SkyexRamper
Midwest Connect/Skywest 2878 E-landing
Thu Aug 23, 2007 1:12 am
This morning Midwest Connect flight 2878 MKE-EWR had an engine failure in flight shortly after departing MKE. These damn CRJs just keep giving us problems. Flight landed in one piece back at MKE.
[Edited 2007-08-22 18:14:03]
Good Luck to all Skyway Pilots! It's been great working with you!
DeltaAVL
RE: Midwest Connect/Skywest 2878 E-landing
Thu Aug 23, 2007 1:14 am
How long can a CRJ go on one engine?
"We break, We bend, With hand in hand, When hope is gone, Just hang on." -Guster
SkyexRamper
Thu Aug 23, 2007 1:17 am
Quoting DeltaAVL (Reply 1):
Provided it can maintain level controllable flight, probably a while. If the airplane is preforming fine one engine, then it's a matter of fuel.
Tornado82
Thu Aug 23, 2007 1:21 am
"Straight to the scene of the crash" - Ron White
Seriously, a CRJ like any other twin airliner can go indefinitely on one engine as far as maintaining altitude, though it is still very wise and prudent to land pretty much ASAP. Airliners aren't like some of the light "training" twins where if you pull the engine you can basically maintain straight and level and if you're lucky climb at 100fpm.
That said, I'd rather be on something like the 73G or the E170 running on one than the relatively doggish CR2.
futureualpilot
Thu Aug 23, 2007 1:28 am
Quoting Tornado82 (Reply 3):
"I bet we beat the paramedics there by a half hour!"
I would imagine it is SOP at most airlines, at least for aircraft with only two engines.
I think Part 121 aircraft have to demonstrate the ability to climb single engine (i.e. V1 cuts or failure during climbout, etc), although someone can correct me if I am wrong as I don't recall the specifics.
Life is better when you surf.
uadc8contrail
Thu Aug 23, 2007 1:34 am
Quoting SkyexRamper (Thread starter):
SkyexRamper,
has the OO crjs been a problem since coming onboard at YX???
Bus Driver
flyf15
Thu Aug 23, 2007 1:40 am
Engine failures, although rare, happen from time to time. Sometime for the strangest or most unexpected reasons. 99.9% of the time, they are non-events and the crews flying these aircraft get the passengers back on the ground safely. Although by no means a non-event, the pilots up front are extremely well trained professionals and make it seem easy.
Quoting SkyexRamper (Reply 2):
100% Correct.
The CRJ flies just fine on one engine. Although a dog up high, it has a lot of power down at the low altitudes.
Quoting Futureualpilot (Reply 4):
In the event we're flying on one engine, we'll land at the nearest suitable airport. Suitable meaning it has adequate runways, weather, crash-fire-rescue, etc.
This is correct. We have climb profiles we have to be able to meet when flying on one engine. If you loose an engine at the worst possible moment, highest weight, worst conditions, etc... you will still be able to climb out and return for a safe landing.
SkyexRamper
Thu Aug 23, 2007 1:45 am
Quoting Uadc8contrail (Reply 5):
SkyexRamper,
Yes....not this serious but way too many probs. Lately the 328s have been looking good.
JBo
So in other words, they fit right in?
I'd take the awe of understanding over the awe of ignorance any day.
Sinlock
Thu Aug 23, 2007 2:15 am
On, reading in the topic "E-Landing"
My first thought what would qualify as an E-Landing?  duck
I guess it would be CATIII-C ILS.  sly
smcmac32msn
Thu Aug 23, 2007 2:22 am
Quoting Skyexramper (Reply 7):
Yikes!  duck  Hey Skyex, I got a story for you sometime.
Hey Obama, keep the change! I want my dollar back.
MKENut
Thu Aug 23, 2007 3:14 am
Did YX get another plane to take the passengers to EWR?
apodino
Thu Aug 23, 2007 4:45 am
The strange thing is, the GE engines on the CRJ are among the most reliable in the business with very few problems. That being said, the ones SkyWest pulled from the desert to do this flying were ex indy air birds. I have heard that their engine maintenance program was not the greatest in the world. ACA never did things like Flex takeoffs or stuff like that. Those will murder an engine. Plus SkyWest does single engine taxi's I believe, and those will also murder an engine (Hence the reason my carrier does not do them). I don't know what condition these planes were in, but my sources tell me they weren't in great condition. I know SkyWest has a great maintenance department, but given where these birds were, I am not surprised that this happened.
I wonder if the service would have been better and more reliable had Midwest gone with Air Wisconsin as most people feel they should have.
sideflare75
Thu Aug 23, 2007 5:43 am
It was not an engine failure. Just a bleed air problem. Aren't we being just a bit dramatic?
Quoting MKENut (Reply 11):
Yes. Skywest actually keeps a spare at the hangar just in case. Can't say I've seen them use it much. Usually it just sits there but obviously today they did. The other one has been in and out of the hangar already so it must not have been too serious.
JBo
Thu Aug 23, 2007 5:47 am
Quoting Apodino (Reply 12):
Probably depends on if ZW had obtained the same aircraft for the operation.
n917me
Thu Aug 23, 2007 6:22 am
Yes, it was a bleed air. We actually have not have much trouble with the OO CRJ's since they came online April 1. We have had some issues, but not nearly as much as someone elses CRJs. who has a state in their name.
pilotfox
Thu Aug 23, 2007 6:37 am
The other week MSN had a Pinnacle CRJ-200 flight (MCI-DTW) divert here with a right engine shut down, low oil pressure. Anyways it overnighted and departed the next morning as (MSN-MEM) supposedly fixed. However soon after takeoff it declared an emergency again with the same engine problem.
Goldenshield
Thu Aug 23, 2007 6:40 am
Every bird that OO has gotten from ACA/Indy in way way or another, have been crap. Poor engines (-1A version), lack of ACARS, not Cat II, etc., not to mention the maintenance headaches.
That said, there are a few ex-ComAir birds running around in MKE and MCI, too. The engines on those are crap, too, but not near as many problems.
As they go through maintenance, everything is getting upgraded as parts arrive. The -1B hot and high variant (as opposed to the standard -1B,) which are standard on OO's fleet, are slowly being swapped onto those birds as they arrive.
n917me
Thu Aug 23, 2007 7:15 am
Quoting Goldenshield (Reply 17):
All the "BR" tails that OO uses for YX have ACARS.. N698BR, N699BR, N709BR, N710BR all have ACARS. Tail N417SW has ACARS too. Tails N495CA, N494CA, N506CA, N506CA, N496CA. N498CA, N468CA, and N471CA do not have ACARS. Talk is to install ACARS..but talk is talk.
I do have to say (a bit off topic) The OO crews for the most part are GREAT! Captain Nate is hilarious.
Goldenshield
Thu Aug 23, 2007 8:28 am
Quoting N917ME (Reply 18):
They do now, but not when we got them.  Wink
And we're still waiting on engines.
SkyexRamper
Thu Aug 23, 2007 9:51 am
Quoting JBo (Reply 8):
Yep
Yes
Quoting Sideflare75 (Reply 13):
That's what I was told from my sources at the airport. Generally don't dought them.
sideflare75
Thu Aug 23, 2007 10:04 am
Quoting SkyexRamper (Reply 20):
Better get some new sources then. Wink
Maybe they are the same ones who tell the news media what's going on at the airport since they turn everything into something it is not.
SkyexRamper
Thu Aug 23, 2007 1:44 pm
Quoting Sideflare75 (Reply 21):
Can't always be at MKE either, glad today was my day off.
WesternA318
Thu Aug 23, 2007 10:10 pm
Oh too funny....
