DIA
Is This A320 Dirty, Or Patchwork, Or Both?
Wed Aug 22, 2007 12:32 am
Can't tell if this A320 just needs new paint, a wash, or touch-up. What's going on around the over-the-wing exit doors...and at the top of the rear of the fuselage? Thoughts?
Photo © Weimeng
Ding! You are now free to keep supporting Frontier.
jetjeanes
RE: Is This A320 Dirty, Or Patchwork, Or Both?
Wed Aug 22, 2007 12:40 am
looks like just dirt around the doors.. that strip that looks painted on top im not sure,unless they were testing a section of new paint of something... Is this the one that burned yesterday..
i can see for 80 miles
Scorpio
Wed Aug 22, 2007 12:42 am
Quoting JetJeanes (Reply 1):
Nope. Wrong aircraft type / manufacturer, wrong airline, wrong country even.
richierich
Wed Aug 22, 2007 12:51 am
The dirt around the main cabin door is easy to identify. It is from a jetbridge.
Look at any older aircraft from CO, B6, BA, or other "white"-liveried airline - they all get dirty! Its not just Air France!!
The different color around the emergency exit doors I have a harder time explaining. Maybe the doors were recently replaced or something?
None shall pass!!!!
DIA
Wed Aug 22, 2007 12:56 am
Quoting Richierich (Reply 3):
Civil Aviation 101.
That, along with the rectangle patch up top is what I can't figure out. I'm sure one of A.net's techies can shed some light on this...
WINGS
Wed Aug 22, 2007 1:37 am
Quoting Scorpio (Reply 2):
Scorpio, You are a classic.  Wink I could have not said it better myself.
JetJames, this was the plane that went up in flames yesterday.
CHINA AIRLINES (TAIWAN) BOEING 737-800
Wings
Aviation Is A Passion.
jamesbuk
Wed Aug 22, 2007 1:54 am
Could it be that they may have increased the seat amount so they had to put new emergency exits in to keep within the rules? Cheaper than buying a new plane with 4 overwing exits  silly
rgds --James--
You cant have your cake and eat it... What the hells the point in having it then!!!
richierich
Wed Aug 22, 2007 3:05 am
Quoting DIA (Reply 4):
Civil Aviation 101.
I agree - just wasn't sure if you knew that. Some people on this site probably wouldn't know that.
I see what you mean. Not sure.....
None shall pass!!!!
airfoilsguy
Wed Aug 22, 2007 3:07 am
My guess is that the plane was filthy and was at a jet bridge. A horrendous rain storm came about and cleaned the plane except for the part covered by the bridge. The emergency doors are new patches and the top by the tail is the retractable moon roof.
It's not a near miss it's a near hit!!
paladin87
Wed Aug 22, 2007 3:14 am
Quoting DIA (Thread starter):
Most likely to identify them, perhaps for de-icing or emergency response for quicker locating
Scorpio
Wed Aug 22, 2007 3:18 am
Quoting Paladin87 (Reply 10):
You make them dirty to identify them???  rotfl   rotfl
copter808
Wed Aug 22, 2007 3:28 am
My guess would be that the different color shade around the overwing exits is to make the exit doors easier to see. If you look at the bottom of those exits, you can see the white strip in the blue. The white on white wouldn't be very easy to see!
jamesbuk
Wed Aug 22, 2007 3:33 am
Quoting Copter808 (Reply 12):
Thats one most airlines with a similar livery....
I'm still adamant I'm right in the fact they increased passenger loads/seats hence they had to increase the number of exits per law... so instead of buying a new plane, which is of course costly.. they cut out a hole over the wing and inserted in these exits, which is why the "dirt" is square, when has anyone here ever seen square dirt? or a jet bridge on an emergency exit?
rgds --James--
paladin87
Wed Aug 22, 2007 3:40 am
Quoting Scorpio (Reply 11):
Funny. I was referring to the emergency exits over the wing not the main cabin door
avianca707359b
Wed Aug 22, 2007 4:08 am
Here's the same aircraft, taken in Dec 2006:
Photo © Xu Zheng
Same phenomenon.
I can't believe that plane was not washed once during an 8 month period.
Perhaps it is not dirt but moisture? Maybe some fuselage panels have a different metallurgical composition and collect condensation differently - and through an optical illusion it just looks like dirt? I don't know what to make of this. I have no real explanation, especially regarding the roof "strip".
