BA
50 Gate Airports In The U.S.
Fri Aug 18, 2000 7:46 am
What 50 gate airports in the U.S. do you know of?
Any help would be greatly appreciated!
Kind Regards
"Generosity is giving more than you can, and pride is taking less than you need." - Khalil Gibran
RE: 50 Gate Airports In The U.S.
Fri Aug 18, 2000 7:53 am
THIS SHOULD BE A GOOD ONE.......
ATL, DFW, LAX, MIA, EWR, DCA, CVG, DEN, MCO, CLE, DTW, MEM, STL, PIT, PHL, IAD.............??????
Republic
Fri Aug 18, 2000 8:02 am
.......IAH. Best as I could tell, 83 gates according to Houston aviation web site, www. houstonaviation.com
Fri Aug 18, 2000 8:19 am
DTW has 103 gates total right now, when the new terminal is built, we will have 177 gates total.
aa61hvy
Fri Aug 18, 2000 8:26 am
DFw has ALOT more then 50 gates they have 39 in terminal A alone. i think they have around 160 gates
Go big or go home
RWally
Fri Aug 18, 2000 8:54 am
Do you mean 50 gates total, or more than 50 gates in the whole entire airport, or 50 gates in one terminal?
BA
Fri Aug 18, 2000 9:24 am
I mean 50 to 55 gates in the whole airport.
DeltaRNOmd-80
Fri Aug 18, 2000 9:34 am
There are probably very few airports with gates JUST in the 50-55 range. All I know is Reno has 19, 9 on concourse B and 10 on concourse C.
Louis
Fri Aug 18, 2000 10:31 am
JFK as well. Probably SFO as well...Stapleton airport in Denver also had over 50 gates. I was reading somewhere that it had more gates than DIA.
US521
Fri Aug 18, 2000 11:52 am
I know that PIT has about 70+
US521
gocaps16
Fri Aug 18, 2000 12:06 pm
I know DCA has 45ish gates total...IAD, well...they have over 100 gates..not close to 50.
UAL744
Fri Aug 18, 2000 12:13 pm
How about this:
lax, mia,jfk, ord,sea,pdx,hnl,anc,iad,iah,bos,dfw, and basically all the US airline hubs
Fri Aug 18, 2000 12:14 pm
PDX has 54 gates.
Fri Aug 18, 2000 12:57 pm
Memphis International might have around 50. I think STL has about 75. Does DTW have the most in the world?? If not which airport has the most gates??
deltairlines
Fri Aug 18, 2000 11:02 pm
BOS I think has around 50-70 gates.
Jeff
thomacf
Mon Sep 18, 2000 5:30 pm
Cleveland has 50+
Tue Sep 19, 2000 1:00 am
SFO has 90 gates. Soon to be 114, when the International terminal opens. It is the largest international terminal in the US, with more gates than any other.
jmc1975
Tue Sep 19, 2000 2:00 am
Phoenix Sky Harbor has 100+ gates.
