centrair
Plotting A Route On A Map
Mon Aug 20, 2007 8:44 am
I am working with a couple of my students who are currently in MKE for a week. They have to do a presentation when they return and wanted to include a map of their flights.
I am tracking all their flights and getting the numbers but they want to plot the route on a separate map.
As Flightaware only visualy plots domestic flights. Trans-pacs don't show up except for the route info (visual is a zig-zag). I only have the info for their international flight (NW20). I have their domestic flight info and the plot as it was domestic.
GUPPY OTR8 KAGIS A590 PABBA OTR5 CALMA
4200N 16000E 4400N 17000E 4700N 18000E
4900N 17000W 5100N 16000W 5300N 15000W
5400N 14000W KATCH YYD J510 YEG FUDGY
VLN J483 MOT FAR GEP5
So how do I plot this on a map?
I will have to do this again when they return on DTW-NGO next week. I also want to do this when I fly home this winter. Might as well learn this.
I am also looking for a possible route plots of NW78 NGO-NRT on August 18.
Justin "Centrair" Dart
My name is Centrair but HND is closer. Let's Japanese Aviation!
aviationwiz
RE: Plotting A Route On A Map
Mon Aug 20, 2007 9:01 am
You could always use FlightMemory: http://flightmemory.com/
Proudly from the Home of the Red Tail.
chase
Tue Aug 21, 2007 1:51 am
Or the Great Circle Mapper: http://gc.kls2.com/
Note that this and FlightMemory will chart the optimal (shortest) route for the flight. But of course the actual flight will deviate from that path by a little bit.
Also, if you have programming knowledge, you could check out the Google Maps API...you would need to calculate the Great Circle route, break each flight down into 10 or more segments (enough so that the line segments resemble a smooth curve), and plot each segment on a map. Not that hard, really.