In Memory of HK-1402 "Sucre" & HK-1410 "Bolivar"
bmibaby737
Wed Aug 22, 2007 4:09 am
Quoting Jamesbuk (Reply 13):
If you look at previous photos, you'll see that your 'theory' is in fact false.
jamesbuk
Wed Aug 22, 2007 4:20 am
Quoting BmiBaby737 (Reply 16):
So why would there be square dirt? both on top of the fuselage and around the emergency exit?
'theory'
 Confused
Rgds --James--
hman
Wed Aug 22, 2007 4:27 am
Its totally false, since all A320s have 4 overwing exits as far as I know. It's the A319s that need an extra pair for extra capacity.
paladin87
Wed Aug 22, 2007 4:30 am
True, but also it's a 320 , they all have two window exits on each side.
jamesbuk
Wed Aug 22, 2007 4:34 am
Quoting HMan (Reply 18):
Ah ok thanks... could they be replacements? maybe during a D check if the aircraft is old enough?
rgds --James--
Scorpio
Wed Aug 22, 2007 4:40 am
Quoting Paladin87 (Reply 14):
So was I.
flybyguy
Wed Aug 22, 2007 5:36 am
Quoting Avianca707359B (Reply 15):
...Same phenomenon.
Photo © Xu Zheng
I think that this plane may have just been abused in its years of service. You can clearly see a large patch underneath the L2 door... probably the work of a careless airstair driver. Other patchwork might be because of metal fatigue cracks or something of that sort. Perhaps that's the reason why the overwing exits are also included in what looks like patchwork?
Just to put my 2 cents, I don't think any of the state owned Chinese airlines take particular pride in the appearance of cleanliness of their planes... much like large municipalities rarely wash their metro busses simply because of the costs and logistics of it and the fact that they get replaced after a few years anyway. I believe that this sort of mentality is the same in Chinese commerical aviation... they probably run their aircraft into the ground because at the rate the Chinese economy is going the government will just make another ginormous multi-billion dollar order with Airbus or Boeing every few years and disperse them among the national carriers.
A roommate of mine from Shanghai once told me that Chinese medical centers get huge budgets, however if they don't use all the money their budget gets slashed... so it's not uncommon for a medical center to have multiple MRIs and med-evac helicopters they don't need. If this is true, maybe this sort of budget philosophy carries over to the airlines as well.
"Are you a pretender... or a thoroughbred?!" - Professor Matt Miller
teme82
Wed Aug 22, 2007 5:56 am
Me thinks it's because the air in major cities in china is bad. I was in Beijing in 1996 and when I stepped out of that A310 I felt the dust in the air. So I don't wonder why Chinese planes are looking dirty.
Flying high and low
bx737
Wed Aug 22, 2007 6:42 am
Could it be that the aircraft was cleaned in all bar sensitive areas. Maybe the scrubbing brush damages the overwing exits and cant reach up to the patch on the roof? Maybe the wash plants can't cope with the A320s and dont clean that particular area on the aircraft. I remember for a while when our local bus company introduced a brand new fleet they all had an identical dirt stripe on the back where the existing washers couldn't accommodate the new vehicles.
It is an airbridge that causes the marks at Door 1L, they are visible on all aircraft that park at airbridges.
wingletsman
Wed Aug 22, 2007 7:22 am
just dirty, and wear and tear...
however.... so sad to see that new 738 go!!  Sad  Sad  Sad  Sad
the winglets didn't burn though!!
GeorgeJetson
Wed Aug 22, 2007 7:32 am
Some A319s (although not many) do have 4 overwing emergency exits. Search for D-AGWE, an A319-132 of Germanwings and you will see what I mean.
Meet George Jetson
PH-TVH
Wed Aug 22, 2007 7:33 am
Quoting Breiz (Reply 7):
Easy. In China, the passengers use also the emergency exits to disembark. After a while, these doors do not seal very well anymore, so the airline techs use duck tape to seal them off.
In other words, not a clue.
I have a hard time to believe pax use emergency exits to disembark.
First point: These exits are sealed, once used, they need to be resealed by certified mechanics.
Second point: Where would the get of the wing?
Third point: A wing is not made to handle dozens of pax per day....
