LAXintl
JetBlue Splits With ATA Over FAA User Fees
Tue Sep 04, 2007 5:36 am
Interesting opposition to otherwise widely supported industry plan.
JetBlue Splits With ATA Over Methods To Calculate User Fees
09/04/2007
JetBlue has declared its opposition to the Air Transport Association's FAA funding proposal and mounted its own campaign on Capitol Hill last week urging law makers to reject ATA's suggestions.
Carrier CEO Dave Barger sent letters to heads of pertinent committees in the House and Senate outlining JetBlue's arguments and declaring ATA's proposal "thinly veiled."
The airline takes exception to two aspects of ATA's proposal - the domestic distance tax and exemptions for the first 250 miles of a domestic flight.
JetBlue argues that ATA is opting to measure distance flown using a "great circle" calculation, rather than actual flight distances. A JetBlue spokeswoman noted that the rationale for using pure origin-and-destination mileage is for simplicity and ease of administration, but she noted that while, "it is 'easy,' it's also wrong.
JetBlue also takes issue with ATA characterizing the 250-mile exemption as a way to reduce the burden on smaller communities. The carrier argues ATA's plan exempts more than 25% of all domestic flights, including all the shuttle flights from New York City to Boston and Washington. Those flights alone, JetBlue said, produce more than 100 flights per day in each direction. While JetBlue supports a genuine small-community ATC fee exemption, "this disingenuous plan mocks the importance of small community air service," Barger said.
Full story (subscription required)
http://www.aviationweek.com/publicat...ver+Methods+To+Calculate+User+Fees
westindian425
RE: JetBlue Splits With ATA Over FAA User Fees
Tue Sep 04, 2007 5:53 am
JetBlue raises some valid points, I must say.
God did not create aircraft pilots to be on the ground
Mir
Tue Sep 04, 2007 6:20 am
If the US would get a high-speed rail network going, there would be no need for a 250-mile exemption, and would make an additional 250-mile tax an attractive idea.
-Mir
LAXintl
Tue Sep 04, 2007 6:30 am
I can somewhat see their point on the 250mile exemption as clearly some of the nations busiest flying and densest ATC environments are included.
However on the overall distance based fee, I'd side with the ATA proposal to use simply great circle mileage between cities. Otherwise airlines and the FAA would be taxed with keeping track of actual flown distances on each flight which could really become and accounting nightmare. For instance would airlines get penalised and have to pay higher fees for routing around weather, or getting an ATC re-route? In theory no two flights would have the same distance between city-pairs as each one might take a slight different route based on many operational factors.
I'd also compare this to how foreign nations charge overflight fee's. In most cases (with a few notable exceptions like Japan) fee's are simply based on the great circle distance between entry and exit points of that nations airspace. Simple and fair when applied across the board.
Mir
Tue Sep 04, 2007 7:45 am
Quoting Laxintl (Reply 3):
It would be pretty easy to calculate the distance for filed routes (aircraft that can go direct and off airways get charged less). I agree that actual distance flown would be prohibitive, and that there should be no charge for routing around weather, but simply charging on filed distance would be simple enough.
-Mir
SPREE34
Tue Sep 04, 2007 7:51 am
Why say "penalized"? If they create extra work for ATC by flying around weather or anything else they choose, let them pay the extra fees for creating extra work in the "pay to play" world they want to create.
I don't understand everything I don't know about this.
Mir
Tue Sep 04, 2007 8:04 am
Quoting SPREE34 (Reply 5):
When you have to pay to route around weather, you create an incentive not to route around weather. That's a serious safety issue - you want to minimize the incentives to take serious risks.
-Mir
LAXintl
Tue Sep 04, 2007 9:05 am
Quoting Mir (Reply 4):
True, however again the incentive for airlines to file the shortest possible route for the sake of saving money, while asking crew to request the "real routing" once airborne is quite possible.
Quoting Mir (Reply 6):
 checkmark  indeed. Same logic FAA uses to exempt maintenance related delays from airline On-Time statistics. Dont want to create the incentive or pressure to cut corners in order to receive a better performance ranking.
Anyhow I cant quite understand how and airline would oppose this as a great circle calculation provides the least cost as its the shortest possible distance. Any other measure of filed or actual route flown would be greater distance and eventual cost. With some carriers running 1000's of flights daily even seemingly small dollar amounts can add up quickly for one fat bill at the end.
