modesto2
SFO Runways
Thu Aug 17, 2000 7:32 am
I was near SFO the other day and I noticed the aircraft were approaching from the opposite end of the runway. I know 28L/R are usually used for landings but are 10L/R ever used? And for OAK...is runway 11 ever used (I think I've seen it in operation)? Thanks.
c72
RE: SFO Runways
Thu Aug 17, 2000 8:01 am
As far as I know 10 L/R at SFO are used at times but with strict noise abatement rules on departures.
Don't know about OAK.
Steve
OPNLguy
RE: SFO Runways
Thu Aug 17, 2000 9:04 am
SFO normally uses 28L/R for arrivals and 01R/L for departures, and this is their optimum configuration. If the winds and/or rain (wet runways) force SFO off the above, things start slowing down. 19L/R are rarely used for takeoffs, since rising terrain limits takeoff weights. 01L/R are sometimes used for arrivals if the winds absolutely require it, but that same terrain doesn't allow approaches in very low weather like 28L/R does.
OAK usually stays on 29 and 27L/R, and SJC 30L/R. Both will generally go to 11, 09L/R, and 12R/L, respectively, whenever SFO changes from their optimum.
RE: SFO Runways
Thu Aug 17, 2000 10:05 am
Yes the do land on the 10's when the winds dictate it (which is not very often). Here are some shots that I took of planes landing on the 10's at SFO. The shots were taken from the United gate 77 area.
http://www.geocities.com/silagi/n701me.jpg
http://www.geocities.com/silagi/9vsjc.jpg
Richard Silagi
D L X
RE: SFO Runways
Thu Aug 17, 2000 3:43 pm
DANG! And I missed it?
Is this the same as the rare I280 approach flying low over the 101?
RE: SFO Runways
Thu Aug 17, 2000 11:49 pm
DLX, no you are thinking of the cirling "KaiTak" style approach to 1L/R. That is the rarest approach at SFO. That one happens only once or twice a year and only for a few hours at a time.
Landing on the 10's is a little bit more common. It is a straight in approach through the "gap" over Daly City and San Bruno" There is even a published instrument VOR approach to the 10's. There is no instrument approach for the 1's and it can only be done is clear weather.
Richard Silagi
D L X
RE: SFO Runways
Fri Aug 18, 2000 1:38 am
Okay. Well, somebody PLEASE let us know if they ever do that approach at SFO.
That sort of circling approach is quite common at IAD (although there are no mountains) and it is quite awesome a sight to be able to see both TOP surfaces of a 744's wings on the big turns.
ILUV767
RE: SFO Runways
Fri Aug 18, 2000 1:46 am
It was raining at SFO one moring in Feb, and my flight took koff from 10R. That was a first for me!!!   From my window, I saw planes landing on 19L/R. On another rainy day, my flight took off from 19L   We were in a brasilia so we did not need much runway to take off, but once we got airborn, we made a very sharp turn to the left, and flew over some hotels, and then sort of over 101, and back out over the bay. Then we flew south, and Turned east and started to head to SMF
timz
RE: SFO Runways
Fri Aug 18, 2000 7:30 am
They wanted to build more floors into that hotel SE of the S end of runways 19, but I guess ALPA or somebody was able to prevent it.
My guess is that in any given year odds are 50-50 there will be no jet arrivals on the 1's. Arrivals on the 10's are next rarest. Departures from the 10's are the norm in rainy weather; I guess if the wind is 190 at 20 kt and the runways are wet that's when they depart from the 19's. On one (and only one) occasion I saw Japan Air depart from 19L, presumably to Tokyo. Also, saw a Tower Air 747 off 19R to JFK.
Adam84
RE: SFO Runways
Fri Aug 18, 2000 3:50 pm
Every time I have flown into SFO I have landed on 10L/R, in CO 757's and NW DC-10's.