And I can go on for quite a while when I think about it...
bx737
Wed Aug 22, 2007 7:34 am
Quoting GeorgeJetson (Reply 26):
Easyjet have their A319s configured with 156 seats, as a result all of their A319s have 4 overwing exits
GeorgeJetson
Wed Aug 22, 2007 8:00 am
Quoting Bx737 (Reply 28):
It’s interesting how sometimes the number of overwing emergency exits can be used to easily distinguish one aircraft type from another one that’s similar. I remember back in the old days, it seemed like the easiest way to tell a Boeing 707 from a Boeing 720 was by counting the number of emergency exits. The 707 always had four overwing exits while the 720 usually had two instead. And of course, there were always exceptions as Eastern’s 720-025 as well as Northwest’s 720-051B had four of them! But nowadays, it really doesn’t matter since almost all these old birds have been long gone. As for today’s planes, one can also distinguish Next Generation Boeing 737s not only by the fuselage length (which may not be obvious to most people) but also by the number of overwing emergency exits with the Boeing 737-600 and -700 having two emergency exits and the -800 and -900 having four of them. I imagine that there may be exceptions with the NGs as well but can’t think of any offhand.
Meet George Jetson
David L
Wed Aug 22, 2007 8:07 am
Quoting PH-TVH (Reply 27):
I suspect the rest of the post gives a clue as to how serious it was...
 biggrin
Blackbird1331
Wed Aug 22, 2007 9:32 am
If this airliner is owned by Air France, then I would say it is dirt. If it is owned by any one else, then I would say it is dirt. But, not as dirty.
Cameras shoot pictures. Guns shoot people. They have the guns.
Aaron747
Wed Aug 22, 2007 9:44 am
Have you been to China recently? The air quality is horrendous. If you flew through all of that particulate matter, dirt, soot, and industrial gunk you'd look like that after a week too.
QXPDXMTX
Wed Aug 22, 2007 10:04 am
I believe that the areas around the emergency exits are for easier identification and area on the top of the plane could be like the areas on the top of CRJ aircraft where it is best to cut the fuselage to rescue people who may be trapped inside if they are unable to escape via the doors/overwing exits. Just my 2 cents, and a heck of a run on sentence now that I look back at it.
Panman
Wed Aug 22, 2007 10:10 am
The different shades of paint just tell me that some work was done there recently and the paint required a touch up.
It could be any of numerous things
  • Corrosion
  • Structural repair
  • Flaking Paint
  • Paint discoloration - though too uniform in shape for me to believe it is this.
    The mechs didn't use the exact shade of white, or enough coats of the correct shade of white (the primer can make the white appear darker than the surrounding area). Case in point: We had a TNT A300 in the hangar a while back where some corrosion was removed. The mech then reprotected the area, primed it with green primer, and applied one coat of orange paint. The result was a brown patch. After a few more coats it was orange.
    First point: They are not 'sealed' as such and are quite easy to open, though unless the slides are deactivated (have to open up a panel in the aft cargo bay to do that) opening them will set off the slides.
    Second point: If you can find an A320 pic that shows the upper surface of the wing at the emergency hatches, you will find that arrows pointing the way to disembark are painted on it. The arrows show the way to the slides, the slides will enable them to get down.
    Third point: Correct. It was made to handle far more weight than that.
    PaNmAn
    kieran74
    Wed Aug 22, 2007 12:34 pm
    maybe it is mold spots.........hahaha
    Ruscoe
    Wed Aug 22, 2007 12:52 pm
    Could it have something to do with "cold sink" where the more heavily reinforced (or possibly repaired) areas hold the "cold" longer resulting in the appearance of a different colour. I had a car like that once. However the area above the fuselage would not fit my theory I think.
    ruscoe
    hman
    Wed Aug 22, 2007 2:04 pm
    That's what I was talking about although I was thinking about the Easyjet ones.
    D328
    Wed Aug 22, 2007 3:28 pm
    Way dirty....haha...I like dirty planes though..
    cricket
    Wed Aug 22, 2007 3:44 pm
    No insult intended towards any Chinese friends here, but my god the planes in that country are Dirty. I was at PVG once and the SQ 773 I was taking was parked next to a MU jet and it seemed the wings hadn't been cleaned ever, so much dirt and grime had accumulated on them. What is so peculiar though is that the streets in Shanghai are spotless, the Pudong side seems cleaner than Singapore. In fact, I began to wonder if it was a city/culture obsessive about cleanliness. But then you saw the planes.