SPREE34
Tue Sep 04, 2007 9:20 am
Therein lies one BIG problem with ATC privatization and/or running safety related systems for financial reasons. The money becomes the prime consideration in decisions related to safety rather than the safety being the prime consideration.
DING! Safety of flight should never ever take a second priority to anything. Keep the government running the largest and safest ATC system in the world. Do not run it for profit. Fire the flunkies in the FAA who are failing by every measure to run it competently and efficiently.
The US Congress needs to get off their asses and put the money where it needs to be, put competent people in charge of the money and the modernization, then hold said persons accountable for the failure or success of the system. A political appointee will never get that done.
SPREE34
Tue Sep 04, 2007 9:27 am
Quoting Laxintl (Reply 7):
When the request for the "real routing" is made, clear them as requested, then charge a "change of plan" fee.
ATA wants those who use to pay right? Those who use extra should pay extra. To quote some of The ATA's propaganda, "fair is fair".
You gotta love an association of failed businesses (ATA) trying to tell someone else how to run an ATC system. LMAO.
Edited for spelling
[Edited 2007-09-04 02:59:07]
LAXintl
Tue Sep 04, 2007 9:41 am
There are plenty of private AND safe ATC systems in this world. UK, Canada, Australia, Germany etc..
In reality I believe a private system could very well be safer then a national system. Private companies have the ability to spend funds directly on newer technologies and improving system efficiencies unlike governments whom often funnel various revenue streams into central bank coffers or take year to consider the simplest decision.
Most countries to my knowledge that have gone the private route have seen significant improvements in services offered. Matter of fact a couple years ago I saw an ICAO study which looked at countries that had privatized their ATC systems and all had experienced leaps in modernization, capacity and efficiency gains.
SPREE34
Tue Sep 04, 2007 10:10 am
Quoting Laxintl (Reply 10):
None of those systems are as large or complex as the US system. Canada is held up as an example on a regular basis. The US system puts more traffic through the State of California by 9:30 am than NAVCANADA moves in a 24 hour period. (Sorry I don't recall the source)
Congress can fix the money stream and coffer issues. As for taking years to consider the simplest decision, as I said, install competent management and hold them accountable. When you have a political appointee in charge, delaying or not making decisions is an art form. It's how they avoid accountability. Marion Blakey has done it very well. She is about to leave and drop the bucket of crap she's created in someone else's lap.
LAXintl
Tue Sep 04, 2007 10:27 am
Quoting SPREE34 (Reply 11):
If a single private system is going to be too hard to run, privatize the system along the current ATC boundaries. We can have 22 smaller individual contracts awarded then.
The world looks to the United States as a symbol of free and private enterprise. With all the talent and money here I'm sure we can figure out a manner to efficiently and safely privatize things.
You know that will never change. Its simply part of the government just like the post office, IRS etc...
Mir
Tue Sep 04, 2007 11:40 am
Quoting Laxintl (Reply 12):
That might well be the worst thing that could happen. The US is one unified country, it should have one unified air traffic control system.
-Mir
sccutler
Tue Sep 04, 2007 12:11 pm
There are things which are best done privately, and they should be. ATC is not such a thing.
The ATA is disingenuous in the extreme on this issue, attempting to persuade those who know no better (members of the public who know nothing about the aviation infrastructure) that the problems in the ATC system and in scheduling are somehow related to the handling of non-airline traffic.
And it just ain't true.
The ATC system is designed around the needs of the airlines as it is. A fuel-tax based system makes the most sense.
...three miles from BRONS, clear for the ILS one five approach...
LAXintl
Tue Sep 04, 2007 12:28 pm
Quoting SCCutler (Reply 14):
There lies the problem.
Under a fuel based system the airlines would again be footing the burden of the ATC system while Corporate flyer in his G-V skates by still.
From an ATC perspective there is really no difference in handling a G-V or a 747. What the ATA is trying to point out the cost of handling aircraft in the national airspace system needs to be commensurate with services provided. In other-words the guys that today gets full use of the system for free basically need to start contributing to what they are using.
