socalatc
Alaska To HNL Today?
Thu Sep 06, 2007 1:48 am
AS 9351 was scheduled to depart SEA at 8:40 to HNL arriving at 12:05, looks like its been pushed back a little. Is this part of Alaska's ETOPS certification? Anybody know any details?
EA CO AS
RE: Alaska To HNL Today?
Thu Sep 06, 2007 2:02 am
It's an ETOPS proving flight. Consider it a "dress rehearsal," if you will.
bayareablue
Thu Sep 06, 2007 2:09 am
AS 9351 is in the air out of SEA and is due into HNL at 12:48pm local time.
bayareablue
Thu Sep 06, 2007 7:06 am
Heads up HNL, Alaska Airlines Fligth 9351, a Boeing 737-800 (N577AS), is descending through 17,000 feet and is due to touchdown in HNL in 36 minutes. Enjoy the first sighting of an AS aircraft.
ASAFA
Thu Sep 06, 2007 12:32 pm
Alaskaair.com shows this flight diverted to Maui, then operated OGG-HNL. Anyone have details?
as739x
Thu Sep 06, 2007 1:04 pm
It was intended diversion. The FAA is onboard, so the crew basically does as they ask. And if they say "WX is bad in HNL, then your off to your diversion city"
ASSFO
bayareablue
Thu Sep 06, 2007 1:07 pm
As has been pointed out previously in this thread, this was the first validation flight for AS. The FAA was on board and testing the crews ability to react to certain instances. Looks like they were asked to simulate what would happen (most likely an engine loss since the engines are the most critical part of ETOPS flights) and the decision was made to divert to OGG over HNL. Why you ask go further south? It could be anyones guess but maybe they were given the scenario that HNL could not handle the situation and they had to go the alternate aiport (This case it was OGG). Aircraft was on the ground for about 3 hours and finally continued onto HNL. It will most likely head back to SEA tomorrow, but you never know what can happen on a validation flight.
as739x
Fri Sep 07, 2007 1:26 am
It will fly back to Seattle as 9352 today.
Depart HNL 0930
Arrive SEA 0615
ASSFO
Bluewave 707
Fri Sep 07, 2007 2:28 am
Isn't AS serving OGG from SEA as well as HNL and LIH? Their initial service is to HNL, with OGG and LIH coming online soon after.
BTW, who is doing the ground handling @ HNL, OGG, and LIH?
"The best use of your life will be to so live your life, that the use of your life will outlive your life" -- D Severn
bayareablue
Fri Sep 07, 2007 2:31 am
For now it will just be SEA -HNL/LIH and ANC-HNL (seasonsally).
Unsure of the ground handling.
EWRCabincrew
Fri Sep 07, 2007 2:37 am
Quoting AS739X (Reply 7):
Depart HNL 0930
Arrive SEA 0615
Impossible.
SEA time when the flight leaves, according to this 0930, is 1230.
You mean departure 0930, arrival 1815.
AS website shows in comments field as "not operating as scheduled" (special flight).
http://www.alaskaair.com/airport/flightstatus/FlightStatus.aspx
[Edited 2007-09-06 19:38:01]
You can't cure stupid
as739x
Fri Sep 07, 2007 3:13 am
Sorry, ment 1815
ASSFO
Chugach
Fri Sep 07, 2007 6:42 am
Quoting Bluewave 707 (Reply 8):
According to the KOA thread, AS is shopping around for ground handlers at KOA. Provided that HNL and LIH are successful, I wouldn't be shocked to see OGG and KOA start in the next year or two.
socalatc
Fri Sep 07, 2007 3:23 pm
As far as customer service, United will handle in KOA and Delta in HNL. Dont know if they have their own ramp agents.
kalakaua
Fri Sep 07, 2007 3:34 pm
When does AS start flying to ANC?
Gravity explains the motions of the planets, but it cannot explain who set the planets in motion.
Chugach
Fri Sep 07, 2007 3:46 pm
Quoting Kalakaua (Reply 14):
AS has flown to ANC for years  Wink
ANC-HNL daily service starts, I believe, December 9 and runs through April. Next year, seasonal service will begin in October. Don't be surprised to see this one go year-round before too long.
kalakaua
Fri Sep 07, 2007 4:45 pm
Quoting Chugach (Reply 15):
Haha! I didn't see that. I have an odd perspective. I like to center my flights and airlines from HNL.
Thanks.
HikesWithEyes
Sat Sep 08, 2007 2:58 am
There's another flight airborne right now (1100 PST, Friday), also 9351.
First, benzene in my Perrier, and now this!
ANCFlyer
Sat Sep 08, 2007 3:35 am
Quoting EWRCabincrew (Reply 10):
Depart HNL 0930
Arrive SEA 0615
Impossible.
Not if you properly transit the space/time continuum . . .  duck
Hope the flight was uneventful . . . I'm ticketed the AS bird to HNL 2/7/08 returning on HNL-ANC 2/15/08.  biggrin .
Quoting Socalatc (Reply 13):
Delta in HNL
Oh, Lord . . . oh well, at least the ANC-HNL leg won't be hosed . . .
I suspect sooner than later - if AS has the aircrat to support it. I'd not be surprised to see AS start taking some of Hawaiian Vacations pax . . . . increase the number of seats to HNL from ANC . . .
BP1
Sat Sep 08, 2007 4:29 am
E.T.O.P.S. - Engines Turning Or Passengers Swimming
"First To Fly The A-380" / 26 October 2007 SYD-SIN Inaugural
FLY777UAL
Sat Sep 08, 2007 5:08 am
AS9352 is currently scheduled to depart HNL at 4p ETA SEA 1245a.
F L Y 7 7 7 U A L