    Anyway, the dirt can't really affect flight performance can it?
    A300B2/B4/6R, A313, A319/320/321, A333, A343, A388, 737-2/3/4/7/8/9, 747-3/4, 772/2E/2L/3, E170/190, F70, CR2/7, 146-3,
    AirPacific747
    Wed Aug 22, 2007 4:07 pm
    Quoting Cricket (Reply 39):
    I think it can a little bit.. just like dirt on cars can affect performance on those a little bit too.
    Strathpeffer
    Wed Aug 22, 2007 4:55 pm
    Personally I favour the 'touch-up' explanation. Perhaps MX used a paint that had a reduced gloss component compared to the stuff Airbus initially specs the plane with - maybe even the stuff painted under cockpit windows to restrict glare.
    This could have been done in error or because they had no alternative. Either way, dirt and airborne particulates would adhere faster and more effectivly to the rougher surface of the less glossy paint - leading to the effect seen.
    PJ
    Another Technical Problem?
    Bongodog1964
    Wed Aug 22, 2007 5:39 pm
    Quoting Jamesbuk (Reply 20):
    I tend to agree with the above, could it be that the door framing has either been replaced or is of a different material to the rest of the fuselage ?
    iflyswa
    Wed Aug 22, 2007 6:26 pm
    It looks to me like some sort of poorly mismatched paintwork, or as Panman suggests, a hastily applied coating of paint over fresh primer. Above the overwing exits, take notice of the care taken to mask around the bottom of the C in the word "China."
    The bowl (bottom) of the letter C dents the baseline just a little, extending below the imaginary line the word "China" seems to rest upon. It's a simple trick of perception, since putting something with a curve (or a point, in some cases) precisely on such an imaginary line so that they meet exactly would give the effect of the character riding high, instead of being in-line with the other characters.
    The top of the painted (discolored) area above the overwing exits takes into account the C dipping below its baseline, dipping with and around it, so as not to cover any part of the letter C with the new application of paint to that area.
    iflyswa
    Opinions expressed by "iflyswa" are not those of Southwest Airlines Officers, Directors, or Employees.
    cx777fan
    Wed Aug 22, 2007 7:34 pm
    Quoting QXPDXMTX (Reply 33):
    That would stack up if every A320 - or at least every CZ A320 - but this one seems to be unique. I'm leaning towards some kind of mx issue and for some reason (price maybe) glossy white paint wasn't reapplied. Not a very thorough answer, but it's my best guess.
    PH-TVH
    Wed Aug 22, 2007 11:39 pm
    Quoting Panman (Reply 34):
    First point, you are indeed correct, my fault
    Second/third point, I know there are arrows on top of the wing. But I cant imagine the surface of the wing is made for the daily abuse of handling high heels and that kind of stuff. Indeed the wing is made for far more weight... But not on the way a high heel presses upon a coke-can thin surface... The wing is veeeery strong.. as a WING. Its made to withtstand crazy load factors.. But again, not high heels...
    USADreamliner
    Oh, Lord... nobody in USA listen during geography class????
    Scorpio
    Wed Aug 22, 2007 11:50 pm
    Quoting PH-TVH (Reply 45):
    Um, have you still not figured out that the post you were originally replying to (by Breiz) was, in fact, said jokingly? One would think the
    part would have given it away...
    planesavvy
    Thu Aug 23, 2007 12:17 am
    In my experience Chinese airliners are the dirtiest flying into Heathrow, and that includes Cathay Pacific. The polution in China certainly has an effect.
    In regards to this picture, I reckon that when the aircraft was being cleaned in a maintenance area, the over wing exit doors had been removed for servicing and a patch was stuck over their position, explaining why there is a dirty square around them and they are clean themselves.
    PH-TVH
    Thu Aug 23, 2007 12:20 am
    Quoting Scorpio (Reply 47):
    why do I take things always to serieus when it goes about aviation  Sad
    copter808
    Thu Aug 23, 2007 3:40 am
    You're kidding, right?
    Other than the darker white around the overwing exits, there is no contrasting paint, except for the stripe on the bottom.
    As for the darker color around the front loading door, it may not be dirt. The dirt from the jetway is evident as a curved arc over the top of the doorway, extending to the left (front) and down over the cockpit window.