Another argument made I've read in Europe is that airliner in reality deserves even a further break as they manages to transport hundreds of people using the same service that a smaller aircraft only carrying maybe a handful of folks is. The smaller flyer ties up the system that can be used more efficiently by larger craft.
P3Orion
Tue Sep 04, 2007 12:35 pm
Quoting Laxintl (Reply 15):
That B747 and other Heavies require more separation and create other problems than the GLF5.
I will have a Manhattan.
LAXintl
Tue Sep 04, 2007 12:38 pm
OK make it a 737 then. Happy ?
Point being airlines would continue footing the bill for the national ATC system regardless of services provided to others.
The G-V manages to operate with pennies on the dollar while receiving same services.
[Edited 2007-09-04 05:41:55]
P3Orion
Tue Sep 04, 2007 12:44 pm
Why are you so eager to privatize the U.S. ATC system. What benefits do you think would happen? Can you see any drawbacks?
[Edited 2007-09-04 05:45:48]
LAXintl
Tue Sep 04, 2007 12:59 pm
Quoting P3Orion (Reply 18):
I'm not parse eager for a privatized system, however strongly believe the national system needs a huge overhaul including the manner the system generates revenues and spends money. I'm also a very strong proponent of technology believing its helps man work smarter instead of harder.
If privatization is the means to change things and move our basic 1950s system forward (which might be the case due government bureaucracy) then I'm all for it. I've travelled and lived around the globe and can from personal experience have seen transformation of other nations ATC systems and vouch for their benefits.
p.s. - by the way, I dont know if people realise but a good many airport towers are run by private entities and not the FAA. I think the success of such a system proves Uncle Sam does not need his hands in everything.
P3Orion
Tue Sep 04, 2007 1:07 pm
Quoting Laxintl (Reply 19):
Between the time I was a controller for the Navy and the FAA, I worked at two contract towers for two different companies (Midwest ATC and RVA), and I can tell you safety takes a back seat to profit.
Like SPREE34 stated, how can you compare the NAS with Canada, Great Britian or Germany?
[Edited 2007-09-04 06:18:50]
LAXintl
Tue Sep 04, 2007 1:18 pm
Quoting P3Orion (Reply 20):
Why are we afraid to compare? We can certainly scale a system appropriately. Whether this means doing it in sections over time, splitting the NAS system into various smaller contracts etc..
These other countries have proven a switch can be successfully and safely made to a privatized system allaying public fears and overcoming concerns of unions.
We are not some 3rd world banana republic. Putting out best talent and money forward I'm sure we can develop a world class system we would all be proud of.
SPREE34
Tue Sep 04, 2007 1:21 pm
Ahh... Have you had a look at what has happened to the now privatized Flight Service Station system? Lockheed Martin has so fouled things up, and then asked for more money to help them fix what they claimed they could operate. The tax payer has been ripped off.
Nightmare. It's bad enough now with them operating like 20 little FAAs. 20 different vendors doing a bang up job like LM is over at FSS. No thanks. BTW, the FAA has started the process of reducing the amount of Enroute Centers. Houston will be the first to go.
I have seen many statements like this on A.net this week. You, like the others, have made a statement with little or no knowledge of how ATC really works.
The G-V or other Bizjet has much less impact on the system. The Bizjets aren't having to be slowed and turned to achieve spacing to an over scheduled runway. The bizjet generally takes off, climbs out, cruises (above the airlines), descends and lands. If that Bizjet is going out of a major Terminal Area like DFW,ATL, or other major Metro area, it will end up restricted (some would say penalized) under the AIRLINE traffic coming out of the primary airport until sufficient separation for a climb exist. Inbound the Bizjet will be forced down earlier (penalized) than the AIRLINES so the controllers have room for turning and slowing the AIRLINES who are scheduled into the primary airport at a volume exceeding the runway acceptance rate.
So who is screwing who here? Who is creating more work in the system? From WHOS perspective?
How can you (Airline Management / Consulting) say the words "From an ATC perspective...." ??
What ARTCCs have you certified in? What TRACONS?
I am happy to answer any questions you may have about ATC.
P3Orion
Tue Sep 04, 2007 1:27 pm
Quoting Laxintl (Reply 21):
But how would the users benefit? Also, the only way a privatized system can make money is to cut back on training and staffing it's controllers. I have seen it first hand; both in the U.S. (Contract Towers) and Canada (Nav Canada).
