceled by AC last week - without any confirmation reference.
We are but a moment in this vast Universe and when gone we will never have existed.
haan
Sun Aug 19, 2007 7:03 am
Any chanse TAM to consider GRU-JNB?
LipeGIG
Sun Aug 19, 2007 9:32 am
Quoting Vega (Reply 16):
I always respect others sources ! The confirmation has been posted by TAM on it's internal network so it seems that the deal remain firm.
Quoting Haan (Reply 17):
Considering the 2010 World Cup, could be feasible. But AFAIK their plans for the future are some additional services to the US and a second flight to LHR. Now they decided to focus Europe because it's where there is no Daily Brazilian Flag service to some destinations like MAD.
They have more planes to be received, let's wait a little more.
Felipe
A350XWB
Sun Aug 19, 2007 3:14 pm
Very interesting, so there now seems to be room for LH to start FRA-GIG.
robffm2
Sun Aug 19, 2007 6:43 pm
Sorry, but somehow I don't get the logic of the bilateral. Currently I count already 30 weekly flights between Germany and Brazil:
  • FRA-GRU LH502 744
  • FRA-GRU RG8741 763
  • FRA-GIG RG8779 763
  • MUC-GRU LH504 343
  • FRA-SSA DE3076 763 (twice weekly)
How can a bilateral with 21 frequencies provide room for JJ?
Finishing, let me say that I just would love to see JJ again in FRA!
jog
Sun Aug 19, 2007 6:53 pm
Quoting Robffm2 (Reply 20):
It's 21 flights for Brazilian airlines plus 21 flights for German airlines - so in total 42 flights would be possible.
hardiwv
Sun Aug 19, 2007 6:54 pm
Excellent news and I remember I have stated this here some time ago: there is room for more flights and more frequencies between Germany and Brazil.
We can see a huge expansion of capacity and service Germany-Brazil: this year alone LH will introduce the B747 dedicated FRA-GRU, while increasing MUC-GRU from the A343 to A346. TAM now will offer daily flights and RG keeps struggling with its FRA-GRU and FRA-GIG.
I have my doubts whether RG will manage to operate to FRA after TAM starts its operations.
Rgs,
PHKLM
Sun Aug 19, 2007 7:10 pm
Quoting Hardiwv (Reply 22):
After cutting EZE and now possibly FRA I think we can say there's absolutely nothing left of the old VARIG. To me those two routes are a resemblance of "what once was". It's a good thing there are finally more seats at this market, now let's wait for prices to go down Big grin
LipeGIG
Mon Aug 20, 2007 12:36 am
Rob, it's a bilateral, both countries keep 21 weekly flights (pax/cargo) + 7 dedicated to cargo, each.
Quoting A350XWB (Reply 19):
I don't think that LH will look for GIG during the next 12 months. First i believe they will try to consolidate EZE as a non-stop route. With more services from Brazil (RG and JJ) the market become more competitive.
The question is that... is there demand for this ? The market is now on a downturn because of the accident and the recurrent problems in Brazilian ATC.
Felipe
PHKLM
Mon Aug 20, 2007 1:14 am
For the ones that are interested, if you want to be on the inaugural flight of the 77W:
KL791 AMS - GRU on Thursday 27 March 2008 will be the first to see the 77W.
thering
Mon Aug 20, 2007 1:17 am
So looks like JJ is is the process of finishing it's FirstClass. That's bad...... They will need to improve Business.... So than they will have 3 different products on their fleet: M11's RG-style seats(poor), 332's orginal TAM seats (good), 345's AC-style lie-flat business seats (very good)... Though, it's not good to have such a differed fleet in terms of seats right? Looks just like RG 2-3 years ago, had poor First Class in some planes and Sky Suites in others..... Less informed passangers will buy a ticket not knowing what are they going to get... They could just move the seats to the 77Ws and 332s when they arrive...
146 319 320 321 332 722 732 733 734 735 73G 738 742 743 744 762 763 772 773 CRJ ER4 100 F50 F27 M11 D10
LipeGIG
Mon Aug 20, 2007 5:56 am
One new A332 should be used in order to allow all A332 fleet to be updated and to become a single configuration. I know that F class will be reduced from 7 to 4 seats, but i don't know yet if all A332 will get F.
hardiwv
Mon Aug 20, 2007 5:12 pm
Quoting PHKLM (Reply 25):
GRU will be the launching destination of KL B77W and the first flight will take off from AMS to GRU on 09 March 2007. KL will deploy the B77W 5 x week while B772 2 x week.
Rgs,
PHKLM
Mon Aug 20, 2007 5:26 pm
Quoting Hardiwv (Reply 28):
You are right Hardiwv, my mistake.
thering
Mon Aug 20, 2007 8:02 pm
Quoting LipeGIG (Reply 27):
Interesting... Probably we will se a lie-flat on business and a Suite on First.. That's my thought...
rootsair
Mon Aug 20, 2007 8:33 pm
Does anyone know why TAM will fly the A345. Isn't GRU-FRA too much of a "short" route for this a/c ? Couldn't an A343 or a 772 do the same job ?
regards
BM  airplane  wave
A man without the knowledge of his past history,culture and origins is like a tree without roots
PHKLM
Mon Aug 20, 2007 9:00 pm
Quoting RootsAir (Reply 31):
The 772 is impossible to get by on a short-term lease basis. I can't think of a single carrier that is phasing out 772's right now. TAM has the 77W on order, so they need an interim solution.
I reckon they just picked whatever was available on the market; the AC345's would be stored if not leased to TAM IMHO.
On a side note, the "holy grail" of Brazilian aviation, GRU-NRT, is impossible for the A345, even with its long legs.
LipeGIG
Mon Aug 20, 2007 10:58 pm
regards
Availability of planes! They need planes on the short term and the 2 A345 deal appears as a good solution which provides TAM with the capability to open a new route while they expect for the 77W's and A332's.
Also, they are now clear focused on increasing their international long haul operations because of the better yield compared to the domestic one (where competition with G3 and others become strong and reduced yields). They will add 5 more widebodies this year (now they have 13 nowadays). During the next years they will receive even more widebodies not to replace their fleet, but to improve more.
And as PHKLM explained, it's also the best option as there is no 772 or A343 available now for a 3 year lease.
Felipe
thering
Tue Aug 21, 2007 2:51 am
Yes but they didn't got the 345
Quoting LipeGIG (Reply 33):
When are they gettint rid of the M11s?? Would be like, one 77W arrives, one M11 goes??
LipeGIG
Tue Aug 21, 2007 6:02 am
Quoting Thering (Reply 34):
From June to August 2008, at the same time they will be receiving their first 4 77W's. TAM need to deliver the planes in order they can be converted to cargo planes.
Felipe
