OB1504
Concourse J @ MIA: The Soap Opera
Fri Sep 07, 2007 6:36 am
Quoting The Miami Herald:
Subcontractors had to halt work because doors were locked and no one had the key.
A prime contractor had no clue how much nearly a dozen jobs cost -- and ''no clear direction'' on how to proceed on masonry wall, elevator shaft and electrical work.
The construction manager bypassed a qualified low bidder for a paving contract in favor of a business partner whose budget later ballooned by millions.
As Miami International Airport unveiled its gleaming new 1.7 million-square-foot South Terminal last week, passengers could savor the roomier concourses and fresh sheen of the floors.
What wasn't so visible: the discord, delays and errors that helped add hundreds of millions in cost and 2 ½ years to the project's timetable. Planned for a budget of $799 million six years ago, the terminal's tab is now $1.1 billion.
A Miami Herald review of 100,000 pages of correspondence sheds light on how a project conceived on a ''fast track'' became mired in change orders, angry subcontractors and escalating costs.
Full story available at http://www.miamiherald.com/top_stories/story/227219.html.
It's a fascinating read about everything that went (wrong) into the construction of the recently-opened Concourse J.
Cory6188
RE: Concourse J @ MIA: The Soap Opera
Fri Sep 07, 2007 6:40 am
What airlines are going to be located in Concourse J at MIA?
[Edited 2007-09-06 23:42:04]
PanAm747
Fri Sep 07, 2007 7:11 am
When private businesses do government work with no real enforceable deadlines or oversight, the public ends up with projects like Boston's "Big Dig", Denver's beautiful but delayed International Airport (and that horrific baggage system), and now Miami's new terminal.
In California, hardly the shining example of getting things done properly, we have two examples of the best way to handle things. In 1994, after the Northridge earthquake, a private contractor was given the job of rebuilding Interstate 10 through west Los Angeles. His company was given a bonus for everyday they finished ahead of schedule. Not only did he do quality work (the appropriate oversight), but it ended up costing less than the inevitable overruns would have done.
The same company was hired to repair the melted interchange in the Oakland area after a gasoline truck crashed into a pillar and destroyed part of the interchange. Instead of the six months predicted, his was done in around six weeks. Again, it was done quickly, efficiently, and under budget.
Massive public works projects are almost impossible anymore, because everyone wants a sweet deal. There's no reason to go quickly when you're getting paid for your overruns, is there? And why not let your friends in on the deal - don't use the low bidder - go with your buddy, and pass the cost along to the taxpayers!!
As taxpayers, which plan would you rather go with?
Pan Am:The World's Most Experienced Airline - P(oor) S(ailor's) A(irline): San Diego's Hometown Airline-Catch Our Smile!
sandrozrh
Fri Sep 07, 2007 8:24 am
Quoting Cory6188 (Reply 1):
LH and LX as far as i know, dont know who else.
FAEDC3
Fri Sep 07, 2007 8:47 am
LAN is also going there
OB1504
Fri Sep 07, 2007 8:56 am
A previous thread speculated that Air Canada, Aerolineas Argentinas, Avianca, Caribbean Airlines, El Al, LAN, LTU, Lufthansa, Swiss, TAM, TACA, United, and US Airways might be moving into Concourse J.
MAH4546
Fri Sep 07, 2007 9:33 am
Quoting OB1504 (Reply 5):
There is no speculation. The new terminal has already opened, with Delta already using Concourse J check-in counters. The four LAN airlines move there on Monday. Others will be there by mid-October.
It is truly an amazing terminal, one of the nicest in the entire country. A total contrast to the other parts of MIA.
[Edited 2007-09-07 02:39:39]
a.
OB1504
Fri Sep 07, 2007 9:49 am
What are some of the major differences between J and the renovated A, D, and H?
MAH4546
Fri Sep 07, 2007 10:03 am
Quoting OB1504 (Reply 7):
It's roomier. It was built from the ground up and was not designed to flow into the current airport design (even though it is connected, behind security, to H). It was also designed primarily as an international terminal, so it features a more upscale selection of retail and eateries (such as Hugo Boss).
The renovated A, when it re-opens, won't be very different from today's. It is already a very nice terminal.
The renovated H is not very noticeable. The main addition is new concessions and international gates.
D has not been renovated. The "high D" gates were built from the ground up.
a.
b752fanatic
Fri Sep 14, 2007 10:55 am
So when is the J terminal going to open for arrivals and departure of flights? Its understood that the checkin counters are active, however the terminal is not.
When?
"Truth is more of a stranger than fiction." Mark Twain
aal0616
Fri Sep 14, 2007 11:08 am
Quoting MAH4546 (Reply 8):
It was a special privilege and thrill to be given a tour of J last week.
It is really, really awesome, and, yes, is not so much unlike the rest of the airport (which it certainly is), than really a competitive, modern and efficient design that rivals anything I have seen around the world. High, high, high "cathedral" ceilings, wide, roomy lobby three times deeper than the rest of the airport, etc. etc. Like a completely different planet.
It really makes the North Terminal saga look absurd by comparison, and humiliating for the North Terminal hub "home" carrier (oops, never said that ...), even if J had problems of its own. By comparison, J is a real success.
You will all really dig it when you see it or fly through it!
LawnDart
Fri Sep 14, 2007 11:56 am
Quoting MAH4546 (Reply 6):
Walked from the old Delta lobby to the new Delta lobby through the old Delta offices (in front of security), and the difference truly was night and day.
However, business in Miami being what it is, my fear is that, not only is it built through the buddy system ($$$), but it will start to fall down in a couple of years.
I hope I'm wrong. I don't think I am.
MAH4546
Fri Sep 14, 2007 12:02 pm
Quoting B752fanatic (Reply 9):
When?
The terminal is active. LAN Argentina, LAN Chile, LAN Ecuador, and LAN Peru are using it.
a.