[Edited 2007-09-04 06:30:56]
LAXintl
Tue Sep 04, 2007 1:41 pm
Quoting P3Orion (Reply 23):
Again look at other countries. They have used funding to plow money into newer technologies and tools aiding with both capacity and safety. Australia for instance is building an ADS-B system providing coverage in areas that lacked radar coverage ever before. The UK is redesigning its upper and Oceanic airspace to provide added capacity for users while consolidating older smaller ATC centers under new single roof with better coordination.
Quoting SPREE34 (Reply 22):
See my PM. However I'm far from some green person when it come to US ATC issues.
Ultimately guys, we'll have to agree to disagree however I cannot phantom why we are not willing to explore ways to make NAS better even if take a radical move like privatizing it. Its easy to say no, its harder to come up with the actual solution and its fixes.
Have a pleasant evening all.  wave
Mir
Wed Sep 05, 2007 1:18 am
The US already has a world-class ATC system. It moves far more traffic than any other airspace system in the world, and does so just as safely, if not more safely, than any other airspace system in the world.
Improvments should be made to keep up with technology, certainly, but why should we radically change something that isn't broken?
-Mir
SPREE34
Wed Sep 05, 2007 1:51 am
Yep, and you can read about the lack of staffing and failure to meet the FAA contract by going to the Inspector Generals website. They are being operated on a bottom line philosophy by ex FAA mangers who set up the system just before they retired from the FAA.
Again, go read the Inspector Generals reports.
Words from someone who has been there and seen it.
I don't care how many classes someone has taken, how many ATA, ATCA, or other industry sponsored seminars they have attended, or how many liaison positions they have held an an air carrier. If you haven't been on the inside and seen what the actual work entails, you lack a great deal of needed info to make an informed decision. For that reason companies like Mitre employ recently retired controllers, who have that understanding, to help them in their research.
Quoting Laxintl (Reply 24):
I'm sure you have more than "green" knowledge of the US ATC system. I do not question you having some "professional" view on US ATC issues, your PM seems a fair indicator of that. I, however, do not believe you have realistic working knowledge about what actually happens inside the system. I believe you probably have a good theoretical understanding, and are probably well read in ATC matters. You may have a better understanding than John Q. Public, or even some of your peers at other Part 121 operators. That being said, your writing here indicates, to me, very little understanding of what actually occurs operationally, or what the mechanics are of moving traffic.
sllevin
Wed Sep 05, 2007 5:51 am
Here's something to think about when you say "a plane is a plane."
VNY (Van Nuys, California) is, by total number of movements, is the businest GA-only airport in the world -- and one of the businest airports in the world (typically ranked above airports like MEM, MIA, JFK, IAD) yet the total ATC staffing on the airport is vastly smaller than at those commercial airports mentioned (which have fewer movements). In fact, they have significantly less than half the staff of ATL or ORD -- which are the only two airports in the world that have twice as many movements.
So clearly, if a GA plane is consider to use a "resource" commercial aircraft are, in the end, consuming many more "resources" per flight.
Steve
sccutler
Wed Sep 05, 2007 12:22 pm
Myth.
First off, a G-V burns a heckuva lot of fuel.
Secondly, I am aware of no private jet operators who have received hundreds of millions of dollars in tax subsidies to get themselves over a money-hump. User fees are another way to benefit an already heavily-subsidized industry.
Most fundamentally, however: overwhelming volume of ATC services are used by air carriers, and even if you managed to wipe all but the most-wealthy aircraft owners from the skies (as would happen in a user-fee environment, much as has happened in Europe), the ATC system would be required in essentially its same form.
ATC exists to serve the needs of air carriers; the use of ATC by GA simply adds safety.
Now, if you look where the actual bottlenecks are, you can see where some targeted capacity control measures would help- mostly, in the USofA, in the northeast. But even then, the real problem is not ATC capacity, it's runway capacity, in all but a very few places. And look around, gang-- the air carrier airports at which severe and persistent delays occur have essentially no general aviation activity.
Myth. Utter buncombe. Complete invention. Fictional fantasy. User fees in air traffic control have, in every place implemented, served to substantially reduce use of ATC by general aviation, and have thus decreased safety, not increased it. ATC fees have been a disaster in both Europe and Australia.
