acroairfun
Airbus A321 Noise
Fri Aug 31, 2007 8:14 pm
I saw the aircraft noise charts and I saw that A321 introduced in 1994 is noisy like Boeing 747-300 introduced in 1980! Why?
Everything is flexible if you know how to bend it.
PADSpot
RE: Airbus A321 Noise
Sat Sep 01, 2007 1:56 am
Are referring to outside noise emissions or the noise level inside the cabin?
JeffB
Sat Sep 01, 2007 2:33 am
Quoting AcroAirFun (Thread starter):
That makes absolutely no sense to me. 2 engines on a smaller plane making more noise than a 747 w/ 4 engines and less noise dampening systems?
Can you provide a link to said charts? or maybe a description of where you saw these charts?
ncelhr
Sat Sep 01, 2007 3:07 am
That's right, an A321 is noisier at takeoff than a B743 at idle.
This doesn't make sense. Too many parameters - gotta see the charts.
ca2ohHP
Sat Sep 01, 2007 3:23 am
I fly the A321 alot, and I do notice that it seems much louder on takeoff (particularly in the back) on takeoff until the power reduction after being airborne 90-120 seconds.
Sat Sep 01, 2007 3:54 am
I think this is a clear case of someone reading some numbers an not knowing what they mean, in summary a A321-200 is much quieter than a 747-300.
A 747-300 with a TOW 377,800 kg and CF6-80C2B1 has the following noise characteristics relative to Chapter 3
Flyover - 6.9
Sideline - 4.6
Approach - -0.2
Cumulative - 11.3
An A213-200 with a TOW 93,000 kg and V2533A5 has the following noise characteristics relative to Chapter 3
Flyover - 4.6
Sideline - 2.4
Approach - 5.5
Cumulative - 12.5
Above numbers from http://www.aci.aero/aci/aci/file/ACI...ties/Environment/ACINoiseIndex.pdf
But what does relative to Chapter 3 mean ?
We need to look at ICAO Annex16, Volume I, Attachment A
Between a TOW of 35 and 400t, the sideline noise is defined as 80.87 + 8.51 log(TOW)
747-300 = 80.87 + 8.51 log (377.8) = 102.80 EPNdB
321-200 = 80.87 + 8.51 log (93.0) = 97.62 EPNdB
747-300 margin over chapter 3 is 4.6 = sideline noise generated is 102.80 - 4.6 = 98.20 EPNdB
321-200 margin over chapter 3 is 2.4 = sideline noise generated is 97.62 - 2.4 = 95.22 EPNdB
A321-200 is 2.98 EPNdB quieter
Between a TOW of 35 and 280t, the approach noise is defined as 86.03 + 7.75 log(TOW), above 280t it is a flat 105
747-300 = 105 EPNdB
321-200 = 86.03 + 7.75 log (93.0) = 101.29 EPNdB
747-300 margin over chapter 3 is -0.2 = approach noise generated is 105 + 0.2 = 105.2 EPNdB
321-200 margin over chapter 3 is 5.5= approach noise generated is 101.29 - 5.5 = 95.79 EPNdB
A321-200 is 9.41 EPNdB quieter
Between a TOW of 48.1 and 385t, the flyover noise for twin engine aircraft is defined as 66.65 + 13.29 log(TOW)
Between a TOW of 20.2 and 385t, the flyover noise for four engine aircraft is defined as 71.65 + 13.29 log(TOW)
747-300 = 71.65 + 13.29 log (377.8) = 105.90 EPNdB
321-200 = 66.65 + 13.29 log (93.0) = 92.81 EPNdB
747-300 margin over chapter 3 is 6.9 = flyover noise generated is 105.90 - 6.9 = 106.10 EPNdB
321-200 margin over chapter 3 is 4.6 = flyover noise generated is 92.81 - 4.6 = 87.31 EPNdB
A321-200 is 18.79 EPNdB quieter
In summary,
the 747-300 has a 11.3 EPNdB cumulative margin over chapter 3, the 747-300 chapter 3 cumulative limit is 313.70 EPNdB
the 321-200 has a 12.5 EPNdB cumulative margin over chapter 3, the 321-200 chapter 3 cumulative limit is 291.72
EPNdB
The A321-200 is 31.19 EPNdB cumulatively quieter than a 747-300, as expected.
[Edited 2007-08-31 21:20:40]
PADSpot
Sat Sep 01, 2007 4:12 am
Quoting Zeke (Reply 5):
747-300 margin over chapter 3 is 2.4 = sideline noise generated is 97.62 - 2.4 = 95.22 EPNdB
747-300 margin over chapter 3 is 5.5= approach noise generated is 101.29 - 5.5 = 95.79 EPNdB
747-300 margin over chapter 3 is 4.6 = flyover noise generated is 92.81 - 4.6 = 87.31 EPNdB
the lower line in each section shall refer to the A321 and not the B743, right? Impressive number cracking ... but how does 31.19 EPNdB feel?
[Edited 2007-08-31 21:21:57]
Sat Sep 01, 2007 4:22 am
Quoting PADSpot (Reply 7):
Correct, fixed, thanks, just copied and pasted the first line and changed the numbers, and forgot to change the model.
Claude
Sat Sep 01, 2007 3:19 pm
hi, i guess you've heard an A321 with maybe a bit thrust just before landing, but surrely not more than a 743!
how many drinks did you have lol  Wink
ThePRGuy
Sat Sep 01, 2007 6:17 pm
I've flown a lot of 321s recently, and perhaps you are referring to the whine you get with some of the 320 series engines with age?
I personally enjoy the noise very much so!
Alex
Heathrow has been described as the only building site to have its own airport.
TurkishWings
Sat Sep 01, 2007 6:34 pm
I noticed that sound too.. Especially during take off...
Recently, I flew on a few A 321s of TK and noticed that the whole cabin shudderes when the plane touches down.. Is this also common with this type? It felt like the cabin of a very very young plane was falling apart...
Coffee - Tea or Me?
flanker
Sat Sep 01, 2007 10:36 pm
I have not noticed anything weird like that. Must be because i like engine noise, but anyway i love how quiet the A320 family is when powe is reduced after takeoff. It almost scares you. I remember the first time i flew an a321 when power was reduced i thought we had lost the engine on the side i was sitting. Its SOOOOOOOOO quiet. lol
Calling an illegal alien an 'undocumented immigrant' is like calling a drug dealer an unlicensed pharmacist
